Old 11-23-2006, 01:40 AM   #1 (permalink)
SR20 POWA
VE QUESTIONS
i've seen on the net that some ve's have different valve cover colors like red and blue and they are the 20VE's...*** wondering if theres any difference...
also if the engine was once an AUTO..will it work with a manual...
which would be better and most easiest way to activate VVL solenoids...
what is IACV and AAC...
will standard b13 clutches work..
92 Sentra Se-R (VE powered)
duntmesswitda_s is offline   Reply With Quote
Old 11-23-2006, 02:02 AM   #2 (permalink)
SR powered S13 coupe
McCoy's Avatar
Trader Rating: 74 (100%)
Have you read through the technical library for the VE (it's located at the top of this section. It should answer all your questions. Also, think of the swap to an SR20VE the same as swapping SR20DE motors with a few minor electrical and hose connections.
http://www.sr20forum.com/neovvl-guides/
Old 11-23-2006, 01:26 PM   #3 (permalink)
Approved vendor
Trader Rating: 92 (100%)
definitely read all you can before doing anything. I'll try to answer your questions though.
The red top is the SR16VE N1
The blue top is the SR16VE non N1
The black top is the SR20VE
There is also the 20V and VET, but that's a different story.
A motor that was auto can be used in a manual by just swapping the flywheel in for a flexplate.
Use either a JWT ECU, Calumsult or Greddy MSS to activate the solenoids.
IACV is the piece bolted directly onto the manifold, and is necessary. The AAC is the piece in the backside of the manifold with 2 hoses attached. It would be nice to have, but not totally necessary (at least in Cali).
Std clutches work fine.
Greg V
RIP John and Danilo Get better Leon (93specv)
Like the old avatar?
Old 11-23-2006, 03:20 PM   #4 (permalink)
Is an SE-R/VE a VE-R?
Greg, not sure JWT modified DE ecu's switch solenoids - leastways that wasn't an option when I did mine; I used the MSD 8969. Methinks the JWT modified ecu is just remapped for the ve. Standard pressure plate likely a good idea, especially if the clutch cable brace to the back of the block isn't reinforced.
Jer
'93 B13, etc.
do it over and over again?
Old 11-23-2006, 03:27 PM   #5 (permalink)
BTCC VE Power
Trader Rating: 16 (100%)
you need to add the nitrous module to get the JWT to switch the cams
KL0 P11 Sport
Surround Sound
My VE thread
Old 11-23-2006, 03:28 PM   #6 (permalink)
Built not bought
http://www.sr20forum.com/mechanical-oem-part-outs/178175-vvl-head-f-s-parts.html
^^ BUILT BY BOLT^^^
Nyc Home of the greatest !!!!!!!!!!!!!
Nissanwulf is offline   Reply With Quote
Old 11-23-2006, 08:17 PM   #7 (permalink)
Ah - is the nitrous module as easily adjustable as the 8969?
Old 11-23-2006, 08:39 PM   #8 (permalink)
BTCC VE Power
no you have to send it back for reprogram just like the rest of jwt stuff you need to send it a
Old 11-23-2006, 08:51 PM   #9 (permalink)
eric96ser's Avatar
AAC and IACV are on the same part, on the front of the intake manifold. The part on the underside is the FICD.
1991 Sentra SE-R
The community is here.
Old 11-23-2006, 10:41 PM   #10 (permalink)
Built not bought
it is the 8969 digital
Old 11-23-2006, 10:48 PM   #11 (permalink)
Approved vendor
The FICD is also known as the Auxillary Air Regulator.
Old 11-24-2006, 02:06 PM   #12 (permalink)
Dunno if you meant that as a question, but yes, the 8969 is digital; changing the switch point is nothing more than a button push. You need two of 'em if you're going to switch the cams separately; Dre suggested with stock cams and my setup just turn 'em together at 4600. Here:
http://photo.angrylabs.com/main.php?g2_itemId=118
It's the little box sitting under the fender lip to the right of the pop charger.
OH - did you mean the jwt nitrous module is nothing more than an 8969?
Old 11-24-2006, 03:11 PM   #13 (permalink)
Built not bought
i have one i meant and i *** it is digital sorry for the confusion it is for sale in my post.
Old 11-24-2006, 08:27 PM   #14 (permalink)
Ah. They're bulletproof; if the guy needs one and your price is right that would be the place to get it. :-)
Jer
Old 12-11-2006, 01:01 PM   #15 (permalink)
SR20 POWA
*** wondering about the MAF...will the DE MAF work fine...i seen something about using a maxima MAF but the harness is difference..will i have to rewire.....also after engine is in will it have to get tuned or is it optional..
Old 12-11-2006, 01:39 PM   #16 (permalink)
the proof wizard
Trader Rating: 26 (100%)
that all depends on what ecu you plan on running. you can use your stock maf/injectors along with your stock ecu if you want. other wise you will get a ecu programed for whatever maf you plan on running.
12sec NA
Old 12-11-2006, 01:44 PM   #17 (permalink)
BTCC VE Power
i wouldnt run stock injectors as there is a 70cc difference in stock de and stock ve injetors
Old 12-11-2006, 05:43 PM   #18 (permalink)
huh?
Ric
VePwrd 97 Se-r (jwt free)
VqPwrd 07 Fronty
Teal97 is offline   Reply With Quote
Old 12-12-2006, 10:51 AM   #19 (permalink)
Hostile Aberration
Shawn B's Avatar
Check this out, it answers pretty much all your questions:
http://www.sr20forum.com/new-members/149841-search-tips-hjbarker-crew.html
