Old 10-22-2006, 03:15 PM   #1 (permalink)
Is an SE-R/VE a VE-R?
At long last, pics of Eads' VE
No sound vids of the racket this thing makes, but here's a few pics - after 8 months-
My kid operates a small commercial wireless ISP up in Richmond (richmondair.com); these are on a hosting site he glued together. These are cut back with photoshop to 640x480 from 2272x1704 so they shouldn't hang people up. First time I've done pics, HOPEFULLY when this posts this'll just be links and not transferred in pics so I don't force you guys with dialup to come back to see this after you go to work.
Edit: It occurs to me with all the thanx I put in to folks below, not once did I mention Matt and this forum - without which I can't imagine I could have done this thing; learning from this forum has been like going after another degree but a LOT more fun. Thanx to all of you who make this place happen.
This is just the car - Thanx to Melissa's tutelage, it shines up pretty well, *** the paint is far from perfect, and plenty of parking dings.
http://photo.angrylabs.com/main.php?g2_itemId=82
Rear view - you can just see the 3" poking its nose out - no chrome - just an oval Magnaflow 3" both ends, painted black.
http://photo.angrylabs.com/main.php?g2_itemId=91
Exhaust a bit more obvious
http://photo.angrylabs.com/main.php?g2_itemId=88
For Melissa - (this is cheating; new hood with fresh paint and clearcoat)
http://photo.angrylabs.com/main.php?g2_itemId=109
AD22VF's with 16x7 37mm offset OZ's and 205/40 BS RE950's. Decent for a 30k street tire but pretty (okay, very) slippery for ax.
http://photo.angrylabs.com/main.php?g2_itemId=66
ENDLESS posts on how to screw up headliners. This is how it's done right (Let a good ol' boy 30 year upholstery guru do it). See signature.
http://photo.angrylabs.com/main.php?g2_itemId=106
Gauges. My gawd this takes a lot of wire and conduit. Wish I could have found something prettier to house the oil press on the column, but it's where you put it - right in front of your eyes. Visually it's right between the tach and speedo, no interference.
http://photo.angrylabs.com/main.php?g2_itemId=115
This is how you shut up the racket of shortened (don't do this, not enough travel, but it sure looks good ) Hypercos (THANKS Chris (Chriscar)) in the AGX seat. Plain old heater hose. I don't get credit for the idea, some genius on the forum thought it up. THANK YOU if you see this. Somebody thought pickup bed liner paint would quiet them, which is what's on the spring. The thin rubber Nissan spring seat is tossed.
http://photo.angrylabs.com/main.php?g2_itemId=112
Okay okay okay. Here's the motor. THANK YOU Dre. I cried when I wrapped (Summit) that gorgeous stainless Fuji, but it is absolutely wonderful stuff, & my AC compressor overheat sensor shuts it off no more. It's darn near cold in there. Also hence no CAI. Dre called me up last February and says - "Just got one with 7500 miles on it - want it??" - does a bear etc. -- the plugs looked like they'd been fired once. The guy spend HOURS on the fone with me MAKING SURE everything went all right. No secret why those of us who work with him go to bat for him.
http://photo.angrylabs.com/main.php?g2_itemId=100
Another shot. Yes, every lead is in conduit. No exceptions. The remote oil press sender is mounted just in front of the mc and just behind the Pathfinder MAF. Stainless down to the Nissport adapter.
http://photo.angrylabs.com/main.php?g2_itemId=97
A better shot of the battery (THANKS Serban), the Digital 6+ (THANKS Teal97), the 8207 coil and the single 8969 tucked under the fender lip. I used Serb's ittybitty battery to get SOMEWHERE to cram the ignition (mainly for the rev limiter but many other benefits), and I did NOT want to remote the battery. So far, it's been flawless.
http://photo.angrylabs.com/main.php?g2_itemId=118
This is the Apexi valve right in front of the resonator and behind the cat. Open; you see the slight bit of slack left in the line. Yes, cable is in conduit all the way through the firewall. I HATE redoing things. Screw holding the butterfly on the shaft came loose in two weeks. TG it's a 3" and that I have really small hands. And a helluva junk screw box. With loctite it's still in there.
http://photo.angrylabs.com/main.php?g2_itemId=70
Here's the cable pull, in full closed position. It's positioned so it's a very easy reach when the seat's where I set it, and clears the seat so it doesn't rub a hole in the upholstery. It is NOT spring loaded, so you MUST remember to open the damned thing when you get on it. Sigh.
http://photo.angrylabs.com/main.php?g2_itemId=76
The tail of the Fuji, one of the Progress bars (THANKS Rob (Toolapcfan)), and the perfect fit 3" mandrel Magnaflow system (THANK YOU DANIEL AND VRS).
http://photo.angrylabs.com/main.php?g2_itemId=103
Guess that'll do. Thanx again to Dre, Milburn, Ron and my wizard kid Chris (got bored with being a benz tech so now runs wireless ISP) for ALL the help. It's a bitch doing this on a carport in the winter.
YES, it passed the dreaded Atlanta smog test. Without the EGR.
Moderators, sorry if this is too much; just toss it or move it as you see fit.
'93 B13, etc.
do it over and over again?
Old 10-22-2006, 04:01 PM   #2 (permalink)
convention track slut
Trader Rating: 28 (100%)
Nice car!
05 Tacoma 4x4
91 White SE-R built de coming up
nissansr20nx is offline   Reply With Quote
Old 10-22-2006, 05:16 PM   #3 (permalink)
Soon!
Looks fantastic! Glad I could be of help. (I want to see direct sunlight shots though, that's the real test for paint swirls ).
Melissa is offline   Reply With Quote
Old 10-22-2006, 05:29 PM   #4 (permalink)
agent camel toe
it must not rain much where u guys are at..that msd in that position/the blaster coil also will make me worry//other than that nice ve
nyce1s.com
R.I.P. RESPECT SR.
93 p10 jdm de--for sale
96 b14 det--for sale
89 formula--sold
next up is a minivan
Old 10-22-2006, 05:52 PM   #5 (permalink)
Yup, worried about that too in placement; Milburn (formerly coolblackser, now with Evo) set me up in his lab shop to build that aluminum alloy mount for the d6+ (both are supposed to be waterproof but I wasn't happy about placing the dials face up); it's placed where it is precisely for it to shield the D6+ and the 8207. Took a look after several downpour drives; dry as a bone. Wonder if I should build a plastic shield to go over the dials.
Melissa, tried to do shots in full sunlight and only got glare, which did a GREAT job of hiding the swirls - - - - :-)
Old 10-22-2006, 07:27 PM   #6 (permalink)
Back in the game sluts
Nice car.
Question, My 96 se-r came with the black hose all over it. Why would anyone want it? Is it for looks or does it serve a purpose?
07 Civic Si (Daily Driver)
96 200sx SE-R. S4's and supporting mods + Suspension (trackcar)
91 300zX Twin Turbo 5spd @ Stage V (Powerhouse)
200SX SE-R WV is offline   Reply With Quote
Old 10-22-2006, 07:57 PM   #7 (permalink)
Black hose? You mean as edging? Don't understand. Try me again.
Old 10-22-2006, 08:10 PM   #8 (permalink)
Your dead Twinkie
Benito Malito's Avatar
Trader Rating: 32 (100%)
Man Jerry that makes me want to redo my wiring. Not that I will. Looks great.
1992 SE-R 'Fasty' Mods and mods in boxes. Ready for more boost, or more vvl.
Old 10-22-2006, 08:51 PM   #9 (permalink)
Slowing down.....
Nice job, Jerry. Nice paint, straight body, clean VE install. Ain't no way in hell you are ever going to sell your baby, period. Now we see why.
91 SE-R
94 SE-R w/VE
blusteelsr20 is offline   Reply With Quote
Old 10-22-2006, 11:36 PM   #10 (permalink)
.i love my NX.
Trader Rating: 20 (100%)
...this is one very clean classic....seen this car in person and is one of the most cleanest b13's i have ever seen....makes me want to get one and put a VE in it too....Jerry your car rules!....
.MuNkey. is offline   Reply With Quote
Old 10-23-2006, 12:21 AM   #11 (permalink)
Did you have to take the fuji off to wrap it?? I'm thinking of doing it...
lalito is offline   Reply With Quote
Old 10-23-2006, 01:09 AM   #12 (permalink)
That conduet stuff.
Old 10-23-2006, 08:49 AM   #13 (permalink)
Thanx Joji (HAH - got it right)
Yup, did the Fuji on the dining room floor (Mary Lynn is getting used to it) straight out of the box before it went on. But I suspect you could do it with it on the car, altho I wouldn't choose to do it that way (PITA).
AH - The conduit protects whatever's inside it from heat and abrasion from rubbing up against stuff. Everywhere I ran a wire. LOTS of wire for the gauges. Some folks unwrap the original wiring loom conduit and put new wire in that, but I was just too lazy.
Old 10-23-2006, 08:52 AM   #14 (permalink)
I like it alot.
92 NX2000 'Stock'- gone to a good home
92 Sentra SE-R 'Stock & So damn clean'
03 SRT-4 13.3@103mph
Current: 2002 BMW 325Ci
Originally Posted by XxToKeSxX View Post
When your a boss player, you buy the car to match the shoes bish... j/k
CenturyI is offline   Reply With Quote
Old 10-23-2006, 08:56 AM   #15 (permalink)
Trader Rating: 102 (100%)
Jerry, the car looks great! I'm glad to finally see pics of it, good work on all you've done so far!
Old 10-23-2006, 09:38 AM   #16 (permalink)
Thx Serb.
ONE of these days I'll get somebody to cut off the muff and reweld. It's the one vrs 'miss.' - muff and one of the tp sections are welded together, and they fall in there perfectly to the tp piece with the S bend and to the hangers. One of those bazillion detail pieces that I just haven't gotten to, as it also takes re-positioning the hangers.
Dre'll call up every now and then and say things like "CAMS" or "8CW CRANK" or "VALVE SPRINGS" etc. - Of course he takes these things apart in his sleep - - - I keep asking him to move up here, but no luck so far :-).
Old 10-23-2006, 10:16 AM   #17 (permalink)
Very nice clean looking car and setup overall there! Good work.
Sabre 200 Gxi is offline   Reply With Quote
Old 10-23-2006, 11:21 AM   #18 (permalink)
Sweetness!!
Nice ride you got there, Jer! When you gonna dyno tune it?
Ric
waiting for another (sae vs actual) controversey
Teal97 is offline   Reply With Quote
Old 10-23-2006, 12:24 PM   #19 (permalink)
Hey Ric - Been thinking about taking up a collection or doing a bake sale to do dyno proceeds - I figure about 5 different modifications in a fully counterbalanced experimental design - That should be 125 runs - - - - :-) After that I'd guess I'd need to ask Dre for another motor - - - -
Old 10-23-2006, 02:28 PM   #20 (permalink)
party over there
AG>SR's Avatar
Trader Rating: 40 (100%)
THE JOB YOU DID
ON YOUR CAR
random music
more random music
and beeee veeeeerrrry
AG>SR is offline   Reply With Quote
