Old 10-25-2007, 10:55 PM   #21 (permalink)
coryb13ser
the proof wizard
Trader Rating: 26 (100%)
Originally Posted by THOR View Post
i see a drop where the cams are set to engage.... do u think that if u trigger them independent that it would be smoother there...... at the 5700k mark???
yea switching them indedpendantly would smooth it out a bit. i dont car, i just raised it to 6k...
12sec NA
Old 10-26-2007, 11:01 AM   #22 (permalink)
Setzer
DVNO, 4 capital letters.
Hmm i should really get the graphs of our 50k mile ve with sr16 cams making 214whp on the packs. I'll post back Monday.
Old 04-05-2008, 06:58 AM   #23 (permalink)
lschew
just done the conversion recently and the dyno yesterday.
188.6 front wheeled hp @ 7000rpm
150 ftlb @ 7000rpm
lschew is offline   Reply With Quote
Old 04-14-2008, 07:03 PM   #24 (permalink)
Yellow4g63
Enemy of the stupid
Run 65= Franklin cam 67= N1 cam
Franklin cams S3 vs N1 same day dyno's cam gears set to zero timing stayed the same. It was about 40min apart and reved to 9k. no reprogramming same program for both cams. In a nut shell they are just the same like they said.
91 NX2000 VE forsale
http://www.drag240sx.com/
Old 04-14-2008, 07:13 PM   #25 (permalink)
jer_760
Broke Ass
jer_760's Avatar
It's amazing how close those are! What were the switch points?
95 200sx
sr20ve
Old 04-14-2008, 07:18 PM   #26 (permalink)
Yellow4g63
Enemy of the stupid
I forget what we had, I think it was like 5k for intake and 5300-5400 for the exhaust. They stayed the same during both dyno runs.
Old 04-15-2008, 05:47 PM   #27 (permalink)
5speed
P10 pro
The FS3 are advertised as N1 copy. The runs were 40 minutes apart with no change to timing, fuel, or activation points. The N1 ran a tad bit richer. As you can see by the dip at 5,000 rpm, the intake was kicking in too early.
5speed is offline   Reply With Quote
Old 04-15-2008, 05:59 PM   #28 (permalink)
Yellow4g63
Enemy of the stupid
Same runs just with the correction factor set to STD not SAE
Old 04-16-2008, 12:43 AM   #29 (permalink)
jer_760
Broke Ass
jer_760's Avatar
Yea, I knew they were advertised as N1 copies but we haven't had any actual proof until now. There were measurements taken that showed they were actually pretty different than the N1's IIRC, but no proof. It's nice to finally know for sure. What was the price of the Franklins again?
Old 04-16-2008, 06:04 AM   #30 (permalink)
Lonewolf1983
$680NZ plus freight, plug it into your currency calc.
pretty good value i think.
Fcams website still confuses me.
Lonewolf1983 is offline   Reply With Quote
Old 04-17-2008, 07:33 AM   #31 (permalink)
myprojectB13
myprojectB13's Avatar
Trader Rating: 16 (100%)
Nice work.
Jonathon
1996 G20
1993 SE-R 13.66@101
Old 04-29-2008, 08:50 AM   #32 (permalink)
Lonewolf1983
Engine: SR20VE
Cams: SR20VE
Intake: generic pod filter
Header: xforce 4>2>1
Exhaust: 2.5"
ECU: retuned sr20de
Intake/Exhaust: 5000/5000
this is a hub dyno.
apparently it intermittently doesnt want to rev past ~7200rpm, possibly a faulty CAS according to the tuner.
Old 06-16-2008, 12:25 PM   #33 (permalink)
alexhs
My friend's SR20VVL in Taiwan
Using P12 CAM , N1 intake,Fuji down pipe , Fcon vpro ...etc.
alexhs is offline   Reply With Quote
Old 08-20-2008, 11:42 AM   #34 (permalink)
Lonewolf1983
Engine: SR20VE
Cams: N1
Exhaust: 2.5"
ECU: retuned sr20de
Intake/Exhaust: 5200/5200
graph shows difference between std sr20ve cams and n1's.
cam timing set at +-2.5deg
