Old 10-28-2006, 07:00 PM   #1 (permalink)
Jah Rastafari
Trader Rating: 55 (100%)
I Made A Wrong Calculation On Compression With SR16VE Pistons
Here are the new figures.
SR16VE pistons in DE motor 11.8 to 1 compression
SR16VE pistons in VE motor 12.5 to 1 compression
I use to say that the SR16VE piston in a VE was about 13.6 to 1 compression. I was making this calculations from the SR16VE N1 head. As we know the SR16VE N1 head is shaved down 1mm to get the compression to 11.8 to 1 vs 11 to 1 compression in the regular SR16VE.
So if we shave 1mm of the top of the SR16VE piston the compression will be about 12 to 1 compression.
You can also get SR16VE pistons and make the valve notches 1mm deeper and that will take out the same amount of metal as removing 1mm of the top of the SR16VE piston so this should also net 12 to 1 compression.
If you do any of these mods when done send the piston to swain to be coated on the top.
To add to this if you make the headgasket .5 mm thicker than stock the compression will be about 12 to 1 compression with SR16VE pistons in a SR20VE motor.
Old 10-28-2006, 07:07 PM   #2 (permalink)
12's Is So Last Summer!
urbanracerone's Avatar
Trader Rating: 36 (100%)
JUN
turbo SER's are so 90's!
Tarmac Motorsport LLC
89-Florida St
farmindale NY, 11735
631 390 9410
NYC's Fastest Nissan's
urbanracerone is offline   Reply With Quote
Old 10-28-2006, 09:53 PM   #3 (permalink)
Any reason we can't just do what Nissan did and shave the regular SR20VE head 1mm to bump compression from 10.3:1 to around 11:1? Granted, adjustable cam gears (at least one) will probably be needed to get the cam timing ideal.
hachi_boroku is offline   Reply With Quote
Old 10-29-2006, 01:48 AM   #4 (permalink)
The Calibrator
And then we end up with a huge squish clearance making the motor more prone to detonation. Not only that but we weaken the piston crown and move the rings higher up on the piston exposing them to more heat.
Why not just get correctly designed pistons that work?
tunerguy is offline   Reply With Quote
Old 10-29-2006, 02:08 AM   #5 (permalink)
Damn. Another reason why that built motor of mine wasn't performing.
I had 16VE pistons, 1mm deeper valve reliefs, and a 1.5mm head gasket. Miko any idea what CR that probably ended up with?
ps: Is a domed piston like the 16ve or a flat top with pockets better? (Assuming you manage to get the same CR)
Sabre 200 Gxi is offline   Reply With Quote
Old 10-29-2006, 02:13 AM   #6 (permalink)
Jah Rastafari
You dont understand what I am telling you. The crown of the piston does not get thinner. Please take a look at a SR16VE piston and you will understand what I am shaving.
I did also say you could put in the piston and just put a slightly thicker gasket and get 12 to 1.
If someone could get a pick of a SR16VE piston I will try and brake down what I am saying,
Old 10-29-2006, 02:15 AM   #7 (permalink)
Jah Rastafari
The compression with the 1.5 mm gasket with Sr16VE pistons would be about 12.2 to 1 compression.
If you made the valve notches 1mm deeper after that the compression would be about 11.5 to 1 compression.
Old 10-29-2006, 10:05 AM   #8 (permalink)
Can you run 12.1 comp on sr20ve on 93 octane gas daily driver?
Thanks for the info
danilo20 is offline   Reply With Quote
Old 10-29-2006, 10:15 AM   #9 (permalink)
Jah Rastafari
yes you can
Old 10-29-2006, 10:26 AM   #10 (permalink)
Opssssss....
payu is offline   Reply With Quote
Old 10-29-2006, 10:27 AM   #11 (permalink)
Jah Rastafari
Originally Posted by payu
Opssssss....
did you put opsss
of did you mean oopssss
Old 10-29-2006, 10:52 AM   #12 (permalink)
you got it....
I am not a wizard jejejeje......
Old 10-29-2006, 10:53 AM   #13 (permalink)
I was just about to ask if you can run 12:1 compression on 93. I think this whole thread was a sign. haha.
Thanks Miko
92 NX2000 'Stock'- gone to a good home
92 Sentra SE-R 'Stock & So damn clean'
03 SRT-4 13.3@103mph
Current: 2002 BMW 325Ci
Originally Posted by XxToKeSxX View Post
When your a boss player, you buy the car to match the shoes bish... j/k
CenturyI is offline   Reply With Quote
Old 10-29-2006, 11:00 AM   #14 (permalink)
Jah Rastafari
I think the best options to get 12 to 1 compression with SR16VE pistons will be.
shaving 1mm off the top of the SR16VE piston
or
Putting on a headgasket that is .5mm thiker.
Old 10-29-2006, 11:26 AM   #15 (permalink)
Would these have any clearance issue if I upgraded the cams? Or would the 1mm off of the top take care of that?
Old 10-29-2006, 11:32 AM   #16 (permalink)
Jah Rastafari
The top of the piston has nothing to do with valve notches, The valve notche give the clearance and the Sr16VE pisotn was designed with the deepest valve notches because it was designed for the higher lift cams of the N1 and the shaved head of he N1 because the valves got closer because because of it.
Old 10-29-2006, 01:17 PM   #17 (permalink)
The Calibrator
Please specify if the fuel octane rating is ron or mon posting as lots of countries get 93 RON which is similar to like 89 PON in the USA.
There is now way on Gods earth that a engine will run on more than 11.5:1 on the 93 RON we have and even then you are pushing it. Det will set in when the motor builds a bit of carbon.
Mapped a car yesterday on 93 Ron compression is around 11.5:1 and it pings like a bitch with more than 12deg adv under 2000rpm, max timing at 8000rpm 24 deg.
Old 10-29-2006, 01:25 PM   #18 (permalink)
Professor Dingbat
Can you please show your calculations? Or at least the cc numbers you used to calculate?
I did this and I got 13.5:1.
I took the SR16VE as 11:1 and then changed the displacement and got 13.5:1 for 499.5cc displacement per cylinder. I used 41.8cc as the combustion chamber volume.
Old 10-29-2006, 01:26 PM   #19 (permalink)
They are talking about PON (RON + MON /2).
Old 10-29-2006, 01:45 PM   #20 (permalink)
Jah Rastafari
I am not where I have my calculations at this moment, but look at this.
DE 9.5 to 1 piston in a VE is 10.3 to 1 ( These are facts )
Standard SR20VE piston is 10.3 to 1 ( These are facts )
SR16VE piston in a DE is 11.7 to 1 ( These are facts )
20V piston is 11 to 1 ( still has a slight dish and some valve reliefs )
DE 10 to 1 in a VE is 11.3 to 1 ( completly flat no notches )
There is a direct corolation between the VE and DE which is about .8 more in compression.
If the SR16VE piston is 11.7 to 1 in a DE ( which is the thruth, example S14 200HP Autech car runs the SR16VE pistons with this compression.
You should get 12.5 to one with these pistons in a SR20VE.
I also got intouch with Clark Steppler about my finding and he backed up my figures with his calculations.
I only found this out by getting a few pistons and started shaving 1mm of of them.
#1 piston 1 mm off the dome
#2 piston 2 mm off the dome
#3 piston 3 mm of the dome ( this left me with a flat top piston with deep valve notches
The #3 piston with the valve notches added in had more ccs to it than the 20V piston because the valve notches are so deep in the SR16VE pistons
Y
