Old 11-21-2006, 12:58 PM   #1 (permalink)
English SR20VE
Spark Plug Gap - Useful Information from an Expert
Here's an email from NGK
Hello again Paul,
Nice website. Very nice car. I was able to find some information on the plugs for the SR20VE. The original equipment stock plugs for this engine are BKR6E-N which is a .036” or 0.9mm gap setting preset from the factory. I would imagine that is what the stock gap for the engine is as well. Iridium IX BKR6EIX plugs will come new out of the box preset to .032” or 0.8mm. You may not want to gap any larger than .036” for maximum efficiency.
Kristopher Zdral
Technical Support Representative
NGK Spark Plugs (U.S.A.), INC.
First UK SR20VE
Sunderland Tyne&Wear-made P11 2.0GT
SR20VE (SR16VE ecu - VE Distributor)
www.sr20ve.co.uk BioEthanol fuel injector pulse modifier
NGK Iridium BKR6EIX
NGK Power Spark Leads 0.9/metre 04N 6057
ThermoBlok Spacers
Greddy MSS
Greddy Speed Cut
Fujitsubo Header
De-Cat
2" Mandrel Bent Stainless Exhaust
Hybrid Cold Air Ram
www.sr20ve.co.uk
pachadwick is offline   Reply With Quote
Old 11-21-2006, 01:55 PM   #2 (permalink)
Air Force SE-R freak!!!!!
Dick's Avatar
Trader Rating: 47 (100%)
Hello again Paul,
Kristopher Zdral
Good info man. I am running the BKR6EIX. I was told not to gap it anymore because it is a preset gap. Oh well.
95' b14 SE-R: sr20ve/sr16ve N1 cams/BC S&R/SuperTech +1&2 valves/Fuji header/3" exhaust/Calum real time/N60 short ram with JWT POP/Gspec pully set/Fidanza fly/Gspec stage 3 clutch/B&M SS/Tien basics...
93' b13 SE-R: Miss shifted into 2nd after 15 minutes of driving...New engine now
95' 240sx SE: AEM intake with POP charger/ cat-back
www.rapidcustoms.com
Dick is offline   Reply With Quote
Old 11-22-2006, 01:04 AM   #3 (permalink)
BTCC VE Power
Trader Rating: 16 (100%)
Hello again Paul,
Kristopher Zdral
i dunno about expert, but you run the largest gap you can without it blowing out
KL0 P11 Sport
Surround Sound
My VE thread
Old 11-22-2006, 01:46 AM   #4 (permalink)
My MR2 is making me cry
Trader Rating: 24 (100%)
Can you use just a regular BKR6E plug and not the iridiums?
JKho is offline   Reply With Quote
Old 11-22-2006, 08:32 AM   #5 (permalink)
Vz-r
I put the iridums in a theres a noticeable improvement..thats in a sr16ve but it reduced the backfireing and smooted out response at low revs..
some people have said the standard nissan plugs are better but i just dont agree i have ran both sets twice now and i know which works better
toffeapple is offline   Reply With Quote
Old 11-22-2006, 08:55 AM   #6 (permalink)
Is an SE-R/VE a VE-R?
I'm still running the original factory NGKs in mine, now at about 12,000m on the engine (Dre found one with 7500 on it) - I opened them up to .045 as I remember per the suggestions from MSD when I did the Digital6+ and 8207 coil. It's happy as a clam.
'93 B13, etc.
do it over and over again?
Old 11-22-2006, 10:08 AM   #7 (permalink)
BTCC VE Power
the more expensive plugs are not exactly better... i dont think you guys are getting better result because of the type of plugs, but because you are replacing them...
copper is the best conductor out there in terms of spark plugs.. however they do need to be replaced more often which is why ppl see an increase in performance when changed. Get coppers and just swap em out when you change your oil... the cost will be about the same.. an added benfit of doing this is that you will be able to see your plugs and check for how the engine is running
Old 11-22-2006, 12:46 PM   #8 (permalink)
I've heard that too, civicdragon. & thanx for the advice; this old wrench agrees.
Jer
Old 11-22-2006, 01:27 PM   #9 (permalink)
Cookin Up Some Snails
ive run my sr20de-t at 25, 35 and 40. and by far the car runs the best at 39-40 gap. it feels so much stronger.
rodrigo is offline   Reply With Quote
Old 12-01-2006, 04:55 PM   #10 (permalink)
i need money
[quote=pachadwick]Here's an email from NGK
I just got iridium ix for my car they were pre gapped at .44...
guy with a g20 is offline   Reply With Quote
Old 12-01-2006, 06:39 PM   #11 (permalink)
P10 pro
You probably got the Bk6eix-11 that's why it was pre- gapped at .44". The 11 stands for 1.1mm which equal to .44 inches.
5speed is offline   Reply With Quote
Old 12-02-2006, 09:52 PM   #12 (permalink)
VE-tec
werd.. very tru civicdragon
JaeAR 20 is offline   Reply With Quote
Old 12-02-2006, 10:05 PM   #13 (permalink)
I think that is a little too frequent if you go 3k oil changes, maybe every third oil change. Copper will definitely last at least 15000
2000 Black Sentra SE w/aPP
turco is offline   Reply With Quote
Old 12-02-2006, 10:08 PM   #14 (permalink)
BTCC VE Power
hmm well im used to turbo and you should change them that often... all motor you could prob get away with it
Old 12-02-2006, 10:40 PM   #15 (permalink)
Turbos eat copper plugs The stock wrx plugs at bkr6e's and need to be changed like every 8-10k miles. And that is NOT a car you want to frequently change spark plugs in.
Old 12-02-2006, 11:06 PM   #16 (permalink)
BTCC VE Power
good thing this isnt a wrx board and we have sr20's
Old 12-02-2006, 11:10 PM   #17 (permalink)
I know sorry i was agreeing with you
Old 12-03-2006, 12:56 AM   #18 (permalink)
agent camel toe
i ran br6's gapped at .50..re-gap *** and u will see the diff..i did change mines like every season though since their $5
nyce1s.com
R.I.P. RESPECT SR.
93 p10 jdm de--for sale
96 b14 det--for sale
89 formula--sold
next up is a minivan
Old 12-03-2006, 08:31 PM   #19 (permalink)
P10 pro
Is that with stock ignition or aftermarket?
