The VE Dyno Post - Page 3 - SR20 Forum
Old 01-16-2009, 03:12 AM   #41 (permalink)
Feedback Score: 13 reviews
Mine as well put it in the books. A few changes since then, hoping to have a new dyno sheet up soon.
Engine: SR20VE
Cams: SR20VE (N1)
Intake:Pop-Charger Ram-Air
Header:SSAC (2.5)
Exhaust:3icnh vrs
ECU:Calum Realtime
Intake/Exhaust:5300rpm
Dudeman
Old 02-03-2009, 06:59 PM   #42 (permalink)
Nerdy Dirty Asian
Feedback Score: 5 reviews
dudeman, did you ever get your numbers up? I have not taken my car to the dyno, but it seems that the car is not as fast as I envisioned. I have all fo the same mods, ecxept that I have a crush bent 2.25" catback.
Engine: SR20VE
Cams: SR20VE (N1)
Header:SSAC (2.5)
Exhaust:3icnh vrs
ECU:Calum Realtime
Dudeman
2000 G20t GT28RS
purekoryo is offline   Reply With Quote
Old 03-15-2009, 11:24 PM   #43 (permalink)
P10 pro
Feedback Score: 8 reviews
So here’s the setup on the 54k miles stock block 2.0.
Pistons: 20v 11:1 compression
Cylinder head: valve job by Portflow
Cams: N1 intake, Franklin S4 exhaust
Exhaust: 2.5” full exhaust with twinloop muffler and straight pipe
Header: modified 2” 421 Ebay header , collector and flex pipe were left alone, they are still 2”
Intake: Place Racing warm air, de maf, akimoto funnel air horn
Ecu: Calum Basic
5speed is offline   Reply With Quote
Old 05-09-2009, 11:28 PM   #44 (permalink)
Enjoying the Ride
happynole's Avatar
Feedback Score: 85 reviews
A friendly family rivalry has begun:
SE-R:
Engine: SR20VE
Cams: N1 with CS gears @ 0,0
Intake: N1 tb, ASP modified N1 manifold, OEM cai & JWT popcharger
Header: ASP Super Freak 4-1 header
Exhaust: 3" OEM
ECU: Calum basic
Intake/Exhaust: 5600/6300
NX:
Engine: SR20VE
Cams: N1 with CS gears @ +5,-5
Intake: SR20VE with OEM wai & JWT popcharger
Header: ASP Budget 4-2-1 header
Exhaust: 2.5"
ECU: JWT
Intake/Exhaust: 5100/5100
I am confident that neither car is up to potential yet. I am waiting on some Calum RealTime ecus and then we will hit the rollers again. The interesting thing is that the from 5200-6400 the NX puts up a better number, but the SE-R pulls stronger and will just walk away from it. You can really feel the difference the Freak header and intake make above 7000. It just keeps on pulling all the way to fuel cut.
BTW, my STD corrected numbers are:
SE-R = 211.2 hp & 150.8 tq
NX = 187.0 hp & 148.6 tq
Vail White 93 SE-R......................what's a Sunny?
Pearl White 95 Primera.................the Yin to Sunny's Yang
Life is a Journey, Enjoy the Ride
SR20DeepSouth
http://www.datsun.org/roadster/liter.../dream_grg.mov
Last edited by happynole; 05-09-2009 at 11:52 PM. Reason: Added higher STD numbers for comparison
happynole is offline   Reply With Quote
Old 05-10-2009, 05:43 AM   #45 (permalink)
forgot to post mine up, only changes are asp budget headers and 3" exhaust with a retune to suit
Engine: SR20VE
Cams: N1 with JWT gears @ +2.5,-2.5
Intake: pod filter
Exhaust: 3"
ECU: Nistune
Intake/Exhaust: 5500/5500
Lonewolf1983 is offline   Reply With Quote
Old 06-20-2009, 07:13 PM   #46 (permalink)
Feedback Score: 40 reviews
SE-R:
Engine: SR20VE
Exhaust: 3" OEM
ECU: Calum basic
NX:
Engine: SR20VE
Exhaust: 2.5"
ECU: JWT
This makes me want that 4-1 more then ever!!!! I'll be getting one soon....
91 SE-R: SR20DE (soon to be stock)
jonwepa is offline   Reply With Quote
Old 08-04-2009, 05:45 PM   #47 (permalink)
vz-r driver
sr20ve motor
sr20ve stock cams
fidanza 8.5lbs flywheel
jwt pop charger
n60 maf
Calum basic ecu
ssac 2.5 header
3" exhuast
B15 stock clutch
A.C.T. HD Pressure plate
poly mounts...front and back only
obx Forza oval pan
Andreas Mikos knowledge.......
Calum basic, N60 maf, N1 cams, Greddy mss, JWT cam gears, ssac 2.5" header, 3" exhaust, Vibrant oval pan, ES bushings, JWT popcharger, B15 stock clutch disc and A.C.T. HD pressure plate, 8.5 lbs Fidanza flywheel, gt-s tranny, Prothane E/Mounts, Vz-R front seats, TEIN HA coilovers 197whp/146wtq
THOR is offline   Reply With Quote
Old 08-06-2009, 05:50 PM   #48 (permalink)
on 7th day God made SR20
Originally Posted by THOR View Post
sr20ve motor
sr20ve stock cams
jwt pop charger
n60 maf
Calum basic ecu
ssac 2.5 header
3" exhuast
B15 stock clutch
obx Forza oval pan
Thor, Those are great numbers. Wish I had that kinda power. Would sure be in the 13 sec on the 1320.
Peace
No Boost, No Bottle, Just my 60mm throttle...
Raggy is offline   Reply With Quote
Old 08-07-2009, 11:41 AM   #49 (permalink)
vz-r driver
hoping to be.....
Old 08-11-2009, 02:40 AM   #50 (permalink)
Feedback Score: 6 reviews
Nissan ALMERA 99 VZR CONVERTION
ENGINE: SR16VE STROKED TO SR20VE (SR20DE CRANK AND RODS)
MOD LIST:
CR: 12.5:1 with CP PISTONS std size.
3 ANGLE JOB, PORT&POLISH
CATBACK 3" NO CAT, 3" in 4" out MAGNAFLOW MUFFLER
STOCK HEADER with Modified 2-INTO-1 SECTION
FIDANZA FLYWHEEL
XTD CLUTCH
ACL RACE BEARINGS
NISMO RADIATOR CAP
NISMO THERMOSTAT
3" WAI with 3.5" SIMOTA AIR FILTER
Q45 MAF
RACECAR.CL ECU 8000 rpm revcut, no speed limit, SR20VE N1 CAMS 20DE MAF bin
SAFC II
VTEC CONTROLLER (4900 RPM)
LSD SR20DE with SR16VE final ratio gearbox
Cusco shocks with custom coil over
16" momo rims
VZR rear brake rotors and calipers
SR16VE CAMs (NON N1)
ARP ROD bolts and studs
Stock header rulez!
'95 SENTRA SS SR16VE in progress TDAY edition
http://www.cardomain.com/ride/2453804 <- my sentra ^^
¿Dudas con tu nissan? Ubicame en kb_ssr@hotmail.com o al 820 93 915
PuPPiesonAciD is offline   Reply With Quote
Old 08-11-2009, 10:54 AM   #51 (permalink)
No Tune = No Life
Feedback Score: 7 reviews
Congratulations friend!!!
alfsentra is offline   Reply With Quote
Old 08-19-2009, 10:29 AM   #52 (permalink)
Stock SR20VE
Green Storm filter (used)
DE 4-2-1 header
DE exhaust front to back
Magnaflow muffler
ECU optimised because of 5 spd manual instead of auto.
VVL intake 4700 rpm
VVL exhaust 4900 rpm
http://i110.photobucket.com/albums/n...sr20vedyno.jpg
Im satisfied, knowing that replacing the small SR20DE exhaust system + header will free up some more horses and Newtons
DaMasterPNut is offline   Reply With Quote
Old 10-02-2009, 01:27 PM   #53 (permalink)
Engine: SR20VE
Cams: SR16ve (stock 20ve cam gears)
Intake: JWT pop charger
Header: SSAC with custom 2" secondaries and 2-1 collector
Exhaust: Custom 3"
ECU: Calum Basic
Intake/Exhaust: 4600/4600
Drive train: SR18 Tranny/16ve FD/ACT HD pp w/ Exedy OEM disc
Old 11-11-2009, 10:28 PM   #54 (permalink)
vz-r driver
Originally Posted by Raggy View Post
Engine: SR20VE
Exhaust: Custom 3"
ECU: Calum Basic
very nice numbers too man..... waitin now for the 13 sec. pass
Old 03-11-2010, 08:44 AM   #55 (permalink)
213KM / 227 Nm
Engine: SR20VE
Cams: SR16VE
Pistons: SR20VE
Limiter 8300
Exhaust: 2,5" OBX- R Racing
SMT6,SSAC 4-2-1
213,4 KM/227 Nm/275 km/h, 60ft 2.436, ET 14.831
With SR16VE cams my SR20VE works like that:
tomjedrz is offline   Reply With Quote
Old 07-12-2010, 02:02 AM   #56 (permalink)
those are some nice numbers man good job
s14sidewayss is offline   Reply With Quote
Old 09-13-2010, 03:46 PM   #57 (permalink)
Hi , another project started here in PR
had the car three months and up till now this is what has been done so far:
sr20ve
n1 cams
bc springs and retainers
budget header
very bad home made intake with stock maf
custom tune throught reflash
2.5 ehaust.
tri-y header and n1 intake and throttle are possibly going in this week... I'll keep you posted
morris759 is offline   Reply With Quote
Old 09-23-2010, 08:13 AM   #58 (permalink)
custom sr20ve
hey guys, good figures! I just swapped sr20ve head to my engine last week. Cant wait to dyno n post mine up too
an article about a funny forum (MUST READ)
http://timelesscomments.blogspot.com...ous-forum.html
b14bot is offline   Reply With Quote
Old 10-29-2010, 07:18 PM   #59 (permalink)
1993 NX2000 with VE
Just dynoed my car today and I was happy with the power it made. First pass was 200.1 hp and after a quick tune on my safc-2, it made 209 hp.
Engine: sr20ve
N1 Cams
ASP Headers with 3 Inch Collector
VRS Full 3 Inch Exhaust
Cams set to 5800
MSD 6al
Apexi S-afc2
JWT ECU
Supertech Springs and Retainers
ACT Clutch - Stock Flywheel
MrRicanLink03 is offline   Reply With Quote
Old 10-30-2010, 07:36 AM   #60 (permalink)
Feedback Score: 17 reviews
What kind of AFRs gave you the best power?
