if you want a daughter board solution try looking into what calum and or setzer on this forum have avalible, i have a sezter tuned calum ecu in my car now it runs pretty nicely. the one thing that i would look in to is the stock 16 ve ecu might be tuned to run on diffrent fuels than that are available in the states. but other than that if you did it with a sr16ecu harness you could have your stuff all stock like including the vvl activation, but at the stock rpm witch i hear is kinda high to really take advantage of the cams. just a couple thoughts on that, ive got the sr16 cams in an sr20 and it runs really nicely, check out setzer or calum about the daughterboards.
looks like its got a bad sun burn.
