The trannies interchange, as the SR16VE is identical to the SR20VE but for the crank, pistons, and rods.
As for the SR18 being interchangeable, if it runs an 86mm bore (like the SR16 and SR20) then it should be as interchangeable as any other first gen FWD SR block, meaning "kinda" with work.
Also not sure if this has been covered either but I have seen bluebird / pulsar gti-r engine+tranny for sale at a couple different sites now offering a FWD or AWD tranny??
Are they starting to include FWD SR20DE trannies or is this some other FWD tranny that is useless to us sentra/G20 folks?
Thanks,
Chris
Yes, slightly tougher but it is a hassle getting everything to fit. Custom engine mounts, modified driveshafts, GTiR spec flywheel, hydraulic clutch conversion, etc
