Old 07-01-2006, 11:35 PM   #1 (permalink)
Luke Pighetti
Taiden's Avatar
Really quick question... right at the end of the swap!
Hey guys, I am literally posting from my garage. I am about 10 minutes away from a complete SR20VE swap.
I have a question. There is one vacuum line remaining, and I have no idea where it goes. It is a vacuum line going from the fuel pump, the nipple is facing towards the passenger side.
What is this, and where does it hook up?
This should be the exact same as a lowport setup... Let me know asap, I wanna hear her purr.
Old 07-01-2006, 11:45 PM   #2 (permalink)
Veritas
SERprise In WV's Avatar
Trader Rating: 17 (100%)
I don't think you mean "fuel pump".
Maybe the fuel pressure regulator? If so, there is a fuel pulse damper (looks like another FPR) on the passenger side of the engine.
Is that what you're referring to?
Greg Perry
Huntington, WV
-'93 SE-R, 12.80 @ 110mph
The car: www.TurboChargedSE-R.com
Great parts at great prices: PowerTechPerformance.com
Old 07-01-2006, 11:48 PM   #3 (permalink)
Luke Pighetti
Taiden's Avatar
No, it's definately coming off the fuel pump.
Big black can on the drivers side. On it there are two small nipples that look like the take vacuum lines. The top one goes to intake manifold, the other I have no idea what it does.
Old 07-01-2006, 11:57 PM   #4 (permalink)
Primera Nut
The fuel pump is in the tank....
Sounds like you are talking about the carbon canister.
My Cardomain page and My website check them out
markbuts3 is offline   Reply With Quote
Old 07-02-2006, 12:03 AM   #5 (permalink)
i'm not sure about even carbon canister, maybe cruse controal..... you should have one line coming up off the trans that doesn't connect to anything. just a breather...
T.S.O.L.
cause4alarm is offline   Reply With Quote
Old 07-02-2006, 12:05 AM   #6 (permalink)
Luke Pighetti
Taiden's Avatar
Oh sh*ts, I guess so. VE swap and I don't know where the fuel pump is.
Any ideas?
Old 07-02-2006, 12:07 AM   #7 (permalink)
Luke Pighetti
Taiden's Avatar
No cruise control or AC or ABS in this VE HI CLE
What ever it is, it's a black can with a line going to a thing that has the line going to the fuel filter connected to it.
Old 07-02-2006, 12:10 AM   #8 (permalink)
is it the thing in that pic that sits below the intake pipe to the right of the line going to the oil seperator?
Old 07-02-2006, 12:23 AM   #9 (permalink)
Primera Nut
Easier to see on mine with it being RHD...
Under the strut bar in the top right corner of the engine bay.
Old 07-02-2006, 12:28 AM   #10 (permalink)
Luke Pighetti
Taiden's Avatar
That's it. It's got two blue lines and one black line going to it. I am trying to figure out where the blue line with the silver clamp goes.
Old 07-02-2006, 12:31 AM   #11 (permalink)
Primera Nut
On mine, the right line goes to the fuel tank. The top left one goes to the vac pipes down the back of the intake (where the EGR solenoid is) and the one under it goes to the intake on the back of the plenum.
Old 07-02-2006, 12:31 AM   #12 (permalink)
eric96ser's Avatar
Trader Rating: 16 (100%)
That goes to the nipple on the intake manifold, just after the TB.
1991 Sentra SE-R
The community is here.
Old 07-02-2006, 12:32 AM   #13 (permalink)
on the intake manifold directly after the throtle body facing the firewall, on the lowport....that's not origonal
Old 07-02-2006, 12:34 AM   #14 (permalink)
Luke Pighetti
Taiden's Avatar
what about the other blue line without the silver clamp?
Old 07-02-2006, 12:37 AM   #15 (permalink)
i got it goin into a y, with one line hitting a egr solonoid, which you don't have...the other goes to the vacume galley thing under the tb that you may not have either....
Old 07-02-2006, 12:38 AM   #16 (permalink)
and i've definately altered those from stock, i was without the egr solonoids on this motor for 6 months till harris sent me some
Old 07-02-2006, 12:47 AM   #17 (permalink)
Luke Pighetti
Taiden's Avatar
i have two choices at the moment...
i can leave it vented...
or
i can hook it up to a Y fitting going to the intake manifold along with that other line
Old 07-02-2006, 12:47 AM   #18 (permalink)
Primera Nut
Well mine is stock (although it's a UK Primera) and that line goes to a Y piece which splits off to the BPT and to the vac gallery bit with the EGR solenoid at the bottom of it.
Old 07-02-2006, 12:50 AM   #19 (permalink)
plug it into the y, assuming there is nothing else unpluged
Old 07-02-2006, 12:57 AM   #20 (permalink)
just a reminder before you turn the key... kus i've done this. the fpr regulates the ammount of fuel being released from the rail, not going into it. so the line with the fuel filter should not be pluged into the fuel pressure regulator.
SEO by vBSEO 3.2.
