Old 06-26-2006, 07:44 PM   #1 (permalink)
SE-R Geek / Nissan Tech
friend of a new VE owner
hey guys.......i hate to ask a noob question and i probably deserve to be flamed, but i couldnt find it.
do we use the VE ecu?
can we use the harness it came with, or is it easier to rewire the stock harness?
this is on a 94 SER
thanks! (please, be gentle)
92 SE-R Autocrosser.... too much to list
Old 06-26-2006, 07:52 PM   #2 (permalink)
Luke Pighetti
Taiden's Avatar
this is on a 94 SER
I suppose you could use the VE ecu, but that thing is heavily tuned for the CVT transmission.
You are much better off getting a JWT ecu or a Calum daughterboard (not sure if the 94 lowport was on OBD I or II). You can only use the Calum daughterboard on OBD I B13 ecus.
You might even be better off using your stock Sentra ECU than your VE ecu... But then you need something to activate VVL (summit switch, greddy mss etc)
Old 06-26-2006, 08:17 PM   #3 (permalink)
banned
Trader Rating: 31 (100%)
Not true... Calum does OBD2 now FYI...
Cheers-
Erich
Wicked R is offline   Reply With Quote
Old 06-26-2006, 08:22 PM   #4 (permalink)
The Genesis
if you are going to run a ve ecu, use the sr16ve ecu, way better than the sr20ve ecu.
on a ve setup, i strongly advise against a jwt ecu(many reasons why) Best bet is using the stock ecu with an safc or do what i did and use a calum ecu(best bang for the buck "plug and play" ecu IMO)
tHe iLleSt RiCe is online now   Reply With Quote
Old 06-26-2006, 09:13 PM   #5 (permalink)
Luke Pighetti
Taiden's Avatar
Cheers-
Erich
WOOT!!! this is news to me. all i can say is congrats to the B14 guys.
Old 06-26-2006, 10:32 PM   #6 (permalink)
Gone!!!
Trader Rating: 24 (100%)
The sr20ve will work just fine if that's what you have and need it running. Just remember to use matching injectors and maf.
93 NX2000 VE
08 Frontier Se
BORNGEARHEAD is online now   Reply With Quote
Old 06-27-2006, 02:02 AM   #7 (permalink)
thanks a bunch, guys
Old 06-27-2006, 10:05 AM   #8 (permalink)
welcome to the vvl club. if your de stuff was working fine before the swap you should use it. includes maf/tb and ecu. advance the timing to at least 20*to start with. keep the ve injectors and tune on a dyno with afpr.
Ric
VePwrd 97 Se-r (jwt free)
VqPwrd 07 Fronty
Teal97 is offline   Reply With Quote
Old 06-27-2006, 12:32 PM   #9 (permalink)
Monkey Power
the 94 se-r was still obdI they did not switch to obdII until the 95 model year. I have a stock sr20ve ecu in my ve car. it runs fine but I am sure there are better options for power. I just have not gotten around to making changes yet.
94 se-r 342whp 289lbft @ 15psi
92 se-r sr20ve with N1 cams
http://www.cardomain.com/id/cortrim1
www.southern-shift.com
cortrim1 is offline   Reply With Quote
