Old 01-10-2006, 04:46 PM   #1 (permalink)
808 SE-R MAFIA
fuji buzzing
My fuji header buzzes quite a bit between 2000 and 4500rpm on my classic. Just put it on about a month ago. Thinking of using some header wrap to pad the area that it rattling against the crossmember. any other suggestions? I know others have had this issue also. thanks
nate
sr20sleeper is offline   Reply With Quote
Old 01-10-2006, 05:23 PM   #2 (permalink)
llaprad1's Avatar
nate
I used the wrap that came with the header. Wrapped around the ft sway bar. That did the trick.
No buzzing anymore.
Louis - 1991 Nissan Sentra SE-R w/SR20VE
09 SR20 Calendars available NOW!
Limited Time: SR20VE Stainless Steel Badges
llaprad1 is offline   Reply With Quote
