Hard to tell in 2d, as I can't tell how far forward it is relative to the hose just to the right of it, which should be the hot water return for the cold idle, but if it's coming off the hard line off the back of the thermostat housing, it's for your heater return hose. You'll find, and you'll see from the install writeups, that it's NOT the same size as the B13 hoses and you'll have to step it down.
Jer
'93 B13, etc.
do it over and over again?
