Old 11-29-2005, 11:23 AM   #1 (permalink)
NeoVVL Egg
The Bad Gas Mileage Saga continues....
Well, here it is...16mpg consistently on an sr16ve. NO matter how i drive, i get between 16-18 mpg all the time with mixed highway/city driving. We have tried everything you can think of practically to fix this problem.
- Ecu has been programmed twice to correct the problem = no change
- Full tuneup has been done = no change
- o2 sensor changed = no change
- Maxima maf wiring checked and switched then switched back = no change
- Exhaust leaks fixed = no change
- injectors checked for leaks = no leaks = no change
- Oil changed on regualr intervals = no change
- Wheels checked for brake drag - one wheel is dragging - next culprit to check
:: She runs strong and pulls hard to redline, vvl engagement at 5300 for in/ex.
:: She puffs out big clouds of black smoke when vvl is engaged and my back bumpter is covered in exhaust soot.
- I dont know what to check anymore. The brake drag is going to be the next thing i look at and i will also be getting an fuel pressure gauge. If anyone has any ideas or clues....im open to them.
-John-
1992 Nx2000
Sr16ve, Hotshot CAI, VE Exh. Manifold w/hotshot downpipe, 2.5" Megan Racing cat-back, msd window switch, nismo fpr, eibach pro-kits and kyb gr2's, b14 se-r Wheels, Exxd Ecu.
NismoNx2000 is offline   Reply With Quote
Old 11-29-2005, 02:40 PM   #2 (permalink)
A couple things, check tire pressure also put the ecu in mode I to monitor the o2 condition. The CEL should go ON to OFF more than 5 times in 10 sec.
91 Nissan Sentra SE-R: KYB AGX's, eibachs, prothane mounts, ES suspension bushings, addco RSB, FSTB/RSTB, CAI, JWT C2/ECU, 3in B-pipe, UR UDP, nitrous
Best ET: 13.57 @ 99mph
Nismo87SE is offline   Reply With Quote
Old 11-29-2005, 03:40 PM   #3 (permalink)
Baby Blue VVL
fpr?
VVL?
IX MR?
A race????
Old 11-29-2005, 09:14 PM   #4 (permalink)
808 SE-R MAFIA
what do your plugs look like? have you checked your fuel lines for leaks? Have you checked the TPS voltage to make sure its within spec? Is the ECU throwing any codes? Has the motor been compression tested? Go to the dyno and get an a/f vs rpm printout to see if it is running rich all over or just in the VVL. Its its all over then you can fix it with an fpr and tuning i think. 16 MPG is pretty bad, i get around 22 - 24 in my sr20ve. Not sure what else to say, i dont have any experience with the sr16. good luck.
sr20sleeper is offline   Reply With Quote
Old 11-29-2005, 10:26 PM   #5 (permalink)
My guess was the fpr too.
Dan_93SER is offline   Reply With Quote
Old 11-30-2005, 01:55 AM   #6 (permalink)
agent camel toe
u need to get her tuned on the dyno..i was getting 180 or so then after tuning w/ a w.b. it went up to 280 or so
nyce1s.com
R.I.P. RESPECT SR.
93 p10 jdm de--for sale
96 b14 det--for sale
89 formula--sold
next up is a minivan
Old 11-30-2005, 08:22 PM   #7 (permalink)
808 SE-R MAFIA
what program are you running by the way? a sr16ve ecu? a custom DE ECU reprogrammed for the sr16? a modified sr20ve program? What size injectors is it set for?
Old 12-01-2005, 10:43 AM   #8 (permalink)
NeoVVL Egg
Im running a modified de ecu with sr20ve programmed for 333 injectors....the sr16 and sr20ve have the same injectors.
John
Old 12-01-2005, 12:49 PM   #9 (permalink)
agent camel toe
bro do u have a fpr?if so pm me and ill have el genio tune it..with a wideband of course
Old 12-02-2005, 10:23 AM   #10 (permalink)
NeoVVL Egg
I have just the fuel pressure regulator that comes with the sr16 on the fuel line...i still have to get a fuel pressure gauge to see what shes reading at.
My question is this.....do the sr20ve and sr16ve have different fuel maps??
Like i said, im currently running an sr20ve program and i previously had an sr16 program and i still ran just as rich.
Old 12-02-2005, 10:37 AM   #11 (permalink)
Just LTrain Again..
As per sr20sleeper's advice, did you check the TPS voltages?
VVL
'94 SE-R w/ VE ....sale pending
"Relax, alright? My old man is a television repairman, he's got this ultimate set of tools. I CAN FIX IT."
VVLtrain is offline   Reply With Quote
Old 12-02-2005, 12:01 PM   #12 (permalink)
SR20VE FREAK!
I'm getting pretty bad gas mileage myself - not sure if it's as bad a s 16 mpg - but my car's been a gas-guzzler ever since the swap -
However, I also have a few things to blame - such as my current DE ECU..
"Try me on a bad day" -
Fraychild is offline   Reply With Quote
Old 12-02-2005, 08:25 PM   #13 (permalink)
Im getting really bad gas mileage too. like 10 or so miles to the gallon. pretty ridiculus
sr20ve beast is offline   Reply With Quote
Old 12-05-2005, 10:54 PM   #14 (permalink)
Check the TPS voltage! .50v i believe
93' White SE-R. B14 wheels, sunny turn signals, tsuru taillights, NX2000 brake upgrade, Axxiss ultimates...
coolblackser is offline   Reply With Quote
Old 12-05-2005, 11:47 PM   #15 (permalink)
convention track slut
Trader Rating: 28 (100%)
I ran my car at 100 mph for 65 miles. I have beat on it this whole tank. I will still get 24. 180,000 miles on the motor too. I got 30 on the last tank! I bet if I baby it I can get 32!
05 Tacoma 4x4
91 White SE-R built de coming up
nissansr20nx is offline   Reply With Quote
Old 12-06-2005, 01:46 AM   #16 (permalink)
Boost Addict Anon Member
That is insanely low mileage.... My fpr broke (pressure always up) on my turbo setup and was just dumping fuel to a point where it wouldn't idle at all and I still got 21 mpg.
2k1 Sentra SE "Stock"
wnwright is offline   Reply With Quote
Old 12-06-2005, 02:08 AM   #17 (permalink)
agent camel toe
i have a spare ve fpr if u need it..
Old 12-06-2005, 03:19 PM   #18 (permalink)
why would the tps voltage be a factor in the bad gas mileage saga?
Old 12-06-2005, 09:15 PM   #19 (permalink)
dont know, thats what andreas told me i checked it and it was at .47 "not in spec" and changed it to .50 the cars gas mileage shot back up in the high 20's from 19
