Old 10-22-2006, 01:24 AM   #1 (permalink)
Has anyone actualy tested Franklin cam yet?
And has dyno sheets?
Or was the whole thing a bust?
2006, The year of the Dog Car
choaderboy2 is offline   Reply With Quote
Old 10-22-2006, 02:05 AM   #2 (permalink)
Well after my bearing failure on the built VE I'm considering dropping back in a stock VE untill the built motor can be sorted out.
Now, IF, and only IF someone can give me some guarantee that the FS4 cams can run on a bone stock VE bottom end without hitting the valves (especially concerned about high rpm), then I'll consider doing some dyno runs on the stock motor just dropping in the cams and posssibly the springs too. This is exactly what everyone's been looking for right?
ps: Someone mentioned to me that conrods "stretch" slighty at high rpm. is this a fact?
Sabre 200 Gxi is offline   Reply With Quote
Old 10-22-2006, 02:37 AM   #3 (permalink)
The Genesis
there has been so much speculation on these cams that i think they are a bust overall. i havent really kept up with the development much anyway, so i dont know.
tHe iLleSt RiCe is online now   Reply With Quote
Old 10-22-2006, 04:13 AM   #4 (permalink)
N14 Sr20ve + T
derm's Avatar
Bring the cams to me and i'll test them in a stock motor
derm is offline   Reply With Quote
Old 10-22-2006, 12:25 PM   #5 (permalink)
this might be done very soon, as soon as money allows anyway.
anomaly is offline   Reply With Quote
Old 10-22-2006, 05:12 PM   #6 (permalink)
Baby Blue VVL
ill respond to your PM soon
Let me know what happened to your motor
Chris
VVL?
IX MR?
A race????
Old 10-22-2006, 05:21 PM   #7 (permalink)
yup, that is one of the reasons you keep the quench thickness at about 40 thou, depends upon revs and how stout the rods are though.
Andreas? has dropped the quench below 30 thou total and raced a DE, so thick stout rods allow you more leeway.
Regards,
Mike
UK-SRi is offline   Reply With Quote
Old 10-22-2006, 06:22 PM   #8 (permalink)
Regards,
Mike
I am running only about 25 thou quench clearance by accident. Seems ok though.
Old 10-22-2006, 06:23 PM   #9 (permalink)
So I guess my answer is no not yet? Cams is one of the main reasons why my big dog motor sits in pieces.
Old 10-22-2006, 06:27 PM   #10 (permalink)
This is correct, there are no conclusive dyno's of a VE with Franklin cams.
Old 10-22-2006, 06:31 PM   #11 (permalink)
done
The only dyno is from someone loosing power everywhere, I think..
Old 10-22-2006, 06:34 PM   #12 (permalink)
Jah Rastafari
Trader Rating: 55 (100%)
Build it and they will come.
Just put the damn motor together. Make sure the pistons have large valve notches. I made mine 2mm deeper than stock should work with any cam that will be put in the motor. pic below
Old 10-22-2006, 06:38 PM   #13 (permalink)
I remeber Andreas offered Franklin to test the cams but I think they denied.
Alot of people have been waiting to see some solid facts on these cams but they have yet to do so.
Mike have you researched the Kelford (sp) cams? I know of a few people who will be testing them out soon. I am anxious to see the outcome.
-Rob-
Get ready for a big SE-Rprise
Old 10-22-2006, 06:49 PM   #14 (permalink)
PLAY MY HEAD, MONKEY!
daveracer's Avatar
Trader Rating: 89 (100%)
WOW, it REALLY would have been in their best interest to agree to that. If they made good power, their sales would ^^^^^ big time. Oh well!
Old 10-22-2006, 06:51 PM   #15 (permalink)
Jah Rastafari
I told Franklin cams if they worked I would pay them. If they did not work I would send them back.
Well they denied and life went on.
Old 10-22-2006, 07:34 PM   #16 (permalink)
Enemy of the stupid
Atleast you got a reply from them. I was looking into buying Stage4's and valve springs but never got a email back.
91 NX2000 VE forsale
http://www.drag240sx.com/
Old 10-22-2006, 07:36 PM   #17 (permalink)
Jah Rastafari
I am under the understanding they will not be selling VE cams anymore as they can not get the blanks anymore.
Old 10-22-2006, 07:37 PM   #18 (permalink)
Andreas what Pistons are those? Looks like flat tops with valve notches?
Here's the story:
Motor was built as follows:
8CW DE crank
DE gridle and bolts
N1 pistons with valve pockets cut 1mm deeper.
S14 DET rods, balanced
ACL (lead copper) bearings
1.5mm cometic gasket
franklin s4 cams & springs
Castrol edge 10w60 full synthetic oil
Car was dynoed to 184whp at about 7000 odd rpm at altitude. Corrected for sea level the figure is around 215whp. Running std DE ecu with a piggyback. Afer about 1000kms of gentle driving it was taken for another dyno run. This time it was down on power. We though this was due to the DE ECU detecting the solid lifter type head sounds as knock and retarding the timing.
So engine management was fitted. Car was being dynoed when the rod bearing on #4 or #3 went. (Have to open up the motor to see this coming week) With the management it revved easily to 8500rpm but was never taken higher than that.
Now there is much speculation at the moment. Oil quality, oil temp on dyno, too much load on dyno, incorrect clearances on the used DET rods, Oil supply from sump at high rpm etc. Will only know the reason later this week.
If the motor can't be repaired quickly then I'm dropping in a stock VE. May then do some testing with the cams in that motor.
ps: Is it crucial to change the oil pump after the bearing failure? The motor was pretty much switched off immediately and only idled after the bearing went.
I'm wondering if that heavy rotating assembly was really necessary though. Derm's motors are running 9000rpm daily on std bottom ends with no hassles.
Old 10-22-2006, 07:43 PM   #19 (permalink)
Jah Rastafari
I had the pistons made and they are not flat tops they have a small dish to them
Old 10-23-2006, 02:17 AM   #20 (permalink)
[quote=Sabre 200 Gxi]
QUOTE]
I would inspect the pump gears and side plates and the relife valve and if the valve works smoothly and the insides are not scored, I'd reuse it.
One thing, its important to ultrasonicaly clean the oil cooler and lines whenever you have an engine failure.
