hence telling him to measure the bearing clearances....
we just try to bolt on everything and see it move or not only
even if you are just putting everything together to see if it fits, you still need to measure the bearing clearances and install bearings... unless you want to wreck both the crank and the block.
you need to find the journals that came with the block. If you don't you are going to spend a lot of time and money trying to get this to work and your motor could still potentially fail
here is what is wrong with your block right now, regardless of the crank and clearance:
you have forced journals into a block that were never supposed to fit together. The metal around the journal shoulders and the main webbing is now warped. Especially if you torqued the journals down to specs. You need to inspect your block carefully for sharp edges and metal shavings. you also need to look for any grooves the incorrect journals could have cut into the block.
Only after that can you start to worry about clearances. if you messed up your block the clearances won't mean a damn because as the motor is spinning the journals aren't seated properly.
That BLOCK is specific to only 1 set of Journals. Nothing else equals and nothing else is a substitute. your only mission right now is to find the original journals
