i agree with ^. shaving the head does serve a purpose but at the same time it throws alot of things off. timing of the cams and valve to piston clearance.
i would recommend getting higher compression pistons with deeper valve notches then oem (incase u ever get bigger cams).
its doable but there are better ways to raise compression then shaving the head.
hope ive helped.
stratton.
im back.......
