Old 11-08-2006, 11:29 AM   #1 (permalink)
not my president
how to wire in a VAFC to control the solinoids.
you can use the vafc to control the solinoids but you cant tune with it. i used it for about a week then switched to summit switches and got a safc. but for the bling factor of having 2 apex screens hanging out heres how to do it.
red-power
red-power
black-ground
brown-ground
green-tach(rpm signal)
gray-tps
Purple-solinoid signal input(from ecu if you have a vvl ecu)
Pink-solinoid signal output(to the solinoid)
wire the solinoids to have constant power and switched ground.
87------ to the solinoid
87a----
86------signal
85------ground
30------ground
i was asked for info on this and found my notes fromwhen i did my swap...
1992 nx2000:White: Sold
Danielle Wilson 2/10/07
Old 11-08-2006, 12:13 PM   #2 (permalink)
running mo' tings
i dont think it would be nessecary to add the vafc due to that its more for vtech and start fooling around with vvl soleniods. better off just going with the safc itself and save yourself a few $$$$
Tonynissan is offline   Reply With Quote
Old 11-08-2006, 03:39 PM   #3 (permalink)
not my president
i had one laying around....and it is possible to pick the vafc up cheaper than the greedy mss and if your lucky cheaper than the msd and th summit msu's
Old 11-08-2006, 04:24 PM   #4 (permalink)
BTCC VE Power
Trader Rating: 16 (100%)
so you can set it to whatever point you want?
KL0 P11 Sport
Surround Sound
My VE thread
Old 11-08-2006, 04:30 PM   #5 (permalink)
not my president
worked like that for me.......
