Old 07-23-2006, 11:23 PM   #1 (permalink)
Enemy of the stupid
Gather around everyone VE pic time *Update*
Yes come close and take a look at my head It seems I bent 1 valve so far that I know of. I was sick last week and one of those days (Saturday night) I went out to get some food since nobody wanted to get close to me to help me while I was sick lol. Well long story short car droped 2 cylinders while I was driving. Been sick and a few miles from home I went to a friends house on my way home and did a compression check . We thought the gauge was broke because #4 got zero, and #3 got Zero. Then we tried #1 and #2 and they were good. Well here is what happened.
This is #4 intake, exhaust looked fine.
I spy with my eye the shim caught in between the rocker and retainer!!!!
Now on to #3
Bent!!!!! intake valve. I just found this Saturday night because I was feeling good enough to do a little work on the car. Since no VE valve replacement has been found in another SR20 I'm going to take the head of my SR16VE and swap it onto my SR20. Before that *** I'm going to change the springs and retainers out with the franklin cams and order there N1 copy cam while I'm at it. should have bought a Civic and did the K20 swap lol. Ahh well Rev limiter was set to 7800 with the SR16VE cams. When I'm done I guess I won't have to worry about this crap anymore. I hate it when I should have done something at 1st but didn't There goes some of my RB20 manifold funds. I'll fix the this head with some of the parts from SR16 head cept for the valves then save this head for I don't know what. Live and learn
UPDATE
Well I was very right it was the screw that bent the valve! sob.
And then I saw this on #4???
Looks like something was trying to get out and finally did.
91 NX2000 VE forsale
http://www.drag240sx.com/
Old 07-23-2006, 11:58 PM   #2 (permalink)
The Genesis
fack..even when u showed me earlier, its still a sad sight
Old 07-24-2006, 01:42 AM   #3 (permalink)
giggidy giggidy
How did you bend the valves dude? For the sake of our own amusement... Have a look at your throttlebody and see if there's still two screws in there :S
That looks extremely familiar to the sight I saw when I had a valve jammed open by a throttlebody screw
Anybody who cannot comprehend mathematics is not fully human. At best he is a tolerable subhuman who has learned to wash, cook food, and not make messes on the floor.
punkoutnz is offline   Reply With Quote
Old 07-24-2006, 02:17 AM   #4 (permalink)
Enemy of the stupid
Well the motor only had 1 in there when I installed it. I took one from my DE and put some lock tite on it. If you look at #3 the valve is sitting lower than the others. Either way the head has to come off. 1 more week and I'll be better health to do the work. How long dose it take Franklin to crank out cams?
Old 07-24-2006, 10:08 AM   #5 (permalink)
sorry to see this yute! well hope to see you up and running again, why not go with the stg4 cams?
anomaly is offline   Reply With Quote
Old 07-24-2006, 10:32 AM   #6 (permalink)
Enemy of the stupid
The valve clearance issue, If it wasn't for that I prob would go with the Stage4's. I'm also loosing focus on my other project the more I play with the car. So N1 cams are good enough, it will put my past my goal of 190hp lol.
Old 07-24-2006, 03:44 PM   #7 (permalink)
Baby Blue VVL
what happened exactly?
do you have pics of the inside of your intake manifold/ Tbody?
also if that shim was like that originally could you have hooked one valve on the other at high rpm?
VVL?
IX MR?
A race????
Old 07-24-2006, 08:59 PM   #8 (permalink)
Enemy of the stupid
Went to get food late night, merged on the fwy kept driving lost 2 cylinders. Stoped by my friends place and did a comp test found 2 dead. Went back home pissed and sick and the car sat for a week till saturday night where I felt good enough to pull the valve cover and see what was going on . The car sounded find after I merged on the fwy nothing to make me say "hmmm that dosen't sound right".
Old 07-25-2006, 02:31 PM   #9 (permalink)
Guanaco Tuner
That's weird how you just "lost" 2 cylinders.. What was your redline set to ? Not saying you bounced off the rev limit, just curious.
Old 07-25-2006, 04:47 PM   #10 (permalink)
Enemy of the stupid
Rev limiter was set to 7800 with the SR16VE cams. I did hit the limiter, but everything sounded fine. It didn't happen after I merged on the fwy, in fact this sh*t never happens when I'm at WOT, It happened as I was going down the fwy at 65-70mph in 5th gear. I'm just waiting on Franklin at this point.
Old 07-25-2006, 04:53 PM   #11 (permalink)
Guanaco Tuner
That is pretty random. Sounds like your springs might have failed.. Which doesn't really make sense. I guess you'll know when you take the head apart.
Old 07-25-2006, 05:12 PM   #12 (permalink)
Enemy of the stupid
Yeah the head isn't as fresh as my SR16VE.
Old 07-25-2006, 06:25 PM   #13 (permalink)
needs to be tuned
geeio's Avatar
i got the same thing going on. i was just driving and it wasnt untill a bit after that the car started sounding like crap and i lost compression on cylnder #2. i got some new intake valves, franklin valve springs and the retainers. just havent had the real time to get the work done. good luck with yours. my rev limit was set to 8 with sr16 cams. i was also missing a throttle body screw but im not sure if it was there when i put the motor in.
looks like its got a bad sun burn.
geeio is offline   Reply With Quote
Old 07-25-2006, 06:43 PM   #14 (permalink)
Luke Pighetti
Taiden's Avatar
I need to go knock on a lot of wood right now. Just finished my VE.
Bbl.. going outside in the vast forest that is Maine.
Old 07-25-2006, 06:49 PM   #15 (permalink)
Enemy of the stupid
Did you find someone parting out a VE head for the extra valves or did you buy new ones?
Old 07-25-2006, 07:10 PM   #16 (permalink)
Luke Pighetti
Taiden's Avatar
Can you guys tell me where said throttle body screw is? I would like to locktite the sh*t out of mine.
Old 07-25-2006, 08:35 PM   #17 (permalink)
The Genesis
on the throttel body itself^ the butterfly has two tiny screws there.
Old 07-25-2006, 08:39 PM   #18 (permalink)
Luke Pighetti
Taiden's Avatar
Are you talking about the two screws that face towards the intake piping right on the center of the butterfly?
Nissan shoulda riveted that thing or something. sheesh.
Old 07-25-2006, 08:41 PM   #19 (permalink)
SHIFT_ SuCka
greense-rious's Avatar
yes those , its on the butterfly its self , Im buying loctite metal epoxy tomorrow and sealing them myself
95 200 SR20 project -------->(VE)
" A horse is a horse of course of course, 323 of em in that porsche get a load of this life style of the rich and I dont even race her I baby that ish"
" My hands got the bubble touch, bite with the double clutch"
greense-rious is offline   Reply With Quote
Old 07-25-2006, 08:42 PM   #20 (permalink)
Enemy of the stupid
SOB!!!!!!!!!!!! punkoutnz your right!. The same fing screw that was missing when I 1st got the motor was missing again!!! I even put lock tite in it.
I was *** running out to take a pic for Taiden. Looks like I'll have to get that fixed too sob.
