Old 11-08-2006, 01:33 AM   #1 (permalink)
SE-R
VE MAF Hotwire In and Out settings for SAFC
Hi,. I'm installing the VE MAF, and I need to know the setting for the VE MAF as the SAFC needs it..
I had read for DE MAF is 6 - 6 and for SR16 (Not sure which MAF it is) as 3 - 3.
Could anyone tell me if those would work for my SAFC II?
1992 Nissan Sentra SE-R SR20VE Swap ---> Sold
1995 Subaru Impreza GT
EJ20 + TD05 16G
CRSentra SE-R is offline   Reply With Quote
Old 11-08-2006, 01:37 AM   #2 (permalink)
Enemy of the stupid
In 3 out 6. Since you have the DE ecu. Or it could be backwards.
91 NX2000 VE forsale
http://www.drag240sx.com/
Old 11-08-2006, 11:53 PM   #3 (permalink)
SE-R
My current setting for the DE MAF with the SAFC is In 1 Out 1 and the idle is good. Should I just change it?
Old 11-14-2006, 05:08 PM   #4 (permalink)
NEOB11VE
mine is at 3 in 3 out, no problems
NEOB11 SR20VE
13.9@99.9mph-2.25 60ft
B11VE (VVL FUN)
macakin is offline   Reply With Quote
Old 09-15-2007, 10:57 PM   #5 (permalink)
Air Force SE-R freak!!!!!
Dick's Avatar
Trader Rating: 47 (100%)
Gonna bump this one up as I want to get my car drivable.
I am running a sr20de ECU and a N60 pink tag Maxima MAF. What should be in and out setting be at???
95' b14 SE-R: sr20ve/sr16ve N1 cams/BC S&R/SuperTech +1&2 valves/Fuji header/3" exhaust/Calum real time/N60 short ram with JWT POP/Gspec pully set/Fidanza fly/Gspec stage 3 clutch/B&M SS/Tien basics...
93' b13 SE-R: Miss shifted into 2nd after 15 minutes of driving...New engine now
95' 240sx SE: AEM intake with POP charger/ cat-back
www.rapidcustoms.com
Dick is offline   Reply With Quote
Old 09-16-2007, 02:09 AM   #6 (permalink)
VE POWWA
^^^^^ 4in 6 out.....just installed a n60 on mines.....
BOOST_HAPPENS
http://www.cardomain.com/ride/418842
rigged200 is offline   Reply With Quote
Old 09-16-2007, 02:17 AM   #7 (permalink)
Dick's Avatar
Thanx bud
Old 09-16-2007, 11:45 AM   #8 (permalink)
vz-r driver
sr16ve and sr20ve maf is the same 22680 5J000
THOR is offline   Reply With Quote
Old 09-17-2007, 09:36 AM   #9 (permalink)
Racing Addict
On an AFC Neo (I don't know if it's the same settings for an SAFC2), here is what I had used with a B14 ECU and an SR20VE MAF:
HW-14 in HW-6 out
It was the only setting with which the car was not running in limp mode. The manual also says that SR20VE-equipped cars are HW-14, so it is the correct setting.
Would these settings be different on the AFC Neo?
Not that it matters much for me anymore, since I now have a JWT ECU that is programmed for the VE MAF.
Matt
2001 Sentra SE/pp (SR20VE powered)
KrAsH is offline   Reply With Quote
