Old 12-13-2005, 11:09 PM   #1 (permalink)
Boosted SR20VE
valve adjustment on sr20ve
Hello,
any of you can give me:
the stock valve clearance for the sr20ve?
is there any "performance" clearance for valves or cam angles?
regards,
fonta
www.fontaracing.com
fontaracing is offline   Reply With Quote
Old 12-14-2005, 02:21 AM   #2 (permalink)
done
cam to rocker on the small lobes is .015mm (.006")
Old 12-14-2005, 07:33 AM   #3 (permalink)
Boosted SR20VE
any ideas about the big lobe?
Old 12-14-2005, 03:21 PM   #4 (permalink)
done
you dont adjust the valve lash for the big lobe. you adjust both sides of the rocker arm so that both small lobes are even. the big lobe on the rocker has a hydraulic lash adjustment and oil pressure with spring that keeps the rocker against the big lobe on the cam. this also keeps pressure on the shims on the springs so that they dont fly out.
