Closed Thread
Old 04-13-2006, 03:55 PM   #1 (permalink)
exxd
retired
Franklin Camshafts Information
Franklin has four stages of VE cams:
Stage 1-Mild
Stage 2-fast road
Stage 3-N1 type
Stage 4-extreme
Here are the specs:
These camshafts are made out of new billets.
They are Located in New Zealand
If you want them contact Adrian from Franklin Cams.
They are ready for sale now and they do accept paypal:receipient.fcam@xtra.co.nz
The springs do not come with retainers you can use the stock VE retainers.
All cams are being run on stock 20ve pistons.
The franklin valve springs should not float the valves until 9600 with the stage4 cams.
There seems to be no *good* dyno sheets at the moment.
Want every possible detail? 16pages have fun:
http://www.sr20forum.com/showthread.php?t=138812
NOT SR20 POWERED
needs.
exxd is offline
Closed Thread
