My VE head swap how to (picture heavy) + Roller Rocker! - Page 2 - SR20 Forum
Old 07-03-2006, 03:49 PM   #21 (permalink)
P10 pro
Feedback Score: 8 reviews
You do have the correct numbers of links ( 20 rollers) but the dots on the sprocket shoud be between the solids links. Don't worry about the cams being exactly at 10 and 12 o'clock before the tensioner is installed.. The only time you should pay attention to the 10 or 12 o'clock position is when the tensioner is installed and released (popped).
5speed is offline   Reply With Quote
Old 07-03-2006, 03:51 PM   #22 (permalink)
Guanaco Tuner
Feedback Score: 11 reviews
Originally Posted by TUNED200
nice work, got anymore 400 buck ve heads?
We have a roller rocker head for $400
Old 07-03-2006, 03:54 PM   #23 (permalink)
Guanaco Tuner
I see what you mean. Thanks for catching that! I'll update the picture tomorrow. Should be an easy enough fix
Old 07-03-2006, 05:36 PM   #24 (permalink)
Gone!!!
Feedback Score: 24 reviews
Very nice write up. I'm sure once people see how it's done, there will be more people doing it.
92 Se-r w/sr20ve
06 Xterra Off-Road
http://mid-west-nissans.motionsforum.com/forum.htm
BORNGEARHEAD is offline   Reply With Quote
Old 07-03-2006, 06:08 PM   #25 (permalink)
Nissan-oholic!
i wish VE's and VE heads were more readily available in canada.
Great write up! informative!
Lemute is offline   Reply With Quote
Old 07-04-2006, 02:16 AM   #26 (permalink)
Veritas
SERprise In WV's Avatar
Feedback Score: 17 reviews
Nice work, Luis.
Greg Perry
Huntington, WV
-'93 SE-R, 12.80 @ 110mph
The car: '93 SE-R with a VE
Old 07-04-2006, 10:00 AM   #27 (permalink)
sr20ve
very good work
nice write up
keep us posted on performance figures
sr20's is offline   Reply With Quote
Old 07-04-2006, 10:30 AM   #28 (permalink)
AWD owns me
Jaketips42's Avatar
Feedback Score: 12 reviews
Nice work man. I am wanting to do the same thing.
Sporting the GC awaiting EJ20T
____________________________________GC Pilot
Subaru stole me from Nissan
Old 07-04-2006, 10:59 AM   #29 (permalink)
Im all about the 4x4
Feedback Score: 35 reviews
whats the pros and cons of doing this instead of just swapping in a full ve motor?
Here is a List of Items I have for Sale and the Photo and Prices are in this Link Below:
http://www.sr20forum.com/florida/268...ml#post2554270
For Sale:
B14 Wheels
SAFC II - Silver
B14 Welded Transmission
SR20DET Motor
N60 MAF
specalk is offline   Reply With Quote
Old 07-04-2006, 02:12 PM   #30 (permalink)
Guanaco Tuner
Pro's it's cheaper and you can do whatever you want bottom end wise. Con.. it's a little harder than doing an oil change. If you can do a cam swap you can do this.
Luis
Old 07-04-2006, 02:37 PM   #31 (permalink)
ga16*****.com
Feedback Score: 31 reviews
nice write up
1997 200SX SE-R - 280whp & 264tq
"Shut the fu*k up and sit down"
Old 07-04-2006, 02:38 PM   #32 (permalink)
VE'ed
Feedback Score: 41 reviews
and the fac that you have a beefier bottom end, 8 cw crank, and the ability to put DE UR pullies on it with no problems
Mautai916@yahoo is offline   Reply With Quote
Old 07-04-2006, 08:52 PM   #33 (permalink)
so that best combo would be GTI-R bottem end with a VE head? only real thing i never liked about the VE is where the oil filter is located, with my de i can just lightly jack up the passenger side of the car and drail oil and set it back down and from the top change the oil filter..
but from what ive seen most ve heads go for $700 and a compete motor is like $1200-1300
Old 07-04-2006, 11:53 PM   #34 (permalink)
Guanaco Tuner
Best combo would be forged pistons and rods with a VE head I love where the VE filter is. I just turn my wheels all the way to the left and I can just stick my arm in behind the wheel and twist the filter off. The filter has to be there, I believe it'll interfere with the intake manifold in the "old" spot.
Old 07-10-2006, 01:14 PM   #35 (permalink)
From Miami to New York
Feedback Score: 13 reviews
Awesome awesome awesome! Good job on this!
Miss it
http://www.g20.net/gallery/data/500/medium/425Lip3.JPG
2007 Infiniti M35 Sport
Stuff for sale
MSD red wires $55 shipped, RRSR20 New 50lb Top Feed Inj $250, B13 93' MT ECU $70.00shipped
Domiken is offline   Reply With Quote
Old 07-10-2006, 01:21 PM   #36 (permalink)
SerMonkey
Feedback Score: 14 reviews
Tommy Likey....Tommy Want Wingy
1992 Nissan Sentra SE-R
SeRMonkey92 is offline   Reply With Quote
Old 07-10-2006, 02:08 PM   #37 (permalink)
WHP11 CVT M6
Feedback Score: 5 reviews
very nice write up. only thing u could have done different is just drill the block down where the oil hole is supposed to be. u drill straight into an oil gallery and u don't need to use the oil fittings and lines. Just like stock VE.
this can only be done if using a RR block and a VE headgasket. The way u did it u could use a DE headgasket, the metal VE hedgasket gives a little more compression though b/c of less compressed thickness.
I started out with nothing and still have most of it left.
yoshoto is offline   Reply With Quote
Old 07-11-2006, 02:20 PM   #38 (permalink)
Guanaco Tuner
I thought about doing that, since I had a roller rocker block. But this motor is going in my friends car, so I decided not to take a chance. That and I really wouldn't even try doing this without a drill press (which I also don't have). And the way I did it, there is less chance of getting shavings in hard to clean areas. I used the VE headgasket because that's what I had lying around
Old 07-12-2006, 10:20 PM   #39 (permalink)
15642uner
Ricer_X_01's Avatar
Feedback Score: 9 reviews
great write up man! i dont know how i missed this thread earlier.
2001 Sentra SE w/pp 5spd (white)
1992 Sentra SE-R 5spd (maroon)
1996 Grand Cherokee Limited v8 4x4 auto (chargold)
1990 Chevy K1500 4x4 5spd (beige) *Sold*
1993 Sentra SE-R auto (white) *Totalled 5-8-05*
1991 Accord EX dohc 4dr 5spd (white) *Totalled 12-20-03*
Ricer_X_01 is offline   Reply With Quote
Old 07-13-2006, 02:57 PM   #40 (permalink)
Feedback Score: 7 reviews
Seriously, I may def consider this over a turbo setup. Helps I already have a RR in my car
2000 Black Sentra SE w/aPP
turco is offline   Reply With Quote
