Not without modifications. The GTiR block uses larger bolts for the head to block portion, plus it may not have the aditional oil passage that th head needs. So to answer your question as simply as you stated it in one sentence: Nope.
~Ryan
1992 NX2000 Hardtop
1989 B12 AWD wagon
Originally Posted by abelsgotspeed
Originally Posted by chriscar
