Old 01-01-2006, 06:25 PM   #1 (permalink)
thegost
ve-t ?'s
well if u guys read some of my posts i really dont care about having a manual tranny. but if i wanted to throw a turbo on a ve with an automatic will it hold up. im not looking for a crap load of power just the excitment of a project. and do u have to lower the compression on the ve to turbo it?
(\__/)
(='.'=)This is Bunny. Copy and paste bunny into your
(")_(")signature to help him gain world domination.
walabe25 is offline   Reply With Quote
Old 01-01-2006, 07:36 PM   #2 (permalink)
done
I have done a DE-T on a 99 P11 and it was an AT. It had S3 cams, a gt2871 and held 15psi and even a few 20psi boost spikes and never skipped a beat. 15 psi all the time seemed ok. probobly high 200's maybe 300whp.
Old 01-01-2006, 08:13 PM   #3 (permalink)
retired
You don't have to lower the compression, just be super careful and do things right if you don't.
NOT SR20 POWERED
needs.
Old 01-01-2006, 09:33 PM   #4 (permalink)
NA>Boost
what would be considered "safe boost" on a stock compression VE...
SR20DEEP CT
I am Too Slow to LOCK IT UP
sr20gti-r is online now   Reply With Quote
Old 01-01-2006, 10:10 PM   #5 (permalink)
Forever slow
pm andreas miko, he wrote the book on sr20's. he'll know the answers to all your questions.
#1 -1993 Classic XE SOLD
#2 -1992 Classic SE-R SOLD to Autoxse-r
#3 -1993 Classic SE-R SOLD
-2002 GMC Sonoma 4.3 V6 - The DD
-1988 Kawasaki EX500 - The newest money trap
Is it Possible to use a TMIC and FMIC?!?
intiractive is offline   Reply With Quote
Old 01-01-2006, 10:45 PM   #6 (permalink)
retired
I guess it would depends on alot of things, The problem isn't so much the compression but the super weak bottom end, My opinion is that with proper tuning you will run into problems with the weak bottom end before you run into compression issues.
Old 01-02-2006, 12:15 AM   #7 (permalink)
Forever slow
how is the bottom end weak? is has the same as a sr20de.
Old 01-02-2006, 12:21 AM   #8 (permalink)
retired
The pistons are pathetic and the rods are thinner. Have you ever seen the ve bottom end? There should atleast be pics of the piston on the forum some place.
Old 01-02-2006, 01:44 AM   #9 (permalink)
VE'ed
Trader Rating: 33 (100%)
i'd like to see a pic of that too~
Mautai916@yahoo is offline   Reply With Quote
Old 01-02-2006, 01:53 AM   #10 (permalink)
retired
Ok I got a new camera for xmas let me go find a ve piston.
Old 01-02-2006, 02:06 AM   #11 (permalink)
done
The VE rods are the same thickness from the wrist pin to the big end. They are about half the size of a DET rod. Think Factory Honda B series bottom end
Old 01-02-2006, 02:17 AM   #12 (permalink)
retired
Piston Pics,
http://www.sr20forum.com/img/showgal...00&ppuser=3302
Edit: Add
Some good pics in Zexel's post
http://www.sr20forum.com/sr20ve-sr16ve/138273-project-ve-build-up-begins.html
Old 01-02-2006, 11:56 AM   #13 (permalink)
Her 1st track day in 2017
Fosters's Avatar
Trader Rating: 41 (100%)
Don't forget most of the common VE's have a 4 counter-weight crank and they don't have the girdle compared to the DE's.
That's why it has been posted to run the DE crank, DET rods, etc when boosting the VE.
Josh
'95 G20 - daily driver
'92 NX2000 - Money Pit
Izzy's Cages---------------Custom Steel---------------G Spec
