i tried searching for some info about swapping it but couldnt find anything.
what does it take to put into a b13? do you have to mod it similar to a b15 tranny? which axles fit it? is it as strong as a b15 tranny? at least stronger than the standard b13 trans?
I'm not sure if the SR16VE tranny comes from only the N15, but when I installed an SR16VE + SR16 trans into my buddy's NX2000, the tranny bolted in with no modifications. Just had to reuse any existing bracketry from the B13, and the speed sensor. The B13 axles popped right in.
I don't know if its any stronger than a normal B13, but I highly doubt it has the strength of a B15.
Chris '91 VVL-powered SE-RSOLD
VE! Koni/GC's, Apexi, Progress, Crown, Carbotech, ACT, GSpec, Fidanza, VDO, Nismo, and other goodies '04 G35 6MT '99 CBR600 F4
i may be mistaken, but i swear i saw Mr. Miko state that a sr16ve and lsd b15 trannys are one and a same? correct me if im wrong
edit: i believe i am wrong
I said the N16 tranny and the B15 tranny are the same
The B13-B14 and N15 tranny are the same
Does anyone know the gear ratio differences of sr20's? It would b really good info and should be archived. I got teh new post and question already posted but noone has responded. Thanks
"A couple of Nissan Sr20's will pull a premium one week before race wars." (Johnny Tran, fast and furious) LOL
The P11 tranny. 1st 3.333, 2nd 1.955, 3rd 1.286, 4th, .926. 5th .756 and Finsal drive 4.176.
The SR16VE is 1st 3.333, 2nds, 1.955, 3rd 1.333, 4th .975, 5th .756 and Final drive 4.444
The SR20DE tranny 1st 3.063, 2nd 1.826, 3rd 1.286, 4th .975, 5th .756 and Final drive is 4.176
The B15 tranny 1st 3.333, 2nd 1.955, 3rd 1.286, 4th .926, 5th .733 and Final Drive is 4.444
This means the P11 1st and 2nd gear is a little slower than the SR16VE but quicker than a SR20DE. It has the same 3rd as a SR20DE. The P11 4th and 5th gears are longer than a SR20DE.
