Old 12-17-2005, 02:37 AM   #1 (permalink)
No D E T.
Trader Rating: 18 (100%)
VE Valve Shims
I want to know the size range for the VE valve shims. I was checking a head and i think the smallest was about 2.67mm, the largest was 2.81mm, thats just .01 larger than the smallest DE shim. (DE's go from 2.80-3.20)
What am i supposed to do after putting my head back together and re-checking clearance? Have my machine-shop mill some thick DE shims to size?!
Does Mossy have the ability to get VE shims? they probably list at about $10ea.
Jonathan Schultz
1997 200SX SE-R U13 Swap
2005 Toyota Avalon Limited
honkeybizkit is offline   Reply With Quote
Old 12-17-2005, 05:31 PM   #2 (permalink)
VVL SE-R
the shims are super expensive. I'm pretty sure the shim ranges are very similair to the de. When i had a valve job done I had the machine shop set the valve lash. I know he did it with what he had. So its possible he may of shaved the valve's a bit on some. What i do know is it used to tick bad, now it's quiet as ever.
matt20v is offline   Reply With Quote
Old 12-17-2005, 06:29 PM   #3 (permalink)
Gone!!!
Trader Rating: 24 (100%)
Available valve shim sizes are in the "Service Data and Specs" section in the back of the "Engine Mechanical" section of the factory service manual. If you need me to list them I can. They go from 2.00mm(.0787in)-2.98mm(.1173in)
93 NX2000 VE
08 Frontier Se
BORNGEARHEAD is online now   Reply With Quote
Old 12-17-2005, 11:17 PM   #4 (permalink)
No D E T.
In the back of my FSM (b14) it shows the shims from 2.800-3.200... What FSM are you looking at?
Old 12-18-2005, 12:20 AM   #5 (permalink)
Gone!!!
Hmm. The numbers I posted are from my 93 manual.
Old 12-18-2005, 12:39 AM   #6 (permalink)
No D E T.
AHA! the 2.00-2.98 are for the B13 GA16DE, not the same diameter shim as they sit on the lifter above the spring/retainer.
thanks though.
Old 12-18-2005, 02:16 AM   #7 (permalink)
Gone!!!
Ya, I sometimes have a problem thinking before I speak but I'm glad I could help find the info.
Old 01-01-2006, 07:41 PM   #8 (permalink)
I have never heard of a mechanical valvetrain using shims....Are you sure that these VE engines use shims?
MackDad is offline   Reply With Quote
Old 01-01-2006, 09:27 PM   #9 (permalink)
I like the boost!
shims on the valve springs, not on the lifters.
turboAZ2 is offline   Reply With Quote
Old 01-03-2006, 03:18 AM   #10 (permalink)
So just to clarify, the thickness of the shims located on top of the valve springs under the rockers range from 2.8 to 3.2mm in thickness, and the clearance between the rockers and the low cam lobes needs to be 0.15mm ?
Sabre 200 Gxi is offline   Reply With Quote
Old 01-03-2006, 09:59 AM   #11 (permalink)
No D E T.
the shims cannot be 2.8-3.2 as i have some in the 2.6's in my head. I still never recieved an answer.
Old 01-03-2006, 10:34 AM   #12 (permalink)
Okay it seems those are for the B14 which I presume is a RR motor.
What do you have?
I'm also interested in the VE ones if anyone has them...?
Old 01-03-2006, 10:42 AM   #13 (permalink)
I think your original suggestion of milling the DE shims smaller to get your desired lash would be perfect.
So if you can find the correct clearance or lash then you're sorted. (And you will answer my question simultaneously :-) It seems to be 0.15mm though...inconclusive so far.
Old 05-21-2006, 11:53 PM   #14 (permalink)
boost junkie!
so de shims work there just too tall, so you'll need to grind them down a bit?
91 SENTRA se-r
dead SR20VE-T
"I stays breakin stuff"
For sale!
http://www.sr20forum.com/mid-atlantic-east/161787-im-selling-everything.html
check out www.ecdrift.com for you sideways guys!
blackb13se-r is offline   Reply With Quote
Old 05-22-2006, 03:41 AM   #15 (permalink)
N14 Sr20ve + T
derm's Avatar
0.2mm on intake cold
0.3mm in exhaust cold
derm is offline   Reply With Quote
Old 05-22-2006, 07:57 AM   #16 (permalink)
NEOB11VE
Thats's what i needed to know, my VE head is thicking bad too. This specs are for the VE shims, right?
NEOB11 SR20VE
13.9@99.9mph-2.25 60ft
B11VE (VVL FUN)
macakin is offline   Reply With Quote
Old 05-22-2006, 08:11 AM   #17 (permalink)
N14 Sr20ve + T
derm's Avatar
Yip it is
