My VE head swap how to (picture heavy) + Roller Rocker! - Page 6 - SR20 Forum
Old 06-30-2007, 02:21 PM   #101 (permalink)
Guanaco Tuner
Feedback Score: 11 reviews
You have to run the VE intake manifold. Or you can have something custom built.
Old 07-18-2007, 03:47 AM   #102 (permalink)
Guns kill stupid people
Feedback Score: 9 reviews
Like this......http://www.tweakit.net/shop/product_...roducts_id=120
The shiznite
or this universal one http://www.tweakit.net/shop/product_...roducts_id=121
fro20 is offline   Reply With Quote
Old 07-22-2007, 07:12 PM   #103 (permalink)
ok, since i'm not speaking english so well, i would like to resume and ask some question!
- For the computer: we need to run an aftermarket system like "Calum daughterboard with his VE program" or the SR20VE computer. Right?
- Valve clearance on DE stock block? Valve clearance, no issue. Right?
- DE oil pump fit? De pump WILL work on the VE head with DE block BUT BETTER USE A "VE" PUMP. Right?
Now my question:
- Which block it is? filter not located same place as my SR20DE from my 200SX Se-R 1995
- Roller Rocker? What is that? Is my car had Roller Rocker?
- Wire from the NEOvvl solenoid goes where?
- Do I need a Roller Rocker Block to fit the SR20VE head?
Tanx a lot!
Icitte is offline   Reply With Quote
Old 07-23-2007, 12:13 AM   #104 (permalink)
Read this whole thread and all those q's will be answered. If it is not people have linked other threads to this one contaong the information you seek.
Old 08-04-2007, 05:00 PM   #105 (permalink)
PLAY MY HEAD, MONKEY!
daveracer's Avatar
Feedback Score: 93 reviews
I'd just like to point out something. I was using this How-To to drill my VE head to put it on a DE bottom end. I drilled through the back, then the bottom.....and screwed the 1/8" NPT plug. The plug was blocking almost all of the hole on the back. So i suggest drilling a hole that's higher than that.
Old 08-05-2007, 08:22 PM   #106 (permalink)
Guanaco Tuner
Or you can get a really tiny plug like I did (first one I found). The one I used was about 1/4 the size of the theoretical one listed above ^^
Old 08-06-2007, 12:27 AM   #107 (permalink)
"The Chubby Panda"
Feedback Score: 21 reviews
you have to take out the cams to install the head, or what was your reason for taking them out?
My other NX....is an NX.
Canx2k is offline   Reply With Quote
Old 08-06-2007, 12:29 AM   #108 (permalink)
daveracer's Avatar
I just decided to get the bottom one welded up and the head resurfaced. Costs like $50 and it's done the right way.
Old 08-08-2007, 12:14 AM   #109 (permalink)
b13 bai
yo thats nice
jhope510 is offline   Reply With Quote
Old 08-08-2007, 01:19 AM   #110 (permalink)
Yes Dear.
Feedback Score: 6 reviews
ok, but the new excaliber is out on agust 17th...
Sr20kidD is offline   Reply With Quote
Old 09-14-2007, 07:01 PM   #111 (permalink)
One question. WHy did you go with the RR block instead of a regular de?
Old 09-14-2007, 07:04 PM   #112 (permalink)
Guanaco Tuner
It was for an NA car. And the RR bottom end is way newer and 4CW. We just did the same swap on a Avenir DET and had no problems.
Old 09-14-2007, 07:14 PM   #113 (permalink)
^^^ Ok good to know.
Old 01-24-2008, 12:12 AM   #114 (permalink)
teh jelly belly( . )
Feedback Score: 7 reviews
dont know if you ever check this or if anyone does, but what did you do about the coolant hard lines being RIGHT in the way of the oil fitting for the line we have to run for the oil to the selonoids? The bolt hole on the block RIGHT under that fitting is where that bracket is supposed to go.
1996 200sx SE-R JDM HIGHportsr20de SOLD
2000 G20 auto mellinium JADE chill ride...!
94' G20 VE-t
LucinoSR20de is offline   Reply With Quote
Old 01-24-2008, 12:41 AM   #115 (permalink)
Guanaco Tuner
You don't need to do anything about the hard lines. You can run the oil line around it. Here is a picture from another ve head swap we did.
Old 01-24-2008, 12:52 AM   #116 (permalink)
what hardline is that from? A rr engine? looks like a det.. but that hardline looks a lot different from the det OR the ve ones we have. I just spy the oil cooler as well.
Old 01-24-2008, 12:56 AM   #117 (permalink)
Guanaco Tuner
Thats a "hybrid" one we made to use the DET oil cooler. It's a DET one closer to the block and the outer one is the VE one, you can tell because it has the attachment points for the VE IM. The motor I did this thread for used a full VE water hardline set and did not have any interference issues (like this one) with the oil line.
Old 01-24-2008, 01:01 AM   #118 (permalink)
My ve one doesnt look like that though.... Maybe its not a ture VE one. Hell I dont even know now... it doesnt mount up on the IM like that one does... mine has a bracket in the same spot as the det one... sh*t might be a damn DE one for all I know now... would it help to know my ve is a 97... and not a newer one. Maybe they changed.
Still dont know what Im going t do... just more work... lovely.
Old 01-24-2008, 01:05 AM   #119 (permalink)
Guanaco Tuner
Sounds like you don't have a "real" VE one. It shouldn't be that big of a deal to get it all to work together. You will have to switch to a DE/DET coolant flange/sensor fitting vs the VE one if you dont have the whole set.
Luis
Old 01-24-2008, 01:13 AM   #120 (permalink)
did I also mention Im using an o2 induction manifold.. Ill jsut leave it hanging around back there... just mounted over on the coolant temp sensor housing... I was trying to avoid more work in this temp... Didnt wanna have to pull em all off and hack'n slash em... Ill have to do it anyways. Oh well. Thanks* for your help... Any other issues you had?
wish you had a couple more pics of what yours looked like but ill just fab it up myself.
