Old 04-22-2002, 09:45 PM   #1 (permalink)
VE Injectors becoming maxed out
I was thinking, the VE injectors are around 314cc right? Well, if 370cc injectors top out around mid 200's at the wheel, then the VE injectors might start running out of room at around 213 (give or take a few) horsepower at the wheels. I wonder if this will be a problem for those of you with full exhaust, CAI, SR16VE cams, Intake and header. Would be nice peace of mind if Clark could make a program with 370cc injectors so that you would never have to worry about it. Another option might be making a 4 bar program for the 314s, so you could just slap on a regulator, instead having having to throw the 370s in the rail. Just tossing sh*t out there cause I am bored!
Lyn Labahn is offline   Reply With Quote
Old 04-22-2002, 09:49 PM   #2 (permalink)
Jah Rastafari
Trader Rating: 55 (100%)
You would be better off just putting in 370cc inj and putting a Nismo adjustable Regulator and lowering the fuel presure a tad bit. The diffrence between 370cc and 314cc are minimal enough where you do not have to get so technical. The computer has a little room for self adjustment also.
Old 04-23-2002, 08:12 AM   #3 (permalink)
Retired VE Owner
According to JWT and their flowbench the VE injectors are 333cc. I just spoke with Clark again yesterday and verified this.
Chuck Nibbana
Retired VE owner
2005 BMW M3
CNibbana is offline   Reply With Quote
Old 01-25-2004, 05:06 PM   #4 (permalink)
Trader Rating: 36 (100%)
Has anyone tried the 370cc injectors off the SR20DET motors? I don't know if they're a direct fit or not? You can get a set off the DET guys for a fairly good price. I'll be having my own set when I upgrade my RWD SR20DET injectors, I'll see if they work then..
O.K. Let's say you got the basic bolt ons, CAI, Fujitsubo headers, 2.5" exhaust, 2.5" test pipe, FPR, a JWT VE ECU set for 370cc injectors, and you put in 370cc injectors. With these mods, you think that will break the 200hp to the wheel mark???
nismos13silvia is offline   Reply With Quote
Old 01-25-2004, 08:23 PM   #5 (permalink)
Jah Rastafari
the injs are about 333cc. Please also note that the NA motors can be run alittle leaner than turbo motors so you will have to make about 225-230 WHP to start pushing these injs hard.
Old 01-26-2004, 10:51 AM   #6 (permalink)
O.K. Just wanted to toss the idea out there. If "we" ever make that much WHP or more
Old 02-08-2004, 09:40 PM   #7 (permalink)
Like it or Don't Like it
What if on NOS? 75-100HP SHOT...will they top out?
Digitek is offline   Reply With Quote
Old 02-09-2004, 01:51 AM   #8 (permalink)
Infiniti Parts Guy
Andreas said above, you have to make 225-230whp to start getting close to the injector's limits. If you make 175-180whp with a basic VE, then add another 75-100 hp (which is most likely too much nitrous for an internally stock VE) then you'd be well past the whp range he just mentioned...
Justin McClanahan
2007 350Z
Old 02-09-2004, 07:51 AM   #9 (permalink)
With a Dry system yes, with a wet system no. On both you need to upgrade the fuel pump to be safe.
Steve
06 G35 6MT
Old 02-09-2004, 10:56 AM   #10 (permalink)
ok I don't like dry systems...just asked for getting the info on the board I used a wet system on my DE wth 75hp and a friend with a 100hp on stock internals and no problems at all..
but yes Im going to add a walbro f/p and I already have 3/8 fuel lines.
