Old 03-17-2002, 07:11 PM   #1 (permalink)
Track addict
It's alive
The VE fired right up. A bit loud from running just the HS DE primary but sounds like a very solid motor. Still have to hook up VE solenoids using the MSD RPM switches but that should be a easy compared to rewiring the VE distributor connector to accept the wires from the external coil and ignitor. I had JWT reprogram the ECU for the larger injectors and MAF and also remove the EGR temp sensor. The only connector I didn't plug in was the IACV Air Regulator which is not on the VE motor. It may be specific to the 94 and earlier DE's but not sure. There is a IACV AAC Valve and a IACV FICD Solenoid that I hooked up using the connectors from the VE harness. Other connectors used from the VE harness were the MAF, water temp sensor and distributor. Everything else was plug and play using the DE harness. All I need to get it road worthy is a new header. I hope HS completes development soon. I'm getting real itchy now.
Jim Schumacher
My 240
Shoes59 is offline   Reply With Quote
Old 03-17-2002, 08:34 PM   #2 (permalink)
Retired VE Owner
YEAHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!
So you got your ECU back? What RPM cutoff did they program for? Why did you have them remove the EGR temp sensor?
Did you use the DE throttle body? How did that work out?
Throw on the DE manifold or header and test it out! C'mon man!!
Chuck Nibbana
Retired VE owner
2005 BMW M3
CNibbana is offline   Reply With Quote
Old 03-17-2002, 09:28 PM   #3 (permalink)
Track addict
ECU arrived last Thursday. I didn't specify the RPM cutoff so I'm not sure where it's set. I had them remove the EGR temp sensor cause theres no EGR on the VE and I didn't want a check engine light when the plug on the DE harness had nothing to connect to. I used the DE throttle body and DE TPS with no ill effects. I still have a few things I need to finish before I drive it. Battery is bolted in the trunk but have yet to run the cable, needs new VC gasket etc. etc.
BTW, turns out the offset on UR crank pulley is different just enough on the VE that I'm switching back to the VE pulley to be safe.
Old 03-17-2002, 10:33 PM   #4 (permalink)
Veritas
SERprise In WV's Avatar
Trader Rating: 17 (100%)
Congratulations, Jim! Can't wait to see/hear all about it when she's buttoned up and blazing down the highway.
Greg Perry
Huntington, WV
-'93 SE-R, 12.80 @ 110mph
The car: www.TurboChargedSE-R.com
Great parts at great prices: PowerTechPerformance.com
Old 03-18-2002, 01:57 PM   #5 (permalink)
SR20VE or a T28? I dunno!
Is HotShot thinking about making headers for the VEs???
Sam Bass / 1998 200SX SE-R
Atlanta, Georgia
98SERwTricks is offline   Reply With Quote
Old 03-18-2002, 06:17 PM   #6 (permalink)
Retired VE Owner
Hotshot is already making a header for the VE. It should be available any day now.
Old 03-18-2002, 06:48 PM   #7 (permalink)
Guanaco Tuner
Yeah.. but rumor is that you can only purchase it thru SR20Development...
Old 03-18-2002, 07:19 PM   #8 (permalink)
Jah Rastafari
Trader Rating: 55 (100%)
Well you will be able to get it from me also so lets not spread bad rumors.
Old 03-18-2002, 07:26 PM   #9 (permalink)
Guanaco Tuner
Thats great news to me
Old 03-19-2002, 08:41 AM   #10 (permalink)
Trader Rating: 102 (100%)
Jim, I dont know if this is any different, but I have the JDM Primera motor, which also has no EGR, and I am still using the stock ECU with no check engine light ever. But maybe if you have it reprogrammed for no EGR it will run better.
Keep us posted, I really want to know how it runs once you finish with everything, and get some pics too!!
Old 03-19-2002, 10:38 AM   #11 (permalink)
Track addict
Right now I only have 2 DE harness connectors that aren't hooked up to anything. The EGR Temp Sensor connector which JWT took off the ECU and the IACV Air Regulator connector. The car idles fine without the IACV Air Regulator but I'm hoping I don't throw a light for not having this hooked up to anything.
Also, when using the DE throttle body I elected to bypass the water lines going through it. I recall this being mentioned as a free mod keeping the intake air a bit cooler. The main reason for doing it though is the fact that the fittings on the DE TB were smaller in diameter than the fittings on the VE motor. It would require funky hoses with different size diameters at each end.
Once it's on the road I'll do a comparo. DE with all the bolt ons putting down a conservative 145-150 whp vs. a VE with CAI, HS Header, Fidanza 8 lb flywheel, Quaife TBD and a reprogrammed JWT ECU. Should be interesting.
Old 03-19-2002, 10:59 AM   #12 (permalink)
merely a flesh wound
chriscar's Avatar
I remember doing that on my 87 Mustang 5.0 LX.
Funny story about that car. I had aluminum underdrive pulleys on the Stang, and was chasing a TransAm into this great uphill sweeper by my house when the crank pulley exploded. Uh oh! Everything ran off one serpentine belt, and I lost power steering just as I was about to crank the wheel over. That was fun.
Chris
Old 03-19-2002, 01:25 PM   #13 (permalink)
Did you make a custom CAI? The VE uses a MAF from a Frontier right?
If I went VE I would want a nice CAI, HEADER, Pulleys, JWT ECU and custom exhaust. And a little shot of NOS for that extra ******' ******'!
Old 03-19-2002, 02:33 PM   #14 (permalink)
Track addict
I'm using a HS CAI, a Frontier MAF adapter plate from Place Racing with black silicon couplers and SS clamps from Hose Techniques.
Old 03-20-2002, 07:20 AM   #15 (permalink)
eff Jerome!
Sounds like it's gonna be impressive!! keep up the good work!!
// '06 Scion tC - White with stuff // '03 Subaru WRX 2.5L 400hp- WR Blue - Wrecked // '97 SE-R - Pacific Sun Blue - Sold //
DubuRX is offline   Reply With Quote
Old 03-20-2002, 11:09 AM   #16 (permalink)
Track addict
Those who know me and have seen my car before this transformation can vouch for my attention to mechanical detail. This swap will not disappoint. The goal is to make it look like it came from the factory with the VE motor. Except of course the MSD RPM switches which will be mounted on a clear Lexan plate under the hood where the battery used to be.
Old 03-20-2002, 11:12 AM   #17 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
Let's see some pictures.
1991 Sentra SE-R
The community is here.
Old 03-20-2002, 11:31 AM   #18 (permalink)
SR20's since '97
Yeah JIM get us some DAMN PICS i wanna see I bet
it looks awesome and now your gona have a sick rev range
till about ohh i thnk 8400 RPMS or so Whats the VE Redline
Daryl G.
00 Jetta GLX VR6
02 Jetta 1.8t ( hers )
92 Sentra SE-R
98 Sentra SE ( RIP ) 14.2 NA
94 Sentra SE-R ( sold )
90 CRX SI w/GSR + bolt ons ( sold ) 12sec all motor
QUiKSR20 is offline   Reply With Quote
Old 03-20-2002, 12:46 PM   #19 (permalink)
Track addict
I hope to be done with the wiring this weekend. I'll take some pictures right after it's buttoned up. The problem is I'm not smart enough to figure out how to post pictures. Perhaps I could email some pictures to someone who knows how to post them and they could do it for me. Any takers?
Old 03-20-2002, 01:22 PM   #20 (permalink)
JDM style
i can help you out, just email me the pictures at yonkerzdog@aol.com
- Dan
95 se-r -sold-
03 g35 coupe
DaGenesis is offline   Reply With Quote
