Old 12-19-2005, 12:12 PM   #1 (permalink)
Noise from gearbox
hi ppl ...i'm getting a chattering noise when my clutch pedal is up and i'm at stand still but once i press the pedal dowm the chattering stops!!!
this only started happening since i installed a new clutch,pp and lighten flywheel.
what can be causing this ???
mr.vvl is offline   Reply With Quote
Old 12-19-2005, 12:19 PM   #2 (permalink)
seen the light
Any Vibtration along with the noise? Hydaulic cluth or cable? define chattering and exactly where you think it stems from
HP11 VE - SOLD
BCNR33 GT-R - SOLD
HP12 20V family sedan.
S14 all motor track coupe in the pipeline
madandy is offline   Reply With Quote
Old 12-19-2005, 12:34 PM   #3 (permalink)
nikki likey boost...
prolly a release bearing
-n-
soon to be current driver:
93 240 w/ SR20VET ... tons o fun
remember..... KEEP IT SIMPLE STOOPID
inktdevil is offline   Reply With Quote
Old 12-19-2005, 02:38 PM   #4 (permalink)
Technician and Enthusiast
Yeah, your TOB is shot and is causing feedback through the clutch cable and to the pedal. The pedal prolly vibrates too huh.
Coheed is offline   Reply With Quote
Old 12-19-2005, 03:00 PM   #5 (permalink)
12's Is So Last Summer!
urbanracerone's Avatar
Trader Rating: 36 (100%)
well according to you location and your down in Trinidad, ask some of you fellow trini peeps to help find you a new tob *** call you later leo.
turbo SER's are so 90's!
Tarmac Motorsport LLC
89-Florida St
farmindale NY, 11735
631 390 9410
NYC's Fastest Nissan's
urbanracerone is offline   Reply With Quote
Old 12-19-2005, 03:22 PM   #6 (permalink)
I have a brand new OEM release bearing I could sell you.
Audio Piper is offline   Reply With Quote
Old 12-20-2005, 03:11 AM   #7 (permalink)
throw-out-bearings make noise when they're engaged. it sounds more like a bad tranny, perhaps a bearing on the input shaft that was dampened before with a heavier flywheel.
hachi_boroku is offline   Reply With Quote
Old 12-20-2005, 12:19 PM   #8 (permalink)
its a hydraulic clutch ....and the noise only occur sometimes ....we'll i'll change the bearings and let u know if that worked...the noise is like a cha cha cha cha noise...!!!
Old 12-20-2005, 04:51 PM   #9 (permalink)
SHIFT_Damn thats fast
DID YOU CHECK THE TRANNY FLUID? This is exaclty what happend to my friends sentra xe. The fluid was almost completly gone and everthing was just chattering togeather, he put more fluid in and it stopped.
RIDES::
07 Legacy
93 SER DE-T (Night warrior)
93 nx (wrecked twice by my ex) DEAD
01 cbr
twyztidmind is offline   Reply With Quote
Old 12-20-2005, 07:09 PM   #10 (permalink)
done
This sounds just like the same noise that my trans was making before the 6 puck splines stripped out ( which i got warrantied). I replaced the clutch, throw out bearing and even changed the trans. 3 days later it started to get louder again... still doing it now too...
If you let the pedal out very softly and easy it will not make noise, very fast and it chatters..
i have no idea
Here's my current setup...
2001 B15 LSD trans
ACT 6 puck with XT PP
Jun 10 lb flywheel
Stock Throw out bearing, have tried 2 now and no change.
Old 12-21-2005, 06:38 AM   #11 (permalink)
if the noise goes away when your foot is lightly on the clutch pedal, it will be release bearing (throw out bearning). Every single time i've replaced clutch i use a new release bearing and they last about 25,000k's before they start making noise again, very annoying to say the least.
i'm also using a hydraulic setup from a P10 primera (slave cylinder, with gti-r master cylinder and pedal) in my N15 Pulsar SSS (SR20DE) and that didn't fix the problem. So doesn't matter if you have cable or hydraulic setup, it can still happen.
CoZZm0 is offline   Reply With Quote
