Old 09-13-2005, 07:27 AM   #1 (permalink)
Got My Car Dynoed ( Sr16ve Pulsar )
HEY THE BOM HERE
Got my car dynoed at the weekend at WESTWARD ENGINEERING here in IRELAND. My car is almost completly standard. I have an induction kit, NGK plug leads and NGK Racing Plugs No: T7340A-7. And i also have the cat removed ( it was blown when i got the car in from JAPAN.so just removed the the internals of the box). The max BHP Was 165.4 at the flywheel and 141.3 BHP at the wheels the Torque was 113.8 lb ft. This was after i set the timing to 10 degres it was set at 6 on the first run ( dont have the info from the first run) but the torque jumped a good bit when we compaired the two runs
The Bom is offline   Reply With Quote
Old 09-13-2005, 10:34 AM   #2 (permalink)
The VE is for sale
The Boooooommmm!!!!!!!
"If I fart like that again I'm going to throw up" - my boss
nisser is offline   Reply With Quote
Old 09-13-2005, 12:06 PM   #3 (permalink)
70/30 Racing
Rockwood's Avatar
What base timing do those cars run on the stock ECU?
Steve Rockwood
92 G20 - PTD #73
Old 09-13-2005, 01:18 PM   #4 (permalink)
NeoVVL Egg
Those #'s seem pretty low actually. U should probably try bumping up your timing.....do you have the stock ecu setting off the cam switch points for you...i think stock they are intake 5700 and exhaust 6700....also, u might want to do a full tune up on that bad boy.
-John-
1992 Nx2000
Sr16ve, Hotshot CAI, VE Exh. Manifold w/hotshot downpipe, 2.5" Megan Racing cat-back, msd window switch, nismo fpr, eibach pro-kits and kyb gr2's, b14 se-r Wheels, Exxd Ecu.
NismoNx2000 is offline   Reply With Quote
Old 09-13-2005, 03:01 PM   #5 (permalink)
technics professional
Avshi750's Avatar
Trader Rating: 35 (100%)
with as much as i know about SR20 motors, even less about the VE series... i would venture a guess that you could bump the timing up to about 15*, but do some research before you do.
any pictures?
Avshi750 is offline   Reply With Quote
Old 09-13-2005, 03:17 PM   #6 (permalink)
Technician @ Toyota
scortch99th's Avatar
thats lower than my sr20de
91 classic SE-R
94 classic LE
91 240sx(rps13)
COMPRESSED CLIQ
Originally Posted by STRATTON
freddie your a SICK man.
stratton.
Originally Posted by chriscar
Maximum horsepower is dictated by your wallet.
Old 09-13-2005, 04:48 PM   #7 (permalink)
70/30 Racing
Rockwood's Avatar
Keep in mind this is on a 1.6L engine.
Old 09-13-2005, 05:48 PM   #8 (permalink)
increase timing
Prob a dumb question, but which way do you turn distrib to increase timing, towards the front or rear of the car?
vzrboy is offline   Reply With Quote
Old 09-13-2005, 05:58 PM   #9 (permalink)
Broke Ass
jer_760's Avatar
Turn the top of the distributer toward the firewall.
95 200sx
sr20ve
Old 09-13-2005, 06:17 PM   #10 (permalink)
SR20DET convert
Guys should also point out we only get 95 octane petrol over here.
Any dyno print out? What setup do they use?
Muttly is offline   Reply With Quote
Old 09-13-2005, 06:57 PM   #11 (permalink)
Yes that is with the stock ecu. W hat is this window switch that you are talkin about????
Old 09-13-2005, 07:04 PM   #12 (permalink)
Hey Muttly
I have a print out but my scanner is not workin. They use a rolling road system not like the bolt on system i have seen T.D.P using
Old 09-13-2005, 07:07 PM   #13 (permalink)
any pictures?
Thanks for that
Old 09-13-2005, 07:11 PM   #14 (permalink)
SR20DET convert
I'm sure you'll get it on eventually. Check out this, my run. http://media.putfile.com/Dyno-VZ-R
Old 09-13-2005, 07:12 PM   #15 (permalink)
My Timing
Hey
My timing was set at 6 degrees before i mooved it. The lad that dynoed the car dose not really have much interest in tuning my car.
Old 09-13-2005, 07:19 PM   #16 (permalink)
Hey Muttly
Are you still going on saturday to Portlaois
Old 09-13-2005, 07:24 PM   #17 (permalink)
SR20DET convert
I should be. No changes at the moment. You?
Old 09-13-2005, 07:25 PM   #18 (permalink)
SR20DET convert
For anyone interested. A few 1/4 miles. Not my car though.
http://media.putfile.com/VZR-1
http://media.putfile.com/VZR-2
http://media.putfile.com/VZR-3
http://media.putfile.com/VZR-4
Old 09-13-2005, 07:27 PM   #19 (permalink)
I will be there should have two other VZR's with me
Old 09-13-2005, 07:30 PM   #20 (permalink)
SR20DET convert
Sweet. We'll have to sort out a meeting point before the main one. Then head in together. 4 VZRs. I don't know if I asked you what colour is yours and the other ones?
