Originally Posted by coryb13ser
right, but whtat ecu were you using..
Doesn't matter what ecu I'm using. The sensor has to match the ecu YOU are using. If Calum's ecu tune is based off of the straight VE rom, then you use that.
I am running a Calum ecu, and I am running all USDM coolant sensors. Just double-check w/ him on your program requirements, but you should be fine w/ all USDM sensors and VE TPS & knock.
Josh
