Old 12-22-2005, 02:24 AM   #1 (permalink)
differences between VE and DE
hey there,
I was just wondering what are the differences components-wise between the VE and DE?
Its just that im doing as much research on the VE to decide the usual question of VE vs worked DE.
The reasoning behind this question is that because im in Australia, and say i have to replace a part on my VE, like a dizzy cap or water pump. Usually, with my current DE, i can just ring my local Nissan dealer and order one in. BUT.....
If i have the VE in, i can't really do that can i? haha
or can i?
so, thats basically what i want to know.
If i do have to replace a part on the VE can i use a DE part, or will i have to 'overnite ship it from japan?' haha
cheers
EVLSSS
EVLSSS is offline   Reply With Quote
Old 12-22-2005, 02:34 AM   #2 (permalink)
Originally Posted by EVLSSS
hey there,
or can i?
cheers
EVLSSS
Use the DE dist. and just cut the bottom leg off of it. Its really not an issue. Just transfer everything from the DE onto the VE.
Old 12-22-2005, 08:50 AM   #3 (permalink)
Some of the stuff are different. It has more in common with the low port DE than the high port though.
It would be great if there was a sticky listing the identical and the interchangeble and the recommended parts in the VE.
Sabre 200 Gxi is offline   Reply With Quote
Old 12-22-2005, 06:22 PM   #4 (permalink)
Neo'ed
If you need parts, you can message GMC on pulsar.org.au he is able to import direct from nissan japan
Old 12-22-2005, 08:13 PM   #5 (permalink)
the most closely resembling motor to the de is the rr motor found in the newer g20's and primeras. things like the water pump, dizzy, idle control valve and other miselaneous parts on that motor are the same found on the ve. i would be more concerned of a water pump going bad than any other thing... but the water pump from any year fwd sr20 will work. the ve's block is mainly a rr block, just with a few extra holes. so if anything were to really go wrong.. you would be able to find rr motor fairly easy and make it work, or use the some of the internal parts.
THE VE-T IS ALIVE.
-92 sentra vvl-t 470whp...385tq. 24lbs.
-98 sentra SE/ sr2ve powered.
-2005 c230 kompressor.
-2006 Lancer Evolution 9 MR.
http://images.cardomain.com/member_i...66_28_full.jpg
your local asshole.
LanceSR20 is offline   Reply With Quote
Old 12-25-2005, 08:25 AM   #6 (permalink)
yes, i second that notion. It would be VERY helpful!
thx for the replies ppls.
garyd-thx for that, its good to know.
cheers
EVLSSS
Old 12-27-2005, 01:33 AM   #7 (permalink)
Neo'ed
also search for project nugget on pulsar.org.au it has a lot of info from my conversion
