My VE head swap how to (picture heavy) + Roller Rocker! - Page 7 - SR20 Forum
Old 01-24-2008, 01:16 AM   #121 (permalink)
Guanaco Tuner
Feedback Score: 11 reviews
Sorry I didn't find better pics. I have a whole VE head and oil line kit sitting in the garage unassembled Once you have everything together, you'll see it isn't too bad.
Old 01-24-2008, 01:44 AM   #122 (permalink)
teh jelly belly( . )
Feedback Score: 7 reviews
HAHA, just kidding on the not being the VE ones. They are the ve hardlines. Im cold and tired. We'll get the girl done soon. Shes gonna scream.
1996 200sx SE-R JDM HIGHportsr20de SOLD
2000 G20 auto mellinium JADE chill ride...!
94' G20 VE-t
LucinoSR20de is offline   Reply With Quote
Old 02-25-2008, 04:34 PM   #123 (permalink)
So has any work been done with using a turbo with the VVL swap?
I'm assuming that i should swap oil pumps for this but which one should i go with?
I'm working with a 96 200sx b14 if spacing is going to be an issue but i wouldn't think it would be.
Nate8888 is offline   Reply With Quote
Old 02-25-2008, 05:55 PM   #124 (permalink)
Broke Ass
jer_760's Avatar
Feedback Score: 12 reviews
Are you wondering about using a VE head or a whole VE motor? If you are using a de/det block and want to use the VE oil pump, you need to use the VE crank pulley and the VE spacer behind the pulley on the crank.
95 200sx
sr20ve
Old 02-26-2008, 10:04 PM   #125 (permalink)
Sorry I guess i shuold have been more specific.
I was talking about the head swap, so i have a DE bottom end with the VE system hooked up and 16VE cams in it when all is said and done.
Just wondering about anything special a need to do when i toss a discopotato or another turbo onto it.
96' 200sx SE-R
Old 02-27-2008, 12:17 AM   #126 (permalink)
Broke Ass
jer_760's Avatar
16VE cams is reaally pushing it with DE pistons.
Old 02-28-2008, 12:24 AM   #127 (permalink)
In regards to boosting or in general?
Would VG30DE pistons fit into this setup and have enough clearance?
Old 02-28-2008, 02:24 AM   #128 (permalink)
Guanaco Tuner
In regards to clearances, and boost. You'd be at 9.8:1 compression. VG30DE piston reliefs are in the wrong place.
Old 03-19-2008, 06:39 PM   #129 (permalink)
Trooper Billy
Hi Guanaco, Chapin here; if you ever need SR20DE'S call me. I have many in my stock.
Saludos.
Ronald 800-598-3535
Ronald Aguiree is offline   Reply With Quote
Old 03-19-2008, 08:40 PM   #130 (permalink)
working on it
swiss's Avatar
Feedback Score: 27 reviews
Hey Ron,
This is Dave Swisshelm. I bought an engine from you last September and it is beautiful. Clean as hell inside and out, compression tests perfect straight accross the cylinders. Thanks for taking good care of me. I've been spreading the word.
Dave
PS- I might be buying another this summer!
Old 03-27-2008, 03:46 PM   #131 (permalink)
Trooper Billy
Cool beans, just drop me a line and i will do my best. Glad to hear that the engine still going storng.
Old 04-29-2008, 10:35 PM   #132 (permalink)
How'd you get the block so clean?
IIIRII is offline   Reply With Quote
Old 04-29-2008, 10:40 PM   #133 (permalink)
Broke Ass
jer_760's Avatar
It's called paint
Old 04-30-2008, 05:47 PM   #134 (permalink)
Really, oh ok , it looks like it has been wet bead blasted.
Must be a flat silver paint then.
Old 06-23-2008, 02:17 AM   #135 (permalink)
Feedback Score: 5 reviews
i see where you hook up the oil line to the VE head. thats where i have my turbo oil feed line right now. but i blew it so im using a older DE block. i got a few questions ***.
-Where on a older DE block(with the oil filter tilted on top) do i hook up the oil line?
-What can i use if i need a oil line for the turbo and another one for the VE head?
thanks in advanced to anyone who can help.
-94 B13 SE-R VE-T(txnx2k's old car) Built motor by JMRgarage
-91 s13 KA-T drift car
-2010 corolla S daily driver
nacho_nismo is offline   Reply With Quote
Old 06-23-2008, 08:23 PM   #136 (permalink)
Broke Ass
jer_760's Avatar
You take it from the oil filter housing, put a t fitting where the stock oil pressure sender goes.
Old 06-24-2008, 01:35 AM   #137 (permalink)
where online can i find the "T's"?
Old 01-19-2009, 05:39 AM   #138 (permalink)
the sinner
Originally Posted by Luis View Post
That sounds about right..
*update*
I activated the VVL solenoids this weekend, and it works! And no valve piston clearance issue (as expected).
I just got a VVL engine to do the same thing with my sr20de+T 10:1, I'm worried abou the VVL solenoids not working, how or what do I do to ensure these things work???
burnoutkid is offline   Reply With Quote
Old 01-19-2009, 11:14 AM   #139 (permalink)
SR20sss RULE
Well, since the car is up and running now. How does it feel? Compared to a stock VE was it worth it?
omaritech is offline   Reply With Quote
Old 02-16-2009, 04:36 PM   #140 (permalink)
Hi,
I saw the questions I'm going to ask remain un answered. Maybe someone can clear it up.
When using the VE head, I'm also re using the VE Intake manifold with the VE Throttle body and all sensors?
Maf and other pressure sensors on the intake all remain the DE ?
Whose EGR and injectors do you use?
sincerely,
zac
zac-3ne2nr is offline   Reply With Quote
