Old 02-23-2002, 06:31 PM   #21 (permalink)
^^ I'm with stupid ^^
JRios's Avatar
Approved vendor
Originally posted by CNibbana
This still doesn't answer the question can you use the VE ECU with the VE engine in a B14?
Andreas said that the N15 platform (which is the SR16VE) should hook right up to the B14, so i think is should be no problem. If i'm wrong somebody please correct me.
Jorge
1996 SE-R
Old 02-23-2002, 06:52 PM   #22 (permalink)
Retired VE Owner
I bought my SR20VE from Andreas and he is the one that told me I needed to have my DE ECU reprogrammed even though the motor came with the ECU.
I just want to know why you can't use the VE ECU. I'm guessing that it's because of the auto vs. manual tranny issue. I just want clarification.
Chuck Nibbana
Retired VE owner
2005 BMW M3
CNibbana is offline   Reply With Quote
Old 02-23-2002, 07:04 PM   #23 (permalink)
JRios's Avatar
Approved vendor
all you need to do is get rid of the speed limiter which is just a wire gut away. [/b][/quote]
Andreas, would this be possible with the VE ecu also, or the DE ECU? TIA
Old 02-24-2002, 06:05 PM   #24 (permalink)
BOOSTIN PROTECH STYLE
What year DET ECU have a Speed limiter, and what is it limited too? Also what wire is it that you cut?
Originally posted by Andreas Miko
I have put many a JDM DET ECU on a cars here in the US why do you think I sell them on the net. As far as Auto or manual working they both work. A det ECU is just as good as a JWT ECU but all you need to do is get rid of the speed limiter which is just a wire gut away.
Mike Collins
PROTECH FABRICATION
Myspace
"Protech - Making the highest quality products the right way, the first time every time."
PSSSHHHGOESMYSR20 is offline   Reply With Quote
Old 02-27-2002, 01:34 AM   #25 (permalink)
Team Serious Captain
ben that was my car at the convention and it had
a auto det ecu in it
walter (pep)
Originally posted by Ben98SentraSE
Everyone on the list forever and ever said you couldn't use a DET ECU on a US car even with a DET, but I found out you could as long as you have a manual DET ECU. I first learned this was possible by seeing a car that had had one for a year or so installed at the convention last year.
big pep nyc is offline   Reply With Quote
Old 02-27-2002, 08:50 AM   #26 (permalink)
Ben
www.motorists.org
Ben's Avatar
Hey man, cool
How did you get it to idle correctly? What type of TPS do you have in it?
99.5 Audi A4 Avant 2.8L quattro 5-speed
03 Honda Odyssey EX-L
Ben is offline   Reply With Quote
Old 03-28-2002, 12:53 AM   #27 (permalink)
爆走
edit
Old 03-28-2002, 01:18 AM   #28 (permalink)
爆走
edit
Old 03-30-2002, 02:43 AM   #29 (permalink)
Professor Dingbat
everyone is saying this is pretty much a bolt-on install for a B14, but a B13 with a high port head, how much more ifficult would the swap be?
Old 04-06-2002, 12:23 AM   #30 (permalink)
爆走
edit
Old 10-03-2002, 06:19 AM   #31 (permalink)
I can see that this post is really old, but just want to give my opinion!
When we did my swap we used my DE wiring harnes and the VE ECU.
The only thing we needed to do was to check out where the solenoids was getting their signal from on the VE ECU! To do that we just looked at the original wiring harness from the VE and then just pulled two new wires from the VE ECU to the solenoids. Because they weren't on my DE wiring harnes.
So no problem at all for us!
Carsten Elmegard
TeamNissan Denmark
http://www.TeamNissan.dk
1998 Primera with SR20VE
Now with Blown SR20VE engine
TeamNISSAN is offline   Reply With Quote
Old 11-06-2002, 10:22 AM   #32 (permalink)
yes, can you use a ve ecu on a b14 or b13?
Yes, I've been searching the forum and know one has been able to answer this question for sure.
Can you use a ve ecu on a b13 or b14???
--Eduardo
92' classic se-r, black
stillen header, jwt pop charger, magnacore wires, es engine mount inserts, courtesy exhaust
lalito is offline   Reply With Quote
Old 11-07-2002, 02:40 PM   #33 (permalink)
爆走
edit
Old 11-07-2002, 03:03 PM   #34 (permalink)
Plugs into what?? Obviously it will plug into the engine it came with. I'm assuming there are other connections--- I don't know a ton about this stuff-- is this what you are referring to? I'm getting a 99 engine and have a 92 nissan sentra se-r.
What do you thinK?
--eduardo
Old 11-07-2002, 05:34 PM   #35 (permalink)
He is referring to the original wireing harness. If it plugs in it will work fine. Otherwise you will need the complete VE harness to use the VE ECU. As time goes on and more of these swaps are done we might figure out which cars will take the VE ECU.
Steve
06 G35 6MT
Old 11-07-2002, 06:25 PM   #36 (permalink)
The guy I'm buying from says he has wiring diagrams and he has the ve harness as well as a de one. He says he is going to prepare it form me so all I have to do is "plug and play". I'm going to talk to him tonight and ask some more questions.
--Eduardo
Old 11-08-2002, 12:00 AM   #37 (permalink)
Teamnissan uses the VE ECU in his VE with the DE harness on his 98 g20...don't know if it's the same in the b14
b12sr20ve is offline   Reply With Quote
Old 11-09-2002, 09:55 AM   #38 (permalink)
Hello Guys,
Sorry I have been away for so long, but I have changed my ISP so I have been without internet for 2 weeks!
Lalito> The reason why we used my DE harness instead of the VE harness which of course would have fit the engine is, that all the other connectors to the “boxes” (don’t know the English term) won’t fit. The only thing we had to add was the solenoid activation wires from the ECU and the plugs for the injectors. The rest was just PnP (Plug and Play)
Old 11-09-2002, 10:53 AM   #39 (permalink)
Cool team nissan,
Just bought the engine. It's brand new, just broken in 1999. The guy, John Davis in Hawai, is setting it up with the de harness for me, so I don't have to do all the wiring. He's also sending my a new head for my de (which has a bent valve cause the timing chain lost its timing-- long story).
Anyway, he says he has all the fsms for these engines and stuff so he can do all the wiring and just send it to me pretty much ready to go. Hope it all works out. I'll keep you guys posted. Does anyone know how I can attach my pic of my new engine to these posts???
Also, have a question for you guys-- what the #!@$% is a selonoid??
--Eduardo
Old 11-09-2002, 11:50 AM   #40 (permalink)
Trader Rating: 53 (100%)
[quote] A det ECU is just as good as a JWT ECU but all you need to do is get rid of the speed limiter which is just a wire gut away.[/QUOTE
Would you like to shed some light on this Andreas? I bought my BB ECU from you like 2 months ago and I am just getting my car running (hopefully) this weekend. Thanks
