Old 07-14-2006, 12:54 AM   #1 (permalink)
VVL Junkie
SR16VE Tuning
Yesterday I've joined the intake and exhaust VVL solenoid wires and pluged Greddy E-manage. Now the VVL switches at 5800. There was the specific sound after 6000. With the e-manage I have adjusted the AFR to 20% on 6000 and more. Help, What settings must I set to compensate the lean from 6000 to 7000?
Nissan Pulsar Gti-R'91 - under constuction (sr20vet in the garage)
DeNismo is offline   Reply With Quote
Old 07-14-2006, 09:29 AM   #2 (permalink)
vzr- sr16ve
Ha i done this two days ago too i think the car is fair bit quicker.What do you mean there was a specific sound after 6000 .I don't have e-manage but im interested as to what advantage you have got with it on your car.I presume that now you have both cams activating at once you can move that one activation up and down the rpm range.Btw would you not need a dyno to set air/fuel correctly!
lucino vzr 1 is offline   Reply With Quote
Old 07-14-2006, 05:18 PM   #3 (permalink)
Enemy of the stupid
you need to know what A/F ratio your at after those RPM's you might be rich or lean. Try and get a wide band 02 sensor so you can find out what your at. Then from there add or take fuel away.
91 NX2000 VE forsale
http://www.drag240sx.com/
