The VE Dyno Post - SR20 Forum
Old 01-22-2007, 01:32 PM   #1 (permalink)
myprojectB13's Avatar
Feedback Score: 17 reviews
The VE Dyno Post
98sr20ve
http://www.sr20forum.com/showthread....cams+switching
Engine: SR20VE
Cams: SR16VE
Intake:
Header:
Exhaust:
ECU:
Intake/Exhaust:
Andreas Miko
http://www.sr20forum.com/sr20ve-sr16ve/150324-started-204-hp-20v-blue-94-ser-03-22-06-a.html
“20V 204 HP Motor
Custome Intake Manifold
N1 TB
N1 cams
Electric Water Pump
JWT ECU
Maxima MAF
MSD Digital 6
MSD Blaster Blue Coil
Ultra Wires
Light Weight Battery
Custom made 4 into 1 header
Full Stainless 3 inch Exhaust With N1 Muffler
Fidanza Flywheel
Greg V Pully
94-96 G20T tranny”
Engine: SR20VE 20V
Cams: N1
Intake: CAI
Header: Custom 4 into 1
Exhaust: 3”
ECU: JWT
Intake/Exhaust: 5400/5400
Andy R.
http://www.sr20forum.com/sr20ve-sr16ve/181402-another-so-fla-dyno-run.html
“JWT road race tune 100 Oct race fuel
Hotshot CAi
outlaw eng. thermol intake insulator
3" ex turned to the side
20* timing
46 psi fuel press with Nismo fpr.”
"The header is a gen 6. Cam switch over is 5300 RPM intake & exhaust. SR-16 gearbox."
Engine: SR20VE
Cams: SR20VE
Intake: CAI
Header: HS Gen 6
Exhaust: 3”
ECU: JWT
Intake/Exhaust: 5300/5300
billc
http://www.sr20forum.com/sr20ve-sr16ve/107969-ve-dyno-chart.html
http://www.sr20forum.com/sr20ve-sr16ve/107948-ve-dyno-results-reveal-troubles-2-a.html
“Check the link to see a dyno comparison of VE on low cams only with VE switching at 4400 RPM (intake) and 4600 (RPM) exhaust. The set up being run is SR20VE cams, DE MAF, VE injectors, Fuji, HS CAI, and 2.5" exhaust (VRS and Magnaflow).”
Engine: SR20VE
Cams: SR20VE
Intake: HS CAI
Header: Fuji
Exhaust: 2.5”
ECU: JWT
Intake/Exhaust: 4400/4600
BORNGEARHEAD
http://www.sr20forum.com/showthread....hlight=dyno%2A
“sr20ve
warm air intake
Hotshot Gen 6 header w/3" collector
3" catco cat
3" VRS exhaust w/resonator
thermoblok intake spacers
sr16ve ecu
fidanza flywheel
unorthodox crank, water pump, alt. pulleys
no p/s, no a/c
msd digital window switch set at 5300 rpm”
Engine: SR20VE
Cams: SR20VE
Intake: WAI
Header: Hotshot
Exhaust: 3”
ECU: SR16VE
coryb13ser
http://www.sr20forum.com/sr20ve-sr16ve/190993-just-got-off-dyno.html
"intake
n60maf
calum ecu
ssac 2.5 header
3in vrs exhaust
nismo fpr
msd switches @ 4800"
Engine: SR20VE
Cams: SR20VE
Intake: WAI
Header: SSAC w/ 2.5" secondary
Exhaust: 3"
ECU: Calum daughterboard
Intake/Exhaust: 4800/4800
http://www.sr20forum.com/sr20ve-sr16ve/195798-dynoed-again-sr16-cams.html
Engine: SR20VE
Cams: SR16VE
Intake: WAI
Exhaust: 3"
engine: sr20ve
cams: N1
intake: 3in wai
header: custom 4-1
exhaust: 3in
ecu: calum daughterboard
intake/exhaust: 5700
http://www.sr20forum.com/sr20ve-sr16...g-results.html
Cup Driver #21
“Fujitsubo Exhaust Manifold
3 inch intake piping
Dirty K&N Filter
94 SE-R wiring Harness (Only B15 harness are the tail lights)
JWT tuned ECU for SR20VE, 91 Octane, DE TB/MAF
3 Inch Exhaust with Dynomax Bullet Muffler (if you call it that)”
Engine: SR20VE
Cams: SR20VE
Intake: WAI
Header: Fuji
Exhaust: 3”
ECU: JWT
Intake/Exhaust:
Dick
“MSD 8969 set at 4400 RPMs
DE TPS set at .5 off and 4.25 on
DE throttle body
DE dizzy
97 Maxima MAF
E-bay 3" Maxima ram air intake
JWT pop charger
Fuji header
no cat
3" VRS SS tubing kit with Magnalflow 5x8 muffler and 18" resanator
OBD2 G20 ECU
Apexi S-AFC 1
Clutchnet lightweight flywheel +clutchkit”
Engine: SR20VE
Cams: SR20VE
Intake: WAI
Header: Fuji
Exhaust: 3”
ECU: OEM w/ SAFC
Intake/Exhaust: 4400/4400
Eric-NX2K
http://www.sr20forum.com/sr20ve-sr16ve/190626-should-i-disappointed-dyno-results.html
"SR20VE
SR16VE Cams
Hotshot Header gen 6 - 3 Inch exhaust
Maxima MAF
Calum ECU / custom program
MSD controller"
Engine: SR20VE
Cams: SR16VE
Intake: WAI
Header: Hotshot Gen6
Exhaust: 3”
ECU: Custom ROM
Intake/Exhaust:
gio94sr20
http://www.sr20forum.com/sr20ve-sr16ve/149669-local-ve-powered-se-r-puts-down-some-powa.html
“SR20VE
SR20VE 20 V Pistons with SR20VE rods (11.1 compression)
SR16 cams
Jun Ultralight flywheel
JWT Cam Gears
Stillen header ports matched a bit to fit the head
3" exhaust
Pep Boys filter on VE rubber intake arm
OEM Chipped ECU
S-AFC
Walboro 255L fuel pump with OEM FPR”
Engine: SR20VE (11:1 compression)
Cams: SR16VE
Intake: WAI
Header: Stillen
Exhaust: 3”
ECU: Custom ROM & SAFC
Intake/Exhaust: 5100/5100
JustinP10
Engine: SR20VE
Cams:
Intake:
Header:
Exhaust:
ECU:
Intake/Exhaust:
LanceSR20
http://www.sr20forum.com/sr20ve-sr16ve/168529-gettin-some-head-7.html
Engine: SR20VE w/ 20V head
Cams: SR20VE 20V?
Intake: WAI
Header: Fuji
Exhaust: 3"?
ECU: Stand alone
Intake/Exhaust:
matt20v
“n1 intake and tb, thermoblock spacers, 20v cams , jwt valve springs, tomei cam gears, jwt ecu w/cobra maf,Greddy E-manage, wai, topspeed header, 2.5 exhaust w/ cat and resonater, 9 lb flywheel w/ act extreme, walbro 255, freshley rebuilt.
Cam gears are now set at +5 intake, +3 exhaust”
Engine: SR20VE
Cams: SR20VE 20V ?
Intake: WAI
Header: Topspeed
Exhaust: 2.5”
ECU: Emanage
Intake/Exhaust:
“This is my old dyno sheet with the bad bottom end, peak numbers are'nt that much different (whp), but look at 4500 rpm's, with my rebuilt motor I,m making 20 more WHP and 25 more WTQ. it's like that thru all the rpms except peak. I'm very happy with the mid range numbers.”
Engine: SR20VE
Cams: SR20VE 20V ?
Intake: WAI
Header: Topspeed
Exhaust: 2.5”
ECU: Emanage
Intake/Exhaust:
Mautai916@yahoo
“My mods: SSAC header, HS WAI, Pop charger, 2.5'' catback, JWT ECU, Grounding kit. My cams are set at 4800/5800”
Engine: SR20VE
Cams: SR20VE
Intake: WAI
Header: SSAC
Exhaust: 2.5”
ECU: JWT
Intake/Exhaust: 4800/5800
Nollan
http://www.sr20forum.com/sr20ve-sr16...ns-needed.html
“Darker line is first run with cams switching at 5000rpms.
Thinner line is second run wiht cams switching at 4700rpms.
SR20VE Motor
SR20VE cams
HS Gen 6 Header 3" outlet replaced with 2.5" flange
Stock Cat
2.5" VRS Catback
Greddy MSS switching cams at 4700 i/e
stock fuel pump
stock fpr
JWT ECU
JWT POP intake w/ stock intake pipe
ign timing at 15 deg
tps at .5 closed /4.2 open
B13 MAFS
VE Injectors”
Engine: SR20VE
Cams: SR20VE
Intake: WAI
Header: HS Gen 6
Exhaust: 2.5”
ECU: JWT
Intake/Exhaust: See above
nos91
“Mods are: sr20ve, sr16 cams, fuji headers, calum ecu and 2 1/2 exhaust. MSD switch was set at 4800.”
Engine: SR20VE
Cams: SR16VE
Intake:
Header: Fuji
Exhaust: 2.5”
Jonathon
1996 G20
1993 SE-R 13.35@102
Old 01-22-2007, 01:33 PM   #2 (permalink)
pachadwick
“SR20VE (SR16VE ecu - VE Distributor)
ThermoBlok Spacers
MSS
Fujitsubo Header
De-Cat
2" Mandrel Bent Stainless Exhaust
Hybrid Cold Air Ram”
Engine: SR20VE
Cams: SR20VE
Intake: CAI
Header: Fuji
Exhaust: 2”
ECU: SR16VE
Intake/Exhaust:
PennyFan
“I have done my Single TB (75mm) setup, found out that I lost a little hp (0.6kw) up top but the peak power apeared earlier, much more power at mid and low rpm. Gained more torque compare to Quad TB setup as well.”
Engine: SR20VE
Cams:
Intake:
Header:
Exhaust:
ECU:
Intake/Exhaust:
pimpm3
“Not bad for a SR20VE with stock cams. The car has a 2.5 Inch madrel exhaust with two resonators, and a borla muffler, with no cat. It has the old smaller SSAC 4-2-1 Header, a place racing Cold Air Intake and a Calum ECU.”
Engine: SR20VE
Cams: SR20VE
Intake: CAI
Header: SSAC
Exhaust: 2.5”
Intake/Exhaust:
PNWser
http://www.sr20forum.com/sr20ve-sr16ve/117913-my-aem-ems-sr20ve-results.html
“The car is a 1992 Sentra SER, w/SR20VE, SR16VE cams, SR16VE flywheel, stock clutch, POS OBX header, short ram intake, Megan Racing 2.5 catback and of course the AEM EMS netted me 188.XX HP(~7K) and 147.XX FT/LBS(~5K) to the wheels yesterday. Big thanks to John Reed at Torque Freaks in Portland, OR for the power tuning! redline is set at 8200, cams switch at 4500, ve injectors, aem 3.5 bar map and aem iat.”
Engine: SR20VE
Cams: SR16VE
Intake: WAI
Header: OBX
Exhaust: 2.5”
ECU: AEM EMS
Intake/Exhaust: 4500/4500
rigged200
“mods are hs cai, gen V, 2.25 crushbend exhaust, testpipe, ve injectors, g20 ecu, de maf, and of course safc”
“believe it or not but i got the numbers to prove it ive bumped the timing from 19* to 21* and i got 4whp to my midrange”
Engine: SR20VE
Cams: SR20VE
Intake: CAI
Header: Hotshot Gen. 5
Exhaust: 2.25”
ECU: G20 w/ SAFC
Intake/Exhaust:
Sabre 200 Gxi
“Power is rated in kw and nm. This converted to HP is about 162whp at the coast.”
“Are these figures about right for a 20ve running a de header, 2.5" catless exhaust, fabricated CAI and DE everything else incl injectors”
Engine: SR20VE
Cams: SR20VE
Intake: CAI
Header: DE
Exhaust: 2.5”
ECU: OEM
Intake/Exhaust: 4200/4200
Serban
http://www.sr20forum.com/sr20ve-sr16ve/100849-dynoed-my-vvl.html
“sr20ve (roughly 12k miles on the motor)
sr16ve cams
fidanza flywheel
jwt pop charger
short ram intake
HS gen 6 header (full 3")
3" exhaust, no cat
jwt cam gears (set at +5, -5)”
Engine: SR20VE
Cams: SR16VE
Intake: WAI
Header: HS Gen 6
Exhaust: 3”
ECU: JWT
Intake/Exhaust: 4600/4600
http://www.sr20forum.com/sr20ve-sr16ve/101484-re-dynoed-today-better-results.html
Engine: SR20VE
Cams: SR16VE
Intake: WAI
Header: HS Gen 6
Exhaust: 3”
ECU: JWT
Spoolin_RB
http://www.sr20forum.com/sr20ve-sr16ve/173872-finally-dynoed-vvl-results-pics-video-inside.html
“HKS Filter Short Ram
SSAC Header with 2.5in Secondaries
3in VRS Full Exhaust System
Nismo FPR
SAFC 2”
Engine: SR20VE
Cams: SR20VE
Intake: WAI
Header: SSAC
Exhaust: 3”
ECU: OEM w/ SAFC
Intake/Exhaust:
http://www.sr20forum.com/sr20ve-sr16ve/178572-finally-vvl-dyno-part-2-a.html
Engine: SR20VE
Cams: SR16VE
Intake: WAI
Header: SSAC
Exhaust: 3”
ECU: OEM w/ SAFC
Intake/Exhaust:
SR20loper
“hotshot gen 5 header port matched, AEM cold air ntake, no cat, 3 inch to 2 1/2 rear section to a 3 inch dual outlet magna flow muffler, fidanza flywheel, ACT hd with 4 puck, SE-R LSD tranny, one msd trigger set at 5k, JWT VE ECU,”
Engine: SR20VE
Cams: SR20VE
Intake: CAI
Exhaust: 3”
ECU: JWT
Intake/Exhaust: 5000/5000
sr20sleeper
http://www.sr20forum.com/sr20ve-sr16ve/155511-ve-dyno.html
“JWT VE computer for DE MAF and VE injectors, hotshot CAI, Fuji Header, STock Cat, Greddy Sp exhaust, timing at 15deg.
both cams switch at 4500.”
Engine: SR20VE
Cams: SR20VE
Intake: CAI
Header: Fuji
Exhaust:
ECU: JWT
Old 01-22-2007, 01:34 PM   #3 (permalink)
Teal97
http://www.sr20forum.com/sr20ve-sr16ve/159553-ecu-jwt-ve-vs-stock-dyno-results.html
http://www.sr20forum.com/sr20ve-sr16ve/159850-jwt-ve-vs-oem-ecu-afrs.html
“this is a stock sr20ve. just minor bolt on's which include:
nismo afpr
walbro 255 fp
hotshot cai w/jwt pop charger
fuji header
oem cat w/182k miles (breath clean baby)
3" vrs piping kit w/24" (overall length) resonator and a magnaflow 14" oval muffler
zex ultralight flywheel
yes. stock B14 maf and stock obd 2 ecu.”
Engine: SR20VE
Cams: SR20VE
Intake: CAI
Header: Fuji
Exhaust: 3”
ECU: OEM
Intake/Exhaust:
Engine: SR20VE
Cams: SR20Turbofreak Custom Grind
Intake: CAI
Header: Fuji
Exhaust: 3”
ECU: OEM G20
Intake/Exhaust: 4800/4900
VVLtrain
“Mods are:
WAI, JWT ecu, Fujitsubo header, 2.5 in exhaust with magnaflow, 2.5 cat.
(This is with stock VE cams)
*edit* I forgot to add that I did both cams switching at 4800.”
Engine: SR20VE
Cams: SR20VE
Intake: WAI
Header: Fuji
Exhaust: 2.5”
ECU: JWT
wanna92se-r
http://www.sr20forum.com/sr20ve-sr16ve/164247-budget-ve-dyno-partii-posted.html
http://www.sr20forum.com/sr20ve-sr16ve/162981-budget-dyno-run.html
“SR20VE
stock cams
cheap ass PACE SETTER header
ebay filter and MAF adapter
MSD non-digital RPM trigger switch
2 and a half inch CRUSH BENT EXAUST,no cats or resonator
S-AFC
g20 ECU
and a 89-94 maxima maf that everybody told me is useless and is a waste of money but CALUM recomends it to ALL VE guys
this was done in a b14 so everything is obd2”
Engine: SR20VE
Cams: SR20VE
Intake: WAI
Header: Pace Setter
Exhaust: 2.5”
ECU: G20 w/ SAFC
Intake/Exhaust:
Yellow4g63
http://www.sr20forum.com/sr20ve-sr16ve/158755-dynojet-numbers.html
“Intake, 2.5" exhaust, 2.25 cat that came with the car, Stock VE header all the way and way too much fuel I have to reburn the rom and head back to the dyno but thats where it's at.”
Engine: SR20VE
Cams: SR20VE
Intake: WAI
Header: SR20VE
Exhaust: 2.5”
Intake/Exhaust:
http://www.sr20forum.com/sr20ve-sr16ve/160070-went-back-dyno.html
“Anyway same mods as before warm air Intake, 2.5 vrghey exhaust, stock SR20VE header to 2.25 cat.”
Engine: SR20VE
Cams: SR20VE
Intake: WAI
Header: SR20VE
Exhaust: 2.5”
Intake/Exhaust:
http://www.sr20forum.com/sr20ve-sr16ve/162387-redyno-little-better-time.html
“Went back to the dyno after changin out my core cams to my spare SR16 ones. Mods are the same 2.5 exhaust with a 2.25 cat lol, Stock SR20VE header and warm air intake.”
“4600 intake and 4800 exhaust on run 10. #9 4800 intake and 5000 exhaust.”
Engine: SR20VE
Cams: SR16VE
Intake: WAI
Header: SR20VE
Exhaust: 2.5”
Intake/Exhaust: 4600/4800 & 4800/5000
http://www.sr20forum.com/sr20ve-sr16ve/175620-my-ve-back-road-again.html
“mods so far are SR16cams, Calum ECU, RB20 maf, VE injectors, stock VE header to 2.25 cat to 2.5 VRgay exhaust system along with a warm air intake from my old DE AEM cold air intake. 91 pee water ftw.”
"The last dyno run of 179 is after port and polish and same mods."
Engine: SR20VE
Cams: SR16VE
Intake: WAI
Header: SR20VE
Exhaust: 2.5”
Intake/Exhaust:
If you have charts for the following, please PM me.
autoxer7
http://www.sr20forum.com/sr20ve-sr16ve/65967-new-dyno-numbers.html
“My mods are: stock SR20VE, 3" PR CAI, Fujitsubo header, custom "Chase Race" 2.5" exhaust with Magnaflow muffler, 2.5" test pipe, JWT ECU, JUN lightweight flywheel, autocross alignment (-2.5 deg camber, 1/8" toe out).”
“183.0 hp and 146.9 lb-ft (SAE corrected, the uncorrected numbers were 193.9/155.6). This was on a Dynojet 248.”
eric96ser
http://www.sr20forum.com/sr20ve-sr16ve/70809-ve-dyno-video.html
“I have a HS CAI, Fujitsubo header, Courtesy cat back, SR16 cams, Nismo FPR, and JWT ECU. Right now I'm at 186whp. I'm still using the stock cat, but I have a test pipe at home that I just got. The best cam crossover points I found are 4500 and 5500 with my setup.”
“Same numbers really. 186whp / 140wtq. I had more RPm pills to try out. I ended up with 4500 intake, 5500 exhaust. That gives more of a smooth power band. I also messed with fuel pressure, but I think the AF gauge was off. I had the pressure turned up big time, and it still showed I was running lean. I will have a test pipe on Wednesday, but I'm not sure if I'll dyno anytime soon.”
juicetifer
http://www.sr20forum.com/sr20ve-sr16ve/148520-another-ve-dyno.html
“WAI, Fuji header, 3" mandrel exhaust with no cat or muffler, VE MAF, SR16Ve ECU, 370cc injectors, and an MSS for cams set at 4800 for both”
165whp with 132wtq
luckybull
http://www.sr20forum.com/sr20ve-sr16ve/143191-just-dynod-16ve-somewhat-disapointed.html
Muttly
http://www.sr20forum.com/sr20ve-sr16ve/129004-dyno-run.html
“HKS induction kit, 4 branch manifold (I think ye call them headers), 3" cat replacement pipe, 2.5" cat back Nismo exhaust with Nismo back box, HKS S35i Iridium spark plugs and something called a 2001 spec ECU.”
“I got my car dynoed 2 weeks ago using Dyno pack system Track Day Performance. Its made 179.6bhp at 8004rpm and 123.2ft/lbs at 7618rpm using 95ron.”
Ninety-Nine SE-L
http://www.sr20forum.com/sr20ve-sr16ve/144074-dynoed.html
“N1 intake mani.
CAI
JWT ECU w/ VE 333cc and VE MAF
SSAC header with 2.5" dp
2.5" open stainless all the way back with no cat
2pc UR pulleys
Fidanza / ACT HDSS
tuning: 17deg on the timing light, 0.38V closed TPS, plugs gapped to .040, checked and retightened the plugs. VVL in on 4700IE (also tried 4600I, 4800E with no major differences in #s).”
“161.0whp and about 131 ft-lbs”
Engine: SR20VE
Cams: SR20VE
Intake: CAI
Header: SSAC
Exhaust: 2.5”
ECU: JWT
SE-Rican
http://www.sr20forum.com/sr20ve-sr16ve/158125-went-dyno.html
“SR20VE
SR16 cams
SR16 flywheel
fujitsubo header
custom intake arm
ported intake manifold
3" exhaust
EMS Stinger 4424 standalone
CS cam gears”
“The final #'s were 203 whp at 154 ft tq.”
The Bom
http://www.sr20forum.com/sr20ve-sr16ve/129938-got-my-car-dynoed-sr16ve-pulsar.html
“My car is almost completly standard. I have an induction kit, NGK plug leads and NGK Racing Plugs No: T7340A-7. And i also have the cat removed.”
“The max BHP Was 165.4 at the flywheel and 141.3 BHP at the wheels the Torque was 113.8 lb ft.”
Old 01-22-2007, 01:35 PM   #4 (permalink)
I'm going to save this spot for future expansion.
Old 01-22-2007, 08:10 PM   #5 (permalink)
Air Force SE-R freak!!!!!
Dick's Avatar
Feedback Score: 52 reviews
Nice job a getting all this data from all the thread that have been posted. Must of took you a long time to get all this.
95' b14 SE-R w/ sr20ve
93' b13 SE-R w/ sr20ve
95' 240sx SE
Where to buy all your b13 and b14 cosmetic modifications>>>>>>www.rapidcustoms.com
Dick is offline   Reply With Quote
Old 01-22-2007, 08:12 PM   #6 (permalink)
Yes it did
Old 01-22-2007, 08:26 PM   #7 (permalink)
grease monkey
denske's Avatar
Feedback Score: 19 reviews
i wanna see JUN's dyno sheet, c'mon grow a set and post it, just leave it up for an hour and then you can delete it. lol
denske is offline   Reply With Quote
Old 01-23-2007, 03:16 AM   #8 (permalink)
Use to be ^
Awesome thread. Definately "sticky" material!!! *Hint hint* Mods!
*1991 SE-R TURBO SOLD!!!
*1990 240sx coupe SOLD!!!
*1991 SE-R SOLD!!!
*1996 Toyota Tacoma X-cab 2wd
*1991 Infiniti G20
*1989 240sx coupe
sentraturbo is offline   Reply With Quote
Old 01-23-2007, 04:17 AM   #9 (permalink)
done
Feedback Score: 7 reviews
nevermind
Old 01-23-2007, 12:33 PM   #10 (permalink)
12's Is So Last Summer!
urbanracerone's Avatar
Feedback Score: 36 reviews
Trust me Denske, it just doesnt make sense. The bottom line Andreas Miko has the most powerfull sr20ve powered car in the world.
P.S When you see me at the first event at either atco or etown you tell me what kind of power you think the car is making.
JUN
JUNIOR MAHABIR RACING LLC
NYC's Fastest Nissan's
214 N fehr Way
Bayshore NY, 11706
631.940.3638
urbanracerone is offline   Reply With Quote
Old 01-23-2007, 01:21 PM   #11 (permalink)
llaprad1's Avatar
Feedback Score: 12 reviews
I have to dig mine out. Also I seem to remember that Dyno Dynamics measurements don't directly compare to DynoJets.
Louis - 1993 Nissan Sentra SE-R
Rallycross Machine!
llaprad1 is offline   Reply With Quote
Old 01-23-2007, 01:25 PM   #12 (permalink)
I need to add a disclaimer at the top of the post. I would not even compare dyno numbers on the same model Dyno Jet if they are not on the same exact dyno with similar conditions.
Old 01-27-2007, 09:36 AM   #13 (permalink)
grease monkey
denske's Avatar
JUN
can't wait, see ya there.
Old 02-17-2007, 03:38 AM   #14 (permalink)
the proof wizard
Feedback Score: 26 reviews
you should add this one to the list...
http://www.sr20forum.com/showthread....****=lancesr20
12sec NA
Old 03-11-2007, 02:39 PM   #15 (permalink)
the proof wizard
coryb13ser
intake
n60maf
calum ecu
ssac 2.5 header
3in vrs exhaust
nismo fpr
msd switches @ 4800
Engine: SR20VE
Cams: SR20VE
Intake: WAI
Header: ssacII 2.5
Exhaust: 3in
Old 04-16-2007, 03:13 PM   #16 (permalink)
the proof wizard
engine: sr20ve
cams: sr16ve
intake: wai
header: ssac 2.5
exhaust: 3in
intake/exhaust: 4800
Old 09-24-2007, 05:02 PM   #17 (permalink)
I ride the deer!
codyace's Avatar
Feedback Score: 5 reviews
I'm sure Ray won't mind me posting his:
Gen V header, 3" Exhaust, Greddy MSS @ 5k (IIRC), JWT Popcharger, JWT Ecu.
Cody and Matt club Vice President
"More drama than a highschool prom queen competition"
codyace is offline   Reply With Quote
Old 10-09-2007, 02:47 AM   #18 (permalink)
Enemy of the stupid
Feedback Score: 9 reviews
Calum ecu, greddy MMS, VR ghey 2.5 exhaust, cat,SSauto header, velocity stack on maf made a jump in power as you can see by the higher # (I think it's cracked too) Intake set at 5k and exhaust set at 5400. 8k rpm revlimit
91 NX2000 VE forsale
Protech-Fabrication
http://www.OSRdyno.com/
Old 10-23-2007, 01:23 PM   #19 (permalink)
the proof wizard
engine: sr20ve
cams: N1
intake: 3in wai
header: custom 4-1
exhaust: 3in
Old 10-23-2007, 05:14 PM   #20 (permalink)
vz-r driver
i see a drop where the cams are set to engage.... do u think that if u trigger them independent that it would be smoother there...... at the 5700k mark???
THOR is offline   Reply With Quote
