Old 07-23-2006, 01:33 AM   #1 (permalink)
SR20sss RULE
SR20VE into SR18DE Primera
Ok guys, this might be a weird one, I finally have my SR20VE coming, just engine, ecu,harness and i want to put it my P11 Primera that has in a SR18DE . Yes a SR18DE. Pretty nice engine, well after all it is a Nissan.
But this is the thing, i want to put in the VE with my current auto tranny, with a tranny oil cooler. Don't want to go manual yet. Just engine swap. Now what problems am i going to run into with swap and the harness, I am not sure how different the SR20 vs SR18 harness is. Everything i have read is about a SR20DE to VE swap, nothing about the SR18 to VE swap. Please Help. Need some advice.
Should i just swap in complete VE harness and ecu and then use something else to activate cams?
U can look at car here,
http://www.cardomain.com/ride/207065
omaritech is offline   Reply With Quote
Old 07-23-2006, 04:20 AM   #2 (permalink)
SR20DET convert
I don't see any reason it'd be any different from a SR20 conversion. They're the same basic engine after all. All sensors etc should be in the same place.
Muttly is offline   Reply With Quote
Old 07-24-2006, 01:08 AM   #3 (permalink)
Enemy of the stupid
Never seen the P11 but if it's SR18 I don't see why you can't just bolt up you old trans to the new motor and factory harness.
91 NX2000 VE forsale
http://www.drag240sx.com/
