My VE head swap how to (picture heavy) + Roller Rocker! - Page 9 - SR20 Forum
Old 05-27-2010, 12:56 AM   #161 (permalink)
Broke Ass
jer_760's Avatar
Feedback Score: 12 reviews
sh*t, I tell people over and over not to use 16ve cams with de or det pistons and no one listens. Sure there have been that have got away with the 16ve cams and some that havent, I have seen it in person. It is way too close to risk it. But people will continue to learn the hard way.......
95 200sx
sr20ve
Old 06-06-2010, 11:13 AM   #162 (permalink)
B12 SR20VE
aye sinnerman.. I heard about what happened on your build...
Mark10021987 is offline   Reply With Quote
Old 06-11-2010, 11:24 AM   #163 (permalink)
93.5 g20T
Originally Posted by burnoutkid View Post
Greddy MSS works well in activating the solenoids.
High port pistons will hit your valves hard even with a 1.88 gsket, the safer option is to use DET pistons or the VE ones.
I guess no one has really sent the figures on the valve clearance for this build.
Well I hope this helps as this is the result when you use an N1 cam with the DET piston and block.
Exhaust valves will hit the pistons, notice how deep the punches are which should make u think twice even when using a normal 16ve cams.
Originally Posted by Yellow4g63 View Post
I thought everyone knew that you can't use N1 cams with stock DET pistons? SR16 cams yes but not N1's.
I'm glad I read this... I'm building a roller rocker motor with bluebird pistons that have valve reliefs. With this set up can I run 20v cams without the valves hitting?
here's a pic of my pistons:
tampa g20t is offline   Reply With Quote
Old 06-11-2010, 03:56 PM   #164 (permalink)
P10 pro
Feedback Score: 8 reviews
I would say yes, if you upgrade the valve springs.
5speed is offline   Reply With Quote
Old 06-14-2010, 04:04 PM   #165 (permalink)
What sort of bluebird?
Do the valve reliefs line up with the valves? Thats always something to think about when swapping pistons just because they are there doesn't mean they will be in the right place.
unlimitedpower is offline   Reply With Quote
Old 06-10-2011, 06:47 AM   #166 (permalink)
how to wired up and activate the VVL...anybody use e-manage and apexi rsm to activate the VVL since hard to find greddy MSS..thanks
rockyrodriguez is offline   Reply With Quote
Old 11-22-2011, 06:31 PM   #167 (permalink)
Originally Posted by Luis View Post
I layed the VE/Metal Headgasket on, I made sure the engine was at TDC and put white out on the corresponding line on the crank pulley for future timing fun.
Block is ready. Now for the head.
is this realy VE gasket> i cant see the extra hole corresponding to the head tapped extra hole ...
zaplahata is offline   Reply With Quote
