not really, the 16ve pistons are a point or so higher then the 20ve's.
you could swap your head onto a sr20ve if you have a healthy sr20ve laying around.
you could also swap in a sr20 8 counter weight crank and rods into your bottom end. just make sure you notch the pistons for the oil squiters.
search, theres alot of info on this board about sr20de/ves
stratton.
im back.......
