Old 10-25-2006, 04:54 PM   #1 (permalink)
Source of bearing failure found!
With the oil pan and lower part of the block removed, it was obvious why I had bearing failure
Together with some shavings from the bearings, we found the 4 oil squirters / piston coolers' stubs in the oil pan. They had broken off. (by the looks of it probably on the first start up already)
A little inspection revealed that the skirts of the N1 pistons had hit the oil squirters right off on the down stroke, causing about a 2mm oil "leak" where a 0.1mm pressured hole should be squirting oil. This obviously caused oil pressure drop and starved the bearings of oil leading to the failure. I'm surprised it even lasted the +/- 1000miles it did!!
Now, has anyone else had these clearance issues with N1 pistons on a VE? I see a normal 20ve piston has a relief in the piston skirt for the oil cooler. I can only assume N1 pistons have the same.
This means my "engine builder" must have either:
1) fitted the oil squirters incorrectly causing them to be in the path of the piston skirt, or
2) fitted the N1 pistons back to front with the relief facing the opposite way
Sabre 200 Gxi is offline   Reply With Quote
Old 10-25-2006, 05:00 PM   #2 (permalink)
merely a flesh wound
chriscar's Avatar
Oooooh, I'd be SO mad.
Old 10-25-2006, 05:19 PM   #3 (permalink)
wow i hope it works out for you, that REALLY sucks
2000 Black Sentra SE w/aPP
turco is offline   Reply With Quote
Old 10-25-2006, 05:38 PM   #4 (permalink)
!!!!CAUTION!!!!
blurr.rt.by.you's Avatar
Trader Rating: 66 (100%)
skeet skeet skeet. that blows definately post picks and possibly do a write up on how not to do it.
***GARAGE SALE***
http://www.sr20forum.com/mechanical-oem-part-outs/215172-garage-clean-up-sale.html
http://www.sr20forum.com/mechanical-oem-part-outs/217115-more-stuff-sale.html
blurr.rt.by.you is offline   Reply With Quote
Old 10-25-2006, 06:11 PM   #5 (permalink)
NOOOOOOOOOOOOO..............
They dont clear....
you have to make the notch on the SR16 pistons for them to clear
figure 68.5mm stroke<86mm stroke
payu is offline   Reply With Quote
Old 10-25-2006, 06:15 PM   #6 (permalink)
WASHED UP
They dont clear....
Yep you should of notched it bro .
Old 10-25-2006, 06:19 PM   #7 (permalink)
Like it or Don't Like it
Damn thats sad...but as Payu said man...sorry to hear
and sad thing is the mechanic didn't even turn the engine with just the crank and pistons to see if everything turned and cleared...we found in my car that similar problem but fixed it right away and now it clears all perfect.
but oh well...you should be up again buy some new bearings and oil squirters and rebuild.
good luck.
NEO-VVL Got VT@K?
E²SR20.com
Digitek is offline   Reply With Quote
Old 10-25-2006, 06:30 PM   #8 (permalink)
Thanks guys.
I really think that's a point that should be added to the FAQ's in some sticky. All the posts I read on the forum never mentioned this. The consequences are as you can see severe.
Hopefully a few people will read this thread and make a note.
Got a spare 20VE I'm dropping in now then it's back to the drawing board for this block.
ps: Anyone has a set of squirters laying around. How much are they from Nissan/Mossy/Greg? I take it they differ from DET ones?
Old 10-25-2006, 06:33 PM   #9 (permalink)
And I agree that the engine builder should have picked this up!! Especially since I paid nearly $2k for labour on the total build.
Old 10-25-2006, 06:33 PM   #10 (permalink)
They are the same as DET Greg should have them....
Old 10-25-2006, 06:36 PM   #11 (permalink)
XxToKeSxX's Avatar
Aw man I'm betting its #2... $4 on choice 2... roll the dice!!!!
Will your "builder" be taking care of it?
edit... ahhh, didn't read
1998 200sx SE-R | SR20DE
1991 NX-TuRBO | SR20DET
1995 240sx BaSe | ____DET
Shift_Buy Broken & Build...
Old 10-25-2006, 06:39 PM   #12 (permalink)
Jah Rastafari
Trader Rating: 55 (100%)
Nissan never put oil squirter notches on SR16VE pistons because the piston did not come far enough down with the SR16VE crank to interfer with the oil squiters.
The SR16VE crank is 68.70
The SR20VE cranks is 86.00
That means the piston is sitting 8.65 mm higher in the SR16VE. If you check the oil squirter notch on a VE you will see it is about 9mm or so.
Old 10-25-2006, 06:40 PM   #13 (permalink)
Jah Rastafari
This guy should have roatated the assembly by hand before closing up the motor. You always do this an check for problems and clearance issues.
Old 10-25-2006, 06:43 PM   #14 (permalink)
oil squirters would have broken right away if just turned by hand...
I would reclaim this to the mechanic 2k is a big deal of money...
Old 10-25-2006, 06:54 PM   #15 (permalink)
Yeah the bill was rediculous. But he is supposed to an guru and insisted I'm paying for his expertise etc.
Tomorrow I'll know what he says and if he is going to own up. I won't let him work on it again since I've found some other minor discrepancies too, so I guess he will owe me a partial refund. My guess is he will tell me that I should have told him these pistons need to be modified...
If you want something done right,..........!!!!!!
Old 10-25-2006, 09:44 PM   #17 (permalink)
ECU Hacker
how can you tell an "expert" that insists your "paying for experience" blame you - a customer who "doesnt know" and how can he claim that its ok if he didnt test it by hand rotation first ?
If your in the states - find a happy lawyer and tell them what happened and you'll be able to sue him for your money for rebuilds or somethin :P doesnt everyone over there sue when stuff dont work? :P (just kidding - not wanting to start a flame war)
cb_drift is offline   Reply With Quote
Old 10-25-2006, 11:35 PM   #18 (permalink)
On my squirter equppied motor I almost made the same mistake. I checked just as the motor was partly together, then had to dissasemble it and notch the pistons, duh.
2006, The year of the Dog Car
choaderboy2 is offline   Reply With Quote
Old 10-26-2006, 12:18 AM   #19 (permalink)
Your dead Twinkie
Benito Malito's Avatar
Trader Rating: 32 (100%)
Seriously swing the freaking crank. They used to do this on Model-T Fords.
1992 SE-R 'Fasty' Mods and mods in boxes. Ready for more boost, or more vvl.
Old 10-26-2006, 05:40 AM   #20 (permalink)
N15 Pulsar 20v
I would love to hear what your engine builder has to say. I am very disappointed as I was the one who reffered you there. I know people make mistakes and so have I but always fronted up and copped the bill. Good luck
WHEN IM BIG I WANT TO HAVE MY OWN BEER TRUCK IN MY GARAGE
kiwi-japie is offline   Reply With Quote
