Another So. Fla. Dyno run - SR20 Forum
Old 12-21-2006, 08:31 PM   #1 (permalink)
SE-R Driver
http://img.photobucket.com/albums/v6.../06DynoRun.jpg
STU Yellow Sentra SE-R, So. Fla.
VVL Powered!!! Road Racer
Synergy Florida Insoles LLC.
772.336.6452
www.synergyinsoles.com
Andy R. is offline   Reply With Quote
Old 12-21-2006, 08:37 PM   #2 (permalink)
eric96ser's Avatar
Feedback Score: 29 reviews
I call fake. You didn't make 200whp.
The community is here.
Old 12-21-2006, 08:46 PM   #3 (permalink)
The Genesis
Feedback Score: 12 reviews
^HAHA
Dork!
Old 12-21-2006, 08:46 PM   #4 (permalink)
SE-R Driver
Excuse me. All stock no cams. Oh! and a Gen 6 race header.
Old 12-21-2006, 08:47 PM   #5 (permalink)
The Genesis
^what other mods?
Old 12-21-2006, 08:56 PM   #6 (permalink)
SE-R Driver
I had a whole mod thing typed and lost it during the post. Hate that.
anyway, JWT road race tune 100 Oct race fuel
Hotshot CAi
outlaw eng. thermol intake insulator
3" ex turned to the side
20* timing
46 psi fuel press with Nismo fpr.
as for the fuel ratio there has to be an exhaust leak somewhere. The numbers are too good to be actually leaning out.
Old 12-22-2006, 01:27 AM   #7 (permalink)
Hotshot CAi
20* timing
Its probably leaking at the flex if its hitting your crossmember. I know mine is leaking from that spot.
91 Nissan Sentra SE-R: KYB AGX's, eibachs, prothane mounts, ES suspension bushings, addco RSB, FSTB/RSTB, CAI, JWT C2/ECU, 3in B-pipe, UR UDP, nitrous
Best ET: 13.57 @ 99mph
Nismo87SE is offline   Reply With Quote
Old 12-22-2006, 06:25 AM   #8 (permalink)
SE-R Driver
The flexpipe is ok. The copper gasket maybe the culprit. I have to put it up on a lift to listen at idle if there is a leak.
Old 12-22-2006, 08:27 AM   #9 (permalink)
eric96ser's Avatar
I was joking. 187whp is god with stock cams and your mods.
Old 12-22-2006, 09:16 AM   #10 (permalink)
SE-R Driver
Originally Posted by eric96ser
I was joking.
I know Eric.
There is still a slight power loss after cam activation which coencides with the leaning out. There is still more in it with somemore tuning. I have to stop the exhaust leak and find out the actual reading.
Old 12-22-2006, 09:51 PM   #11 (permalink)
VE-T tester
Feedback Score: 3 reviews
Man I would love to feel that car. My SEL only got 170whp up here in Utah. High flow intake filter, uh, jwt flywheel, ssac header, and stock everything else. I am sure if I weren't at 4000 ft I would get better numbers.
99 SE-L. Graphite Gray GT3076R .78 Twin scroll turbo, Custom Twin scroll tubular manifold, 3" all the way! Nismo FPR 740cc, 255 pump, JWT computer. Dyno soon!
Coheed is offline   Reply With Quote
Old 12-22-2006, 10:38 PM   #12 (permalink)
Feedback Score: 6 reviews
ive seen almost all VVLs make 180+ with basic bolt ons. Its nothing new. Congrats on your numbers, sr16 cams with some cam gears will give you about 12-15 additional whp. Do the math.
danilo20 is offline   Reply With Quote
Old 12-23-2006, 08:04 AM   #13 (permalink)
All of our stock cammed VE cars down here are well into the 180's.
Good #'s Andy. Andy would you consider adding a S-AFC for tuning? You will be very serprised how it could help. I am not sure if it is allowed for you to use one in your race group.
SR20Deep
~2012 Convention Info Thread~
http://www.sr20-forum.com/sr20-natio...tion-info.html
Check us out on Facebook
http://www.facebook.com/pages/2012-S...=wall&filter=2
Old 12-23-2006, 02:43 PM   #14 (permalink)
SE-R Driver
I am curious. Why is that the Hotshot Gen 6 ON THE VVL motors are not well received? Even Mike K. Is not thrilled about it.
What would be the better header to use on a stock motor? Without argueing 3hp difference. I mean a significant hp difference. Has anyone made more than 189hp?Stock motor with external bolt on. Include # with an S-AFC as SE-Rican, said.
Old 12-23-2006, 02:52 PM   #15 (permalink)
fu*k you.
Feedback Score: 16 reviews
Why would an exhaust leak affect the AF ratio...
Old 12-23-2006, 03:08 PM   #16 (permalink)
SE-R Driver
O2 sensors sense the amount of oxygen in the exhaust stream. If there is a leak before the sensor, oxygen is introduced affecting the READINGS not the actual engine air fuel ratio.
