Old 12-23-2005, 09:19 AM   #1 (permalink)
VVL Junkie
Can the Greddy E-Manage control VVL?
E-manage has the built in vtec controller. Can it be used to control VVL?
Nissan Pulsar Gti-R'91 - under constuction (sr20vet in the garage)
DeNismo is offline   Reply With Quote
Old 12-23-2005, 09:25 AM   #2 (permalink)
TEAM 15 FTMFW!!!!
IIRC VVL has two solenoids to controll the exhast and inlet seperatly.. whereas the honda only has 1 solenoid..
also the way they switch could be different.. does the honda switch to earth or a positive? and does the VLL solenoids do the same?
Raceworx is offline   Reply With Quote
Old 12-23-2005, 09:40 AM   #3 (permalink)
VVL Junkie
I thought about it.
And I think, that it it is impossible too.
Old 12-23-2005, 09:46 AM   #4 (permalink)
merely a flesh wound
chriscar's Avatar
I don't know anything about the emanage, but niether of the points you bring up would be an issue. Both cams can be switched at the same time from a single relay, and they can be wired to work by either switching positive or negative.
Old 12-23-2005, 09:47 AM   #5 (permalink)
The Super Mechanic
supercowboy's Avatar
yes it can control it. I recomend using a relay. Ive done it and others have to. You would have to open both solenoids at the same time.
06 monaro cv8
91 ser 311whp@15psi
CT SUPERHERO
DO YOU KNOW WHO I AM!!! I THOUGHT SO!!!!
supercowboy is offline   Reply With Quote
Old 12-23-2005, 09:53 AM   #6 (permalink)
VVL Junkie
Interesting. Because most of people use 4900/4900.
Old 12-23-2005, 01:11 PM   #7 (permalink)
The Boost Bear..Rawr!
Zexel's Avatar
Trader Rating: 42 (98%)
IIRC, I read that the E-Manage Ultimate can open the switches at two different points. I may possibly be incorrect though.
Corey
Zexel is online now   Reply With Quote
Old 12-24-2005, 05:46 PM   #8 (permalink)
TeSeR36
yea i heard that the ultimate can activate switches
02 Silver Civic Si(totaled it) (worst week ever)
93 blk SER(DET) SOLD!!!(well kinda)
94 AzRED SER(gtir DET)(traded for 200sx ser)
96 200sx(uk motor)(hit then sold )
94 AzRED SER(SOLD!!!)
93 altima (DD)
92 BLk GMC typhoon(New Project!!!)
mickeyj36 is offline   Reply With Quote
Old 12-26-2005, 10:48 AM   #9 (permalink)
VVL Junkie
Does it effective enough as two-channel control like Greddy MSS does?
