hey guys, would it be possible to make a 1.8ve by using the crank etc etc outa a
sr18de?, iv gt a 16ve and was *** wonderin if this **** be poss, or am i *** talkn
crazy
crazy
thoughts and feedback much appreciated
I don't know if you can do that.
I know you can throw in SR20DE crank (need correct rods and pistons ***) to get a 2.0L motor.
well andreas you said the sr18de uses the same crank as the sr20de, so i would assume the rods are the same as a sr20de also? so he could use his sr18de crank and rods to stroke his sr16ve to a 2.0, i think thats what he was asking, but he assumed the sr18de had a shorter stroke, instead of a smaller bore. not to do a head swap which i think you were thinking?
If you want an sr18ve yes you can get a bigger crank; but as everyone said the cranks are the same. Andreas said the pistons of the sr18de are smaller therefore the answer to your question is no. If you wanted to make a sr18ve you need 90mm pistons(sleeve block) or a bigger crank(you would need to calculate size)
Use SR16VE block
Sleeve block for 90mm pistons.
Use SR16VE crank
Use SR16VE rods.
This is a no brain operation. Send out the stock SR16VE piston to J&E, tell them to up size the piston from 86 mm to 90 mm. Make sure to tell them not to change the size of the dome to compensate for the larger piston to keep the same compression. Tell them you know what the compression is with the sock piston which is 11 to 1 compression and you want the piston to be 11.8 to 1 which is about what the compression will be with the upsized SR16VE piston at 90 mm.
Below is his question
crazy
His title for this thread is SR18VE. He clearly states that he wants to make a SR18VE in his post above not a SR20VE. As stated by me he can not do so by using SR18DE parts as the piston bore is way to small.
A SR18DE head is alot like a SR20DE head with a vew changes.
1. SR18DE head has way smaller valves so not to hit the cylinder walls of the 82mm bore.
2. SR18DE cumbustion chamber is alot smaller to make up for the smaller motor to get the right compreshion.
probably wouldnt be the greatest idea, compression might be too high for pump gas, when considering the sr16ve pistons with the 86 mm stroke (sr18/20de crank) but it would net you the 2.0ve
um, do you guys not understand that i was not wanting to make a 2L ve motor, but infact a 1.8L ve, does the title of the thread not indicate this properly??? besides andreas has already answered the question i originally posed. I dnt know *** the highest octane rating of your fuel in the states is anyways but over here in new zealand the highest we can get is 98 octane, which is pretty high for pump gas
Westie, how octane is calculated in the US verses most everywhere else is different... just for your reference. I know there are a couple of posts on the forum that talk about it, it would just require a search.
Also, why are you so excited about having an SR18VE, just to be different?
98 RON is not 98 octane.
The MON is probably around 86 so that would give an octane rating of (98+86)/2 = 92.
