Old 11-09-2006, 09:32 PM   #1 (permalink)
Water Pumps Reveiled...
well i was just in the garage messin around late at night.. and started comparing some waterpumps, and though it would make for a good discussion. but anyways here were my findings...
here is a Roller Rocker sr20 water pump...
this is a 2.0 VE water pump...
here is a UK SR20 water pump.
this is where it gets interesting... and this is a factory oem water pump.
this is a SR16VE water pump.. looks like a 2.0.... but its not...
here is a side shot of the sr20 RR and the SR20ve water pump.
now here is the side shot of the SR16VE water pump... the blades are shorter in depth...
here is the SR16 and the SR20ve next together.
and for those who didnt know... the SR16 comes with a metal gasket instead of the silicone that all other sr20's have.
now all i can come up with is that the sr16ve water pump moves less water at lower rpm's than the 2.0's do. but in higher rpm moves the same at a higher rpm as the 2.0 does at 7500 rpm. i guess it all rounds out to be the same...but why in the hell does the UK have more blades than the standard DE or VE has, and whats with them being a straight design, versus the curved blades. The UK being the same block... shouldnt have the same cooling capacity as all other SR20's? or is an England thing?
so what you guys think?
THE VE-T IS ALIVE.
-92 sentra vvl-t 470whp...385tq. 24lbs.
-98 sentra SE/ sr2ve powered.
-2005 c230 kompressor.
-2006 Lancer Evolution 9 MR.
http://images.cardomain.com/member_i...66_28_full.jpg
your local asshole.
LanceSR20 is offline   Reply With Quote
Old 11-09-2006, 09:35 PM   #2 (permalink)
Talk about having a bunch of parts lying around. LOL!
-Rob-
Get ready for a big SE-Rprise
Old 11-09-2006, 09:39 PM   #3 (permalink)
Rob
someone bites their nails! lol
Old 11-09-2006, 09:50 PM   #4 (permalink)
SR20DEEP N.Y.C.
from the looks of it....the 20v and the de rr are the same part
SR20DEEP N.Y.C.
LOCK IT UP!
DEAD SE-RIOUS is offline   Reply With Quote
Old 11-09-2006, 10:28 PM   #5 (permalink)
yeah they seen to be the same. too bad i dont have a 91-94 water pump.. but i think it would be the same as the RR.
Old 11-09-2006, 11:22 PM   #6 (permalink)
SR20DEEP N.Y.C.
well good to know if the wp fail....can go str8 to the dealer
Old 11-10-2006, 12:07 AM   #7 (permalink)
I recently replaced the WP on my 93 NX2K it looked just like the UK pump. I can seen why this type could cause cavitation at high RMP.
93 NX2K
Ivanx is offline   Reply With Quote
Old 11-10-2006, 12:23 AM   #8 (permalink)
i love b13's !
Trader Rating: 22 (100%)
exactly what i was thinking, i can also see why it would cause cavitation. fin to fin being so close at high rpm i would imagine i would creat quite a vaccum (right word ? u know what im trying to say) at high rpm.
i wonder if there would be any way to alter the fins to increase the effeciency of the water pump.
im glad u posted this lance, now the next time i change my water pump ill be sure i dont buy the "apocolipse pump" (its late ;/ ).
stratton.
im back.......
Old 11-10-2006, 01:21 AM   #9 (permalink)
XxToKeSxX's Avatar
The conventional DE and Roller Rocker DE Water Pumps are the same... at least the lowports... I've compared them and found no dif...
There's my 2 cents!
1998 200sx SE-R | SR20DE
1991 NX-TuRBO | SR20DET
1995 240sx BaSe | ____DET
Shift_Buy Broken & Build...
Old 11-10-2006, 03:08 AM   #10 (permalink)
done
nevermind
Old 11-11-2006, 12:28 AM   #11 (permalink)
the proof wizard
Trader Rating: 26 (100%)
soo, after all this what would we say is the best water pump...
12sec NA
Old 11-11-2006, 08:11 AM   #12 (permalink)
Originally Posted by LanceSR20
. too bad i dont have a 91-94 water pump...
I have one here at home. I will bring it by today.
Old 11-11-2006, 12:28 PM   #13 (permalink)
well the best being to me is the 2.0 ve and the RR water pump. but i havent seen the 20v water pump yet, to know if it is better. the 20v is suppost to have more cooling capacity for the head is slightly different. it has larger water jackets that run through the head which keeps detonation in check. but i also think that the mezere electric water pump is far suppirior to all.
Old 11-13-2006, 10:07 AM   #14 (permalink)
why is the electric better?
anomaly is offline   Reply With Quote
Old 11-13-2006, 12:52 PM   #15 (permalink)
Guanaco Tuner
More flow, and maximum flow all the time (not rpm dependent).
Old 11-13-2006, 02:42 PM   #16 (permalink)
thank you.
