Old 06-27-2006, 06:15 PM   #1 (permalink)
VE headgasket info
So I just picked up one of the metal oem VE headgaskets from Greg @ Mossy.
This is a very beautiful headgasket. Better looking quality than a lot of the big name aftermarket gaskets.
Anways... For those of you that have installed these: Do you use an type of spray or tack-up (i.e. permatex red stuff) material on it? It looks as though it has some sort of sealant type material allready formed onto it. I have always used a little bit of black sealant up around the timing chain area just as some extra, but not sure if I really need to use anything at all with this headgasket.
Danny Youngs
stock4door is offline   Reply With Quote
Old 06-27-2006, 06:24 PM   #2 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
No sealant needed.
1991 Sentra SE-R
The community is here.
Old 06-28-2006, 05:47 AM   #3 (permalink)
CAR SLÜT
Nothing should be used on your headgasket. It joins two bare metal surfaces and no gasket goo is required.
When you remove your old one, you will see that no glue holds it on.
N14 Pulsar - 3.5L FWD V6 Manual with some breathing mods
VY SS Ute: Stealth TT LS1 V8 with Tein coilovers, Boyd Coddington 19" Turbines & HKS EVC 6 - Pics
CONQER - R34 GT-R Skyline - Blitz Bodykit, 19" Volk GT-C's, HKS Camp 2 and big cube LSX V8 AWD Manual with twin GT4508's - Pics
iamhappy46 is offline   Reply With Quote
Old 06-28-2006, 09:56 AM   #4 (permalink)
you have to put silicone around the timing chain on the block befour installing the gasket and on the top of the gasket in the same place. I didn't, and oil leaked all over my alternator when the car was running, and then it sprayed onto the header which caused a lot of smoke. It even says it in the service manual. Permitex melts. I used it one time and the block was all red around the head because when it got hot it was leaking out.
Fast200SX is offline   Reply With Quote
Old 06-28-2006, 03:29 PM   #5 (permalink)
VVL SE-R
I just blew my headgasket and I had the factory metal one. I'll be switching back to the regular material when I do it this time. If this gasket is at all like the factory one for the 2.5 altima's and sentra's, they have a very high faluire rate.
matt20v is offline   Reply With Quote
Old 06-28-2006, 03:59 PM   #6 (permalink)
Baby Blue VVL
matt when you say "regulary material one" you mean the standard one that comes with the stock VVL? if so that one is metallic as well. I have two of them and i can pick them up with my big magnetic
VVL?
IX MR?
A race????
Old 06-28-2006, 09:37 PM   #7 (permalink)
The Super Mechanic
supercowboy's Avatar
yes the graphite one
06 monaro cv8
91 ser 311whp@15psi
CT SUPERHERO
DO YOU KNOW WHO I AM!!! I THOUGHT SO!!!!
supercowboy is offline   Reply With Quote
