Old 11-06-2006, 03:13 AM   #1 (permalink)
seen the light
2.4VE
Ok so I've searched the VE forum and found nothing concrete so here's a thought.
I wanna stroke my baby and dont wish to shell out on an expensive 2.2 crank from Japan.
DET rods; Custom Pistons from the states;Darton sleeves for the block and a balanced etc. KA24 crank, machined to fit the VE block..
Just looking for some experience regarding this crank and making it fit...
cheers
Andy
HP11 VE - SOLD
BCNR33 GT-R - SOLD
HP12 20V family sedan.
S14 all motor track coupe in the pipeline
madandy is offline   Reply With Quote
Old 11-06-2006, 03:56 AM   #2 (permalink)
REV it up!!!!!
daxx's Avatar
Trader Rating: 36 (97%)
I dont know how much it would cost to machine the crank to fit and the reliablity after it is all done, it will all depend on the machinist and his/her process of doing it. I know you have to machine the nose and thrust bearings so it can fit. Just get a RE 92mm crank they go for about 1200USD. I have one on order but wont use it til Spring.
This is for you dad!!!In Loving Memory of JJR,09/23/2006.>>>CAPT. REV
U.I.O.G.D.
SR20DEEP in Vegas
96' SE-R Patience is a Virtue - Full all out wizadry on this build
Pro-tech Design
The Few, The Proud..The NRR
daxx is offline   Reply With Quote
Old 11-06-2006, 10:47 AM   #3 (permalink)
96mm stroke crank (left) stock sr20 8 counterweight (right)
This is SP COMPETITION MACHINE Inc. forum name nissanoholic. He might be able to help you out with a custom crank.
92 NX2000 'Stock'- gone to a good home
92 Sentra SE-R 'Stock & So damn clean'
03 SRT-4 13.3@103mph
Current: 2002 BMW 325Ci
Originally Posted by XxToKeSxX View Post
When your a boss player, you buy the car to match the shoes bish... j/k
CenturyI is offline   Reply With Quote
Old 11-06-2006, 07:27 PM   #4 (permalink)
seen the light
Damn I hadn't realised the 96mm crank was 4cw.
Daxx, what's this RE 92mm crank you refer to?
Old 11-06-2006, 08:56 PM   #5 (permalink)
REV it up!!!!!
daxx's Avatar
check out raceeng.com and look under sportcompact>crankshaft...it is there.
Old 11-07-2006, 01:41 AM   #6 (permalink)
ECU Hacker
heya andy - bored with thrashing evo's already? :P
(sorry off topic) hows the other ecu compare to the one you had in there?
cb_drift is offline   Reply With Quote
Old 11-07-2006, 12:37 PM   #7 (permalink)
seen the light
Hi dude,
The new ECU is majic. The VVL activation is seamless and the torque curve linear like a well sorted engine should have. I feel less inclined to rev the engine as hard now as it pulls so damn well from mid range! As for the EVO's & WRX's...they are still trying to work out how a P11 keeps whizzing by them lol.
I'm tossing up between a cheap stroking and bore kit or just to go with a big bore as per Andreas Miko's recommended set up. I just wont pay $NZD2000+ for a crank when I can have a block sleeved by Darton and buy custom pistons and make a bored 2.185L for basically the same price as the 2.2 crank alone!
Old 11-08-2006, 01:34 AM   #9 (permalink)
seen the light
I found the QR25 crank(sans balancer shafts) idea in a search. the dude said it was smoother than the Ka24 but yeah I agree...a lot of extra work for that extra cc - wrist pin heights, rod to strole ratio & all that guff I wont pretend to fully grasp. I like the idea of Miko's using a Darton sleeved block to 90mm, DET rods, or Eagle, and some custom pistons, modelled off 20V items, with deeper valve recesses etc. The extra Bore unshrouds the valves and as Miko says the nature of the bigger bore will maintain torque and power to high rpm - something I really like for pulling gears hard right to the end of the earth . I would, of course, invest in a balanced and lightened 8cw DE crank also
Old 11-08-2006, 02:15 AM   #10 (permalink)
15642uner
Ricer_X_01's Avatar
has anybody tried a 92mm bore yet? my buddy works/tunes for a local shop and says they've done a couple rwd sr20's.
Ricer_X_01 is offline   Reply With Quote
Old 11-08-2006, 02:28 AM   #12 (permalink)
Pat Pat Pat
I think Reg Cook has done a qr25 crank in a sr20, but he may be cagey about it if you ask him. Got to wave dollar notes in front of him before he will take you serious, otherwise he can be a bit gruff.
Evlnxr - 20v FTW.
EVLNXR is offline   Reply With Quote
Old 11-09-2006, 06:51 PM   #13 (permalink)
WASHED UP
I want to try that size bore,not too sure how the gasket might seat.But only one way to find out
Old 11-09-2006, 07:01 PM   #14 (permalink)
i love b13's !
Trader Rating: 22 (100%)
96mm crank, who makes this re ? thats a long fu*king stroke, with a 88mm bore and some 12:5:1 compression pistons and some gigantic valves would make one bad ass ve.
to bad im addicted to boost ;P. one day ill have a big cc ve :/.
stratton.
im back.......
Old 11-09-2006, 10:34 PM   #15 (permalink)
KIWI VE
KA24 crank is 96mm. It will be badass... bigger is better (mod for mod)
Franklin cams this... stock valve springs that...
I don't care I have a GTR
NAracer is offline   Reply With Quote
Old 11-10-2006, 12:14 AM   #16 (permalink)
Wil a VE head fit on a KA engine?
93 NX2K
Ivanx is offline   Reply With Quote
Old 11-10-2006, 12:17 AM   #17 (permalink)
i love b13's !
no it will not.
stratton.
Old 11-10-2006, 07:26 PM   #18 (permalink)
seen the light
You shut up you! 96mm Stroke + 90mm bore...I never said I wouldn't do it, just not too sure on all the pro's & con's...and the house is now on the market
Old 11-11-2006, 10:20 PM   #19 (permalink)
KIWI VE
Pro's... stupid amounts of turbo destroying torque.
Con's.. not having somewhere to live
