Old 12-13-2005, 12:18 AM   #1 (permalink)
Best Clutch for a VE
What do u guys think is the best clutch setup to use on a VE ...also the best flywheel
mr.vvl is offline   Reply With Quote
Old 12-13-2005, 12:27 AM   #2 (permalink)
Pulsar 20V
Jun Flywheel + cusco clutch
PennyFan is offline   Reply With Quote
Old 12-13-2005, 12:36 AM   #3 (permalink)
I use an ACT HDSS.
Old 12-13-2005, 12:44 AM   #4 (permalink)
SE-R BUM
I had ACT and hated the feel of the clutch, you have to hit the wieghts for that setup... it was extreamly hard for me to shift gears... i grinded the gears a lot and now something is wrong with themy trans... i just bought a clutch kit for a 2001 B15 from autozone hopefully its just as good as OEM setup from the dealership
(New all motor) 96 B14: Sr20VE JWT ECU, Msd switches, ES mounts and Bushings,2.25 stomung exhaust, KYB shocks, Eibach Sportlines, NGK Plugs/wires, ACT HDPP & Street disc, Hotshot CAI & Headers gen. 5,N-1 intake mani/TB,thermo spacers, B15 LSD trans, AEB1 GEN. 1 Header...
Old 12-13-2005, 12:45 AM   #5 (permalink)
what you guys think about the JGY clutches and flywheel
Old 12-13-2005, 12:45 AM   #6 (permalink)
convention track slut
Trader Rating: 28 (100%)
Those autozones clutches are pretty good. I have beat on one for a couple years I like it!
05 Tacoma 4x4
91 White SE-R built de coming up
nissansr20nx is offline   Reply With Quote
Old 12-13-2005, 12:59 AM   #7 (permalink)
My HDSS with all new parts is smoother and easier then my old stock clutch. If you grease it up right the HDSS is smooth as butter.
Old 12-13-2005, 01:34 AM   #8 (permalink)
Slowing down.....
ACT HDSS, Fidanza flywheel, B15 HD disc... revs quick, hits hard, reliable. Pretty easy to drive everyday. The 2 things that helped were antiseize lube applied to the input shaft housing where the t/o bearing slides and a new clutch cable.
blusteelsr20 is offline   Reply With Quote
Old 12-13-2005, 02:19 AM   #9 (permalink)
the spookman
im using a KV clutch kit but I def. need something stronger.
05 Legacy GT
93 NX2000 w/VE
(\__/)
(O.o )
Old 12-13-2005, 02:35 AM   #10 (permalink)
1.6 3/25/06 VE 7/11/06
Trader Rating: 25 (100%)
right now i have a jgy 11lb flywheel and act pp and street disc. havn't put the motor in yet so can't tell you have it feels
bj200sx is offline   Reply With Quote
Old 12-13-2005, 03:45 AM   #11 (permalink)
I'm running an 11lb flywheel, stock pressure plate, and carbon/kevlar clutch I got at the local clutch/brake supply store. Works awesome, though the clutch does heat up quickly and become extra grippy. Takes some finesse to couple that tendancy with a lightweight flywheel and accelerating from a stop.
hachi_boroku is online now   Reply With Quote
Old 12-15-2005, 03:14 AM   #12 (permalink)
anyone using centerforce or exedy organic?
How well will an Exedy OE replacement hold up w/ the VE?
kato is offline   Reply With Quote
Old 12-15-2005, 06:07 AM   #13 (permalink)
i love b13's !
Trader Rating: 22 (100%)
depends on the power up plan on making. a hdss will start to slip once u break the 220whp mark (so ive been told).
stratton.
im back.......
Old 12-15-2005, 06:43 AM   #14 (permalink)
stratton.
We made over 400 whp on one of our turbo cars and had no issues with this set up. IMHO I think the HD PP with the street disk is a perfect set up for a NA car.
-Rob-
Get ready for a big SE-Rprise
Old 12-15-2005, 04:17 PM   #16 (permalink)
Is an SE-R/VE a VE-R?
Not up yet, so can't tell you how it feels yet, but in the car ('93 B13 & VE) is one of the Clutchnet setups. I think the flywheel is 12 lbs or so; disc looks half again as tough as various aftermarket supposedly HD stuff I looked at. I bit, as the group buy organizer had a good reputation and Clutchnet builds a LOT of tough stuff, and the setup was significantly less than the alternatives. Again, the build quality from my experience (owned my own shop) was superb. I'll let you know in 20k how it held up :-). Group by going on now, if Goneturbo is the same organizer, step up and get yourself some great hardware. ASK THEM what they recommend.
Old 12-15-2005, 04:42 PM   #17 (permalink)
jgy 6 puck works great for me, but i do have minimal mods. still, pedal feel is just a bit over stock if you lube the shaft up right (lol), and you'll need to do the copper reducer trick. i love it, way thumbs up jgy! justin..
Smittysser is offline   Reply With Quote
Old 12-15-2005, 05:18 PM   #18 (permalink)
WASHED UP
My HD with street disk slipped on my ve.I think it was due to 8-9k launches on slicks.HD with 6 plucks holds the 8-9k launches.But for street a disk is best.
Old 12-16-2005, 11:55 AM   #19 (permalink)
Forgot to mention - regardless of whose pp you end up with, the stock arm flexes even more with increased pp spring tension; Andreas Miko does a fix; he'll need your original as a 'core' but it's a worthwhile fix for clutch adjustment and feel and a necessary one given stock ones do break. His mod solves the problem.
Old 12-16-2005, 10:51 PM   #20 (permalink)
SE-R BUM
i greaced up the throw out bearing and shaft and still got the same stiff feeling...
