Andreas would probably be the man to answer this but, I'll try. When you put the 2.0 crank in the 1.6 you use the 2.0's rods and pistons. The main reason for stroking the 1.6 is that it has better cams as compared to the 2.0. I would imagine the 1.6L rods would be too long to use with the 2.0 crank. My $.02
Added quote from Andreas
"The SR20VE and SR16VE have the same bore 86mm but the pistons are diffrent. SR20VE has a 4cc dish and the SR16VE has a dome. If you put the SR16VE piston in a SR20VE it will give you 14-1 compression. The heads are the same, cams are diffrent, rod length is diffrent and crank is diffrent. "
