I bought a 34 inch belt and it works. This is with the stock VE crank pulley and the Mossey water pump pulley and stock power steering. I think the stock belt is just over 33. The 34 is a little bit on the big side so the ps tensioner is towards the end, but I think it should work just fine.
the inner pulley is the same as stock, the outer will be dferent. I had those #s before. Let me look... all else fails, I can size everything up when I get home.
